Question about Panasonic NN-P794SF Microwave Oven
Tripping circuit I have a PANASONIC NN-SD787S and now everytime I use it, it trips the circuit breaker. It will turn on for a few seconds and them trip the breaker.
  • 368 Answers
Hi lbeaujuin,
You don't say how long this has been going on; I'm going to presume it's a recent development.
Several possible scenarios come to mind. I'd first look around and see if any other appliances have been connected to that circuit. In my area (Minnesota), the electrical code requires that microwaves have their own dedicated circuit and breaker; if this is not the case, you need to see what else is competing with your microwave for that breaker's power supply.
One other possible cheap fix - in case the breaker is defective, try swapping out the breaker in-question for another of the same rating (DO NOT, repeat, DO NOT put in a bigger/higher-rated breaker without having a qualified electrician OK it). If this isn't the problem, it never hurts to have a spare circuit breaker on-hand. Might even be able to switch around with another of the same rating, just understand that you'll lose power to both circuits for the duration of the test.
If it's on it's own dedicated circuit, then it's likely the oven itself with an internal short of some kind. Because I don't know your level of skill in dealing with 110V AC electricity, my recommendation is that you have someone qualified open it up and start checking short-circuits with a multi-meter, observing all safety precautions.
If you've isolated the problem to being the oven, and it's going to cost more to troubleshoot than replace, you might be able to cut a deal by trading-in your old oven against the new one - - if the shop you buy from has quailfied repair people on-staff, they might be able to refurb and re-sell it used.
If I can be of further assistance, or if you have questions about any of my response(s), please let me know before rating me.
If this solves the issue, please rate it accordingly. My goal is to earn a "FixYa" rating from everyone I help.
Thanks for using Fixya.com,
Jon
Posted on Feb 21, 2009
I have a panasonic model nn-sd277 microwave. I changed the fuse and now it has power again. The fan and light all work. It trips my breaker and sometimes blows the fuse when you try to heat anything.
time to take it to an appliance repair shop for a quote
it is blowing fuses and tripping breakers because it has a serious short in the electrics
Jan 03, 2016 | Panasonic Microwave Ovens
Freestanding stove (range) keeps tripping breaker when oven is used or two burners are used
Is this a new installation?? It sounds like the circuit breaker is under rated for this unit.
Nov 03, 2013 | Panasonic NN-H965 Microwave Oven
Microwave keeps tripping circuit breaker
Chances are you have a shorted "monitor" interlock switch, or its mount is broken.
See this door switch help file.
You can find links to helpful exploded view diagrams and part ordering help here.
To give you more specific help, we would need the brand name and
full model number of your microwave.
We're
happy to help you with free advice and we'd appreciate your thoughtful rating of our answer.
Aug 30, 2012 | Microwave Ovens
Where is the second fuse in my panasonic nn-s963bf the one for the heating and what does it look like?
There is no second fuse. Look for a thermal cutoff there are a few of those. Test it for open circuit and replace.
Aug 11, 2010 | Panasonic NN-S963BF Microwave Oven
Panasonic NN-T994SF Microwave Oven quits after 15 seconds
my microwave shuts off after a few seconds. is there a fuse that needs replacing?
Feb 01, 2010 | Panasonic NN-T994SF Microwave Oven
Panasonic nn-s255 wont turn on
See if this describes what's happening:
  • Put in time, push start and unit runs for 2 seconds, relay clicks, unit goes off. Cook time on display goes off and clock time comes back. Bad upper interlock switch and charred connector
If so, see http://www.microwavedisplay.com/safety.txt , http://www.microwavedisplay.com/disassembly.txt and http://www.microwavedisplay.com/doorsw.txt
Otherwise, if the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
It may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
In Canada, you can find an authorized Panasonic servicer here.
NOTE: The FixYa system is not currently notifying me when folks reply to my posts, so please contact me directly for more help.
William E. Miller
prototech@usa.net
Sep 08, 2009 | Panasonic NN-P295SF Microwave Oven
Microwave / Frigidare PLMV
Chek the high voltage capacitor and the diode . If one of them are short there is a chance for tripping the breaker
May 25, 2009 | Frigidaire PLMV168 Microwave Oven
No power to Panasonic NN-S252 microwave oven
follow the incoming mains lead into the microwave their is a small pcb with a fuse their check this first
Nov 14, 2008 | Panasonic NN-S254BF Microwave Oven
Microwave causes GFCI on another circuit to trip
You may have a shorted High voltage component. Possibly a recttifier,aka, diode. This should only be replaced by an experienced repairman as an extremely high voltage shock potential exists.
May 27, 2008 | Panasonic NN-H764 Microwave Oven
Panasonic NN-P794SF Microwave Oven Logo
436 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
