Question about Ricoh Aficio 450 Copier
The copy of afficio 450 become lighter
Every 50 to 100 copies my copier print lighter or the black print is not equal wat is the problem of my copier...wen i push the toner 2207 it print ok agen..
  • 4 more comments
  • thraser
    thraser Jan 15, 2009
    The copy count of my machine is 250,000..
  • thraser
    before this hapen i clean my pcu unit..."drum charge roller cleaning blade.. after dat i run 2801 and 3001... after 100 ton 200 copy it copy lighter
  • thraser
    after i replace my developer wat procedurte wil i do.. initialize 1st the developer and push toner... wat is the ryt tings to do...wer can i buy good quality of developer .. im hir in philippines do u have any idea??
  • thraser
    oki after i do replacing developer w/ a new 1 wat wil i do.. wat procedure i must folow... tenkz a lot men...
  • thraser
    the developer contain 500g i wil put it all in the developer unit??
  • thraser
    thraser Jan 16, 2009
    can u help me wat service code to be run to calibrate the new developer?
  • Ricoh Master
  • 2,794 Answers
You may want to consider putting developer into the unit. What is the copy count on the machine?
Posted on Jan 15, 2009
  • 2 more comments
  • Tim Babcock
    Tim Babcock Jan 15, 2009
    The developer needs to be replaced every 125,000 cycles in your copier. Once you replaced this, your copy quality should be corrected.
  • Tim Babcock
    Try precision roller.com. I use them. I'll have to give you the initialize codes once you get some.
    Make sure you remove all of the old developer out of the unit and vacuum the mag roller.
  • Tim Babcock
    Yes. You evenly put it into the unit. Then there are a few service codes to run to calibrate the new developer.
  • Tim Babcock
    Tim Babcock Jan 16, 2009
    Press the yellow button, press 1 0 7, press the clear button. Search the service menu for developer intialization or developer calibration.
    It will take me some time to look up the specific service code if you don't see it by searching through the menus. Let me know if you don't see it.
Afficio450 replace new developer unit wat procedure to be follow?
No, the 450 is just one of those machines that seem to have PCQ no matter what you do. Given light copies, I'd replace the drum for sure and make sure your ID sensor isn't covered with toner. Dust covered optics will also cause light copies on this model.
Jul 25, 2009 | Office Equipment & Supplies
How to calibrate the dv and toner...afficio 450.or gestetner 3245
Hello sir; Just follow the steps;
1, dump entire dv use vaccunm cleaner to cleanup don't leave any dv inside.
2, thorughly clean out magnet roller by rubbing alcohal.
3, pour in new dv evenly.
4.Do simulation 2801 & 2805, the procedure as follow;
press"clear mode", "107", press and hold "clear/stop" key for 3 seconds, then press 1 for copier sp then enter2801 press start, after that go to 2805. same procedure. Let me know the resolve.
Mar 02, 2009 | Ricoh Aficio 450 Copier
Afficio 450 olridy change developer but the copy is stil faded
There are two service codes that you need to run 2801 and 2805 after you put the developer in the machine.
Press the yellow button on the copier. press 107 on the keyboard. Press and hold the clear button. Then run the service codes.
You have to run the codes first after changing the developer. You might have to replace the developer again to get the correct mixture.
Jan 26, 2009 | Ricoh Aficio 450 Copier
Afficio 450 copy faded in some area...
If the image is good in parts, but light in others it is most often toner build up on the laser exposure glass which can be easily -but also VERY CAREFULLYremoved. If you lift the green handle for the toner bottle, you should see a narrow piece of glass protruding just underneath. You can grasp it with you fingers and slide it out for cleaning. Sometimes these have been removed (or broken) so they are not there. If the machine is also a printer, you should see much improvement (if this was the cause). If regular copying is still light in areas, then you may want to remove the copier glass - 2 screws on left scale, and 3 screws on rear scale (POWER OFF ON MACHINE), remove glass and clean with glass cleaner, then slide scanner to the left and clean the mirrors.
Hope this helps.
Jan 17, 2009 | Ricoh Aficio 450 Copier
Gestetner 3245 get lighter wen run 50 to 100 pgs
the amchine runs a density patch every 50-75 prints if you run long jobs it cannot run patch till job is finished which is why your copies get lighter the longer the job
Jan 14, 2009 | Office Equipment & Supplies
Afficio 450e gray copy or lighter copy
Look into replacing the developer in your copier. It has to be replaced every 125,000 cycles.
Afficio 450
you need developer 7734748865
Afficio 450 seeting
Auto setting. If you are getting light copies, you might need the developer replaced as well.
Aug 21, 2008 | Office Equipment & Supplies
Afficio 450 camera lense alignment
You need a manual to calibrate the scanner do you have one?
There are some holes in the scanner that need to be calibrated with a tiny screwdriver. The manual teslls you the correct settings.
Did yiou remove the cable?
Aug 19, 2008 | Office Equipment & Supplies
Developer....
When developer goes bad you use more toner for one thing, but the main sign is a gray background in your copy. The print should be black but appears to be gray. The ricoh 350/450 was always noted to leak toner and developer as it runs. Check your machine and see if you see any small piles of toner, which also has developer in it, in the machine. Ther are small seals made of felt that need to be replaced if you have this problem. These seals rub against the drum sides....Good luck.
Jul 20, 2008 | Ricoh Aficio 450 Copier
Ricoh Aficio 450 Copier Logo
132 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
