Question about Tokina 80-200mm f/2.8 AT-X 828 AF PRO Auto Focus Zoom Lens with hood & pouch for Nikon AF
Soft when lens opened up
It appears the sweet spot for this lens is f6.7 and up. I've read some reviews stating they where getting good pics open wide f2.8. Is there something that can be done to the lens to make it less soft at the upper end. ie f2.8-4.0
Thanks
Bill
  • dvdman45 Jan 18, 2009
    Unfortunately it is soft throughout the pictures at wide open
    Bill
  • dvdman45 Jan 21, 2009
    Unfortuately even in the tight area, of say f2.8, it is still soft...guess I got a lens that could use some tweekin'
    Bill
    Novelist:
  • 121 Answers
Bill,
Your depth of field will be reduced, but that may be what you are after and the results are fantastic for portraits. The focus will be tight in a smaller area - You don't have to go that far, but you'll have to slow down your exposure time in combination with the upping the ISO (you are shooting with a digital camera correct?) test that out on some images to see if that helps out.
randy320sgi
Posted on Jan 15, 2009
  • Randy Wheatley
    Randy Wheatley Jan 29, 2009
    Bill,
    I never asked you what type of resluts you are trying to get? That is a versitile lens, what is it about the softness you are concerned about? Your comment about the tight area makes me think you are relating it to focus, my comment related to the depth of field - can you give me some more info on the problem?
    randy320sgi
Merlin 230t
If the chain is loose I would definitely tighten it up to remove the sloppiness of the drive. That will in turn help you to accurately find the sweet spot that is currently eluding you. And you have to work fast because you do not want to overheat the motor.
Sep 21, 2017 | Sears Craftsman LiftMaster Chamberlain...
I turned on my f410 camera but the lens does not extend out at all
The gear linkage in the lens has more than likely seized, you will need a specialist to handle the repair, but before you proceed ask for a estimate.
Jun 09, 2012 | Fuji FinePix F410 Digital Camera
When a disc is inserted it spins about 3 revolutions & stops then the message says "NO DISC". So appears to not read or see the disc.
Hi Robert,
First of all, thank you for posting your question here at Fixya.You may try the steps below to resolve the issue.
Assuming that the disc is good.
1.Clean the lens. -Sometimes because of dust and any fine foreign objects the optical lens can'tread any disc. If you have a CD Lens cleaner, play it to the unit. If this isnot available you may manually clean the optical lens. Open the cover andgently clean the eye of the lens by smooth,clean,soft cotton buds. Be carefulwhile doing this, just a gentle stroke only.
2.Check the ribbon - Checkthe ribbon connected to the lens from the main board for scratch, damage. Once it has anopen line then of course the lens can't read the disc, this is because of themovement of the optical lens back-and-forth. Also try to erase the contact by pencileraser. If you've done the steps above and the symptoms still there then thenext step requires you a little knowledge in soldering technique and readingthe ohmmeter.
3.Check the spindle motor -Check the spindle motor that spin the disc with an ohmmeter. You can test itusing the ohmmeter (x1) even it is connected on the lens assembly.Good motor - reading should be fairly high and itwill spin. Bad motor-reading will drop to low resistance and will not spin or spin slowly.
HopeI helped you.
Have a nice day!
Thanks for using Fixya.
Jan 21, 2012 | JVC XL-MV303 CD Player
Tamron 28-75 SP AF XR DI does not sharp at 2.8 - 4 aperture.
You didn't state whether you are using it on an APS-C or a full-frame SLR, but that lens is known to be very soft and unsharp especially at the edges until you stop it down below f4. It also exhibits strong vignetting until you stop it down.
The effects are far more noticeable when using a full frame sensor.
Some production examples will be worse than others, and some users will notice the unsharpness more than others. You clearly find the performance to be unacceptable, but it is mentioned in almost every review of that lens. Your lens is not unique in the weaknesses it exhibits as most lenses perform worst at wide open apertures.
You have discovered one major reason why some lenses are cheaper than others, and why lenses designed especially for low lighting levels are hugely expensive..
Your only real fix is to try and avoid shooting at apertures of f4 and larger. If that's unacceptable to you and you need a lens which performs well in low lighting conditions then you can only return the lens for a refund (much easier if you live in the UK due to the Sale of Goods Act). If you cannot get a refund then I suggest you sell the lens and buy a better quality replacement, or better still replace the zoom lens with fixed focal length prime lenses.
Zoom lenses are always an optical compromise, particularly so with zooms covering the wide to short telephoto range, and now that many dSLR's can produce low noise results at very high ISO settings there's less demand from customers for manufacturers to make lenses which have outstanding performance at wide apertures at higher cost.
Jul 14, 2011 | Tamron 28-75 F2.8 XR AF Lens
When I turn the camera on, the lens won't open. I can review pics I have taken, but cannot take new ones.
its a problem with your lens cover shutter on the upper face of the lens. Get it repaired in some Kodak service center.
Aug 06, 2010 | Kodak EasyShare C140 Digital Camera
White spot on photo
Hi and welcome to FixYa,
Initially, this would be a temperature imbalance on the CCD lens. Often white spot(s) appear at night or when the temperature is cold. Workaround is to open the lens but delay taking a picture after a few seconds. The idea is allow the lens to match the ambient temperature.
Good luck and Thank you for using FixYa.
Jan 09, 2009 | HP Photosmart 315 Digital Camera
Lens is stuck open
We had the same problem with a Casio Exilim. Had been stuck for months...had nearly given up until I saw another post about banging the camera pretty forcefully to get the lens unstuck. I hit it once on the bottom onto my desk(w/ paper and blotter on the desk-so soft), then twice with the back of the camera against the desk. I turned it on and the lens was unstuck!! Immediately took a couple pictures and it seems to be working fine! If the camera may be lost, you've got nothing to lose to try this out...Good luck!
Apr 26, 2008 | Casio Exilim EX-S500 Digital Camera
Something inside lens
i work with sonys all the time ..I do not recommend disassembling the lens section at all. unless its between lens and CCD imager but I doubt its there..
Nov 08, 2007 | Sony Cyber-shot DSC-W100 Digital Camera
Overexposure on outdoors shots
i think it is a case of defective apparture system. the system controlling the change of apparture opening has been locked. the reason may be friction in the blade movement or defective flex pcb carring the signal to the apparture motor.
Jul 03, 2006 | Olympus Camedia D-550 Zoom Digital Camera
Focus problem
Suggestion: 1. camera probably has a sharpness setting. 2. avoid wide open, F/5.6 is the sweet spot on most lenses.
Sep 14, 2005 | Canon Digital Rebel / EOS-300D Digital...
Tokina 80-200mm f/2.8 AT-X 828 AF PRO Auto Focus Zoom Lens with hood & pouch for Nikon AF Logo
168 people viewed this question
Top Tokina Cameras Experts
M_Butkus
Steve
Are you a Tokina Camera Expert? Answer questions, earn points and help others
