Question about Gateway MT3705 Notebook
CANNOT SEND OR RECEIVE MAIL IN VISTA WINDOWS MAIL
I've tried everything I was told to do but to no avail. I've tried:
1. checking the server name is entered correctly
2. checked for viruses and other malicious hardware
3. looked up different and related subjects in the "Help"
section
4.written to Microsoft ---a lengthy reply that didn"t work--- and Fix Ya (for $10.00)--no reply yet
5. varios other suggestions
I'm at my wits end
Thanks for whatever help you all can provide
LVYoung@cox.net
The host 'POP3' could not be found. Please verify that you have entered the server name correctly.
Account: 'POP3', Server: 'POP3', Protocol: POP3, Port: 110, Secure(SSL): No, Socket Error: 11001, Error Number: 0x800CCC0D
The host 'SMTP' could not be found. Please verify that you have entered the server name correctly.
Subject 'hello', Account: 'POP3', Server: 'SMTP', Protocol: SMTP, Port: 25, Secure(SSL): No, Socket Error: 11001, Error Number: 0x800CCC0D
  • 741 Answers
Sir, this is a classic case of your computer not connecting to your Internet Service Providers mail server, its a common problem and not hard to fix. You may have it typed in correctly but the problem may be at the ISP's end. I don't know what solutions you were provided but try this one and if it does not work then you need to call your Internet Service Provider and demand a fix immediately.
Click on start>run> then type in "cmd". This will bring you to the DOS prompt. Type in "ipconfig /all" and write down your IP address and your gateway address so you can provide it to your ISP. If your IP address is 192.168.x.x then your DHCP is not providing you a private IP address. Regardless of what the IP address is, the only option for you is to do the following: At the DOS prompt type in ipconfig /release. Then type in ipconfig /renew. IP addresses are automatically provided by a Dynamic Host Configuration Protocol (DHCP). Once you release your IP address and receive a new one then the problem can no longer be fixed at your location,it is your Internet Service Provider that is causing your problem. Someone should have told you this long before you got the migraine..I apologize for the sub level service you have been provided by our company. Good luck and let me know how things turn out.
Posted on Jan 15, 2009
  • Randall  Trahan
    Randall Trahan Jan 15, 2009
    Its not mail.cox.net its smtp.cox.net or pop.cox.net, if u don't know the answer keep it to yourself, you are making us all look like a bunch of idots.
  • 66 Answers
PUTwhere pop is. mail.cox.net on the first line and on the next line smtp put mail.cox.net That it all you do is put mail. And your prvider. your user name you use to get online an pass. i will see if i can find a print.
I can't receive my mail.
What type of server that your e-mail account works with?
If you are using POP3 or IMAP account, please configure Incoming mail server.
You should try the given below solution to resolve the occurred issue:
Sol 1:
Open "Microsoft Outlook" >> Click on "File" tab >> "Account Settings" >> "Account Settings", locate your account and click on change.... then click on "More Settings" to configure Incoming mail server.
If you are using Microsoft Exchange account, check if you use cached exchange mode. If not, enable it. Click on "File" tab >> "Account Settings" >> "Account Settings" locate your exchange account and click on "change...."
Under server settings, check Use cached exchange mode.
You can check another setting to help resolve being able to send but not receive e-mail messages.
You can set up Microsoft Outlook to check for new e-mail messages at intervals of one minute to 1,440 minutes (one day).
On the "Send/Receive" menu, point to "Send/Receive Groups", and then click on "Define Send/Receive Groups".
Select the group that contains the e-mail account that you want to regularly check for messages.
Under Setting for group "group name", select the Schedule an automatic send/receive every x minutes check box.
Enter a number from 1 to 1440 in the minute's box.
Click on "Close" button. On the Send/Receive menu, click Send/Receive All folders.
Sol 2:
Open "Microsoft Outlook" >> Click on "File" tab >> "Account Settings" >> "Account Settings" >> Click on "Change Folder" button >> Change from whatever it was to: Outlook Data File - Inbox
Close the dialog, click on send/receive or press F9 button and see if it works.
Thanks & Regards
Captain Ashish
Nov 06, 2015 | Microsoft Outlook 2010
0send/receive showing 0 of 52 task completed?
hi!!!!!
may be there is a problem in your ISP
so try to resend it
or try to zip your jpegs file and then sen it to email!!!
Sep 21, 2008 | Computers & Internet
Trying to send emails but comes up with message that "The host SMTP could not be found. Please verify that you have entered the server name correctly. POP3 Server - SMTP, Protocol:SMTP, Port 25....
Hi Your internet (mail) set up has 2 different parameters . One for Receive and second for Send. The msg you ve is ror Send , reminding you have not set it properly Open your Pc mail setup menu and find the working values there and insert these paramaters into phone setting. Thats it, Take care and please remember to vote us .thanks
Aug 01, 2011 | Lands Phones
Can't use either Microsoft Live Mail or Lookout Express v6 with Belkin Router. Can't send or receive email Can you tell me what the email setup is for either one? Both email programs probably use the same...
Ask COMCAST for the names of their POP-server and of their MAIL-server, and configure Outlook Express to use those names.
Microsoft Live Mail is "web-based" -- all you need to do is to web-surf to their web-site, login, and click "send/receive" or click "compose" and later "send".
Sep 03, 2010 | Computers & Internet
I can recieve email but I cant send any email out
If you can successfully receive e?mail messages, but can't send messages, then Windows Mail is having problems connecting to the outgoing e?mail server that's used to send messages. These are likely possibilities:
  • If you've never been able to send e?mail successfully using Windows Mail, your e?mail account is probably not set up properly. First, follow the steps to verify your e?mail account information in the "I can't receive e?mail" section of this help topic. If you verify that your e?mail account information is entered properly, you might need to change your authentication settings so that when sending mail, you sign in using your e?mail user name and password. Check with your e?mail provider to see if it requires authentication for sending e?mail.
    To use authentication when sending e?mail
    1. Open Windows Mail by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33.png, clicking All Programs, and then clicking Windows Mail.
    2. Click the Tools menu, and then click Accounts.
    3. Under Mail, click your e?mail account, and then click Properties.
    4. Click the Servers tab, and then, under Outgoing Mail Server, select the My server requires authentication check box.
    5. If the account information that you use to send e?mail is not the same information that you use to receive messages, click Settings, click Log on using, and then enter the user name and password that you use to send e?mail.
  • Many Internet service providers (ISPs) require you to be directly connected to their network to use their outgoing e?mail servers. If you're using a mobile PC and connect to the Internet using a different ISP (such as when using a wireless connection in a hotel), you might be able to receive, but not send, e?mail. Some ISPs will allow you to send e?mail when connected to a different provider if you use authentication when sending. Follow the previous steps to use authentication when sending e?mail. If your ISP doesn't allow this, you'll need to find out the name of the outgoing mail server for the ISP you're currently using, and then change the settings in Windows Mail to use it.
    To change the outgoing mail server settings
    4. Click the Servers tab, and then enter the new mail server in the Outgoing Mail (SMTP) box.
    5. If the new outgoing mail server requires authentication, under Outgoing Mail Server, select the My server requires authentication check box.
    6. Click Settings, click Log on using, and then enter the user name and password for the outgoing mail server.
Mar 27, 2010 | Yahoo Mail
Cannot connect to subscriber in China
Typically this error indicates that you are trying to send your Adhost email through Adhost’s mail server when you have not authenticated your email account to send mail. Our mail server authenticates you through your pop account. So when you check your email, our mail server authenticates your pop user and password, captures that IP that you are checking your email from, and adds that IP to our relay list. This list is flushed every 70 minutes. This means, if you try to send email after the relay list has been flushed and before you’ve attempted to check your email, you will receive this error.
How to fix the problem:
Fix #1 - reauthenticate on our server.
Remove any email from your Outbox. If you need to keep the message, you can move it to your 'Drafts' folder.
Click "Send/Receive". This will reauthenticate you.
Try resending the email.
Fix #2 - configure your email client to check for email before sending.
In Outlook, go to "Tools" and select "Email Accounts". Make sure "View or change existing e-mail accounts" is checked. Click Next.
Select your account from the list and click "Change".
Select "More Settings".
Select "Outgoing Server".
Check "My outgoing server (SMTP) requires authentication".
Select "Log on to incoming mail server before sending mail".
Click "OK", then "Next", then "Finish".
This will fix your problem
Or
Call Yahoo! Customer Service
USA: 1-866-562-7219 --- 1-800-318-0631
UK 020 7131 1000
Canada: 1-877-722 3755
Direct Number: 1-408-349-1572
Regards
manish
Mar 20, 2010 | Yahoo Mail
I am not able to send or receive my Yahoo mail. I
Hi
Follow these steps.
ncoming Mail (POP3) Server: pop.mail.yahoo.com (Use SSL, port: 995)
Outgoing Mail (SMTP) Server: smtp.mail.yahoo.com (Use SSL, port: 465, use authentication)
Account Name/Login Name: Your Yahoo! Mail ID (your email address without the "@yahoo.com")
Email Address: Your Yahoo! Mail address (e.g., user@yahoo.com)
Password: Your Yahoo! Mail password
If you want to use Outlook, Outlook Express, Thunderbird or other third party email clients to view your email you have 2 options.
Subscribe to mail plus:
http://billing.mail.yahoo.com/bm/Upgrade…
or download and install YPOPS
http://ypopsemail.com/
then follow the directions for your version of outlook here,
http://help.yahoo.com/l/us/yahoo/mail/or…
If you have trouble with set up, check the YPOPS installation page for alternate set up instructions.
http://dbeusee.home.comcast.net/
Click on YPOPS link on the left.
Then Click on Configuring email clients towards the bottom.
Choose the appropriate link for your mail client.
I currently utilize version 2.0.0.4 of Thunderbird
and version 0.8.3 of YPOPS (there is a more recent version of YPOPS that you need if you are Yahoo Beta Mail) and have no problems.
Jan 27, 2010 | Yahoo Mail
Hey fixya guys, ive got a works laptop (Dell) with vista and im trying to get outlook express which works fine in work, but not from my home broadband, ive phoned my Isp Virgin media technical support but...
Hi Mark,
In Windows Vista Outlook Express has been replaced by Windows mail. You can configure the Windows mail with similar settings.
Open Windows Mail by clicking the Start button getopencontent.aspx?assetid=4f6cbd09-148c-4dd8-b1f2-48f232a2fd33&documentset=en-us&renderkey=xml, clicking All Programs, and then clicking Windows Mail.
Follow this tutorial to Setup you Windows mail
Oct 06, 2009 | Dell Vostro 1500 Notebook
Sending mail with Vista Windows Mail
Window Vista also have Outlook Express.. please enter the full info for your email account..
On the E-mail Settings page, enter your email account information as follows:
Your Name
Enter your first and last name.
E-mail Address
Enter your email address.
Account Type
Select POP3.
Type for your incoming mail server.
Outgoing mail server (SMTP)
Type for your outgoing mail server.
User Name
Enter your email address again.
Password
Enter the password you created for your email account.
After this please check for "Test Account setting"
If everything is working fine, then remove the previous account
And let us know the error message if come up any.
I hope it will resolve the problem and you will be able to use the Outlook.
May 01, 2009 | Microsoft Computers & Internet
Gateway MT3705 Notebook Logo
169 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
