Question about HP PhotoSmart 7960 InkJet Printer
Print cartridge cradle is stuck. When yout turn the printer on it move slightly in place then gives the error message written above. Please help.
  • 186 Answers
Make sure the cover that holds the ink cartridge in place is completely closed down on the cartridge. Also make sure there is not a pencil or something under the cover where the ink is , obstructing the print head
Posted on Jun 16, 2007
Cartridge cradle is stuck
Hi KHphoto, you can see this steps to fix your printer jam,
  1. Disconnect the USB cable.
  2. Press the printer power button to turn off the printer.
  3. Disconnect the power cord from the back of the printer.
  4. Open the top cover of the printer.
  5. Remove the print cartridges from the printer.
  6. Slide the cradle to the right side of the printer.
  7. Locate the clutch on the left side of the printer.
    NOTE: The clutch is a flat, white, plastic component that rests just above the white roller gear wheel. In the HP Photosmart P1000 and P1100 printers, the clutch is black metal. Figure 1: Printer clutch c00020494.jpg
  8. Remove the rear access door from the back of the printer.
  9. Press the clutch firmly towards the back of the printer, while rolling the wheels in the back of the printer upward two full rotations.
  10. Release the clutch and roll the wheels up two more rotations.
  11. Reinstall the rear access door.
  12. Reinstall the print cartridges and secure the latches in place.
  13. Close the top cover and reconnect the power cord.
  14. Turn on the printer.
  15. Print a test page.
original post*
If you are still having problems let me know.
Jan 03, 2008 | HP PhotoSmart 7550 InkJet Printer
Paper cartrige cradle is stuck.
print cartrige cradle is stuck clear jam then press ok in hpphotosmart 7550
Sep 08, 2009 | HP Photosmart 8150 InkJet Printer
How to remove the cartridge from hp photo smart 7960
Hello the manual way to release cartridge is
  1. Disconnect the power cord from the printer.
  2. Open the top cover.
  3. Look for the gray-colored carriage on the right side of the printer.
  4. Find the horizontal (bottom) edge of the carriage and follow it towards the back (or in) until it makes a 90-degree turn. Follow it down to the ¼ inch-high, black-colored capping station.
  5. Using a screwdriver or similar tool, push the capping station toward the back of the printer.
    NOTE: Do not pull on the ribbon cable when moving the carriage.
  6. Making sure to not push up on the carriage, move the carriage to the middle of the printer. If the carriage is still locked in place, push the capping station farther into the printer and try moving the carriage again.
  7. After the carriage is pulled out from the right-hand side of the printer, remove both print cartridges and store them according to specifications.
  8. Close the top cover.
Sep 03, 2009 | HP PhotoSmart 7960 InkJet Printer
HP photosmart 7960 gives message Cartridge Service station is stuck. Cannot see a jam or obstruction...any suggestions?
Unplug the Power Supply from the Printer.......
Remove both the Catridges from the Printer.........
Just Move the Catridge Carrier which Holds the Catridge Back and Forth for about 20 Times.........
Insert the Catridges back to the Printer.........
Turn the Printer On...........
Good Luck.............
Apr 04, 2009 | HP PhotoSmart 7960 InkJet Printer
Error Message - "Print Cartridge Cradle is Stuck. Clear jam."
open the printer - take out the print cartridge and put it back in
Mar 20, 2009 | HP PhotoSmart 7960 InkJet Printer
The print cartridge cradle cannot move.
"The print cartridge cradle cannot move."
I fixed this problem by disconnecting the power cord from the power-strip and connecting it directly into the wall. My printer was not getting enough voltage from the power-strip. I hope this helps.
Nov 18, 2008 | HP Photosmart C3180 All-In-One InkJet...
Print cartridge stuck
Hi please click on the link below to know exactly what you need to do to fix paper jam problem.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpd09128&lc=en&cc=us&lang=en&rule=1823&product=77146&dlc=en
Please let me know if it fixed the problem or not.
Cheers
Jun 10, 2008 | HP PhotoSmart 7960 InkJet Printer
Cartridge 57 failed
Brenda Walker on August 18, 2009
I think I may have solved this problem. What I did was take out the #56 cartridge and hit the print button. It started to calibrate and then said it was printing on reserve or something? Yup, it printed with only one (#57 cartridge). After that, I stuck in a new #56 cartridge and so far so good for it only happened yesterday.
I hope this solves your cartridge #57 failed problem. Let me know if it does.
Aloha from Hawaii
May 01, 2008 | HP PhotoSmart 7660 InkJet Printer
I have had this problem with my 7550 for a while now and I finally found this on the HP website and it seems to have fixed my problem, I also replaced all of the cartridges:
Issue While printing from an HP Photosmart printer, the printer screen displays Print cartridge cradle is stuck / clear jam and then press OK . The printer may also make grinding sounds. This can occur after a paper jam when another printer part blocks the cradle. Solution Follow these instructions to adjust the clutch on the printer.
Nov 27, 2007 | HP PhotoSmart 7550 InkJet Printer
HP PhotoSmart 7960 InkJet Printer Logo
245 people viewed this question
Clive
Clive
