Question about Kitchen Ranges
How to unscrew a bulb from a new ventahood over the cooktop
I can't seem to get the bulb out of my new  vent a hood
  • 26 Answers
DID YOU TRY TAKING THE COVER OFF. IF SO TURN THE BREAKER FOR THAT FAN THEN PAT A GLOVE ON INCASE THE BULB BREAK'S WHEN PULING UNSCREWING. MOST TIMES IT WAS EITHER SCREW IN WRONG OR JUST HAS GREASE AND RUST.
Posted on Jan 23, 2009
Ventahood b200msc
That would depend on what country you are in. If it is not the USA then it is most likely the voltage is 220. The products are listed here: http://ventahood.com/specifications.jsp IT appears that you dont have the right model number.
Apr 07, 2014 | Kitchen Ranges
Replacing light bulb
make sure the power is off and unscrew it with long nose pliers
Sep 10, 2013 | Maytag MMV5208WB - 2.0 Cu. Ft....
We can't unscrew the bulb from our ihl48 dacor vent hood insert. Someone said to just unscrew it like a light bulb in a lamp but that isn't working. We are afraid to torque it any harder. Any suggestions?
Hello. Be sure to kill the power to the hood at the breaker. Then back to the bulb.
Yes it does unscrew like any bulb. [right is tight and left is loose]. Wear a glove on the hand you will unscrew the bulb with. If it does break, no problem; then use a pair of needle nosed vise grips to grab hold of the metal threaded ring and unscrew it. Often times these bulbs are exposed to so much moisture that they corrode resulting in the difficulty you are having.
4 thumbs up please. ty Joe
Oct 23, 2010 | Kitchen Ranges
My new home already has a hood vent for the range. I have a gas Jenn air downdraft range. I prefer to use the hood vent as the downdraft is not very efficient. Do I have to connect the blower on my range...
The poupose of either is to eliminate any smoke created by the range or grille and move as much of the cooking odors to the outside. I wouldn't use both at the same time, but if the hood is vented to the outside, it would be just fine to use only the hood. Aregular cleaning will be necesssary. The downdraft has limits as to the distance it will efficiently exhaust air. Flex hose should not be used. And excessive bends or vent length, cuts into the efficiency.
Oct 29, 2009 | Jenn-Air JED8230 Electric Cooktop
How to get the light bulb out of a new ventahood????
Go to this website: http://www.faberonline.com/forowners.html
and go down to bulb replacement and you will see your solution. good luck and please rate my answer. thanks
Jan 15, 2009 | Kitchen Ranges
Vent-A-Hood dumping water on Cooktop
only thing i can think of would be a condensation issue. see if it is when you have a temperature change outside while it is warm in you home.
Nov 22, 2008 | Euro-Pro EPH18-236SS Vent-A-Hood Euro Pro...
Broan Allure QS2 Range Hood
Had same problem & fuse fixed it.
Before buying a new control board (approx $160), check the 3 amp fuse located on the inside of the vent on the control board. You have to take the light/bottom housing & black plastic air chute off to see control board/fuse.
Feb 21, 2008 | Broan-NuTone Allure II QS230SS Kitchen...
Light doesn't work on Kenmore Model 55022 Range hood...
If you have 120VAC on the center contact of the light socket, and a working fan, but the bulb won't light...the most likely cause would be a disconnected neutral wire (white) in the light wiring inside the hood....assuming everything else is wired correctly.
If you're comfortable with further electrical testing...let me know, and I can describe a detailed procedure to check the status of the neutral wire. Otherwise, you may need the assistance of someone familiar with electrical troubleshooting or appliance repair.
Jan 27, 2008 | Kenmore 51840 Kitchen Hood
Dacor IVS1 Vent Hood - How to change a light bulb?
Buylighting.com, JDR120V-75W-E27CG...also comes in 50 watt. They aren't inexpensive, but if installed properly, will last a while. We have a little suction cup to take them out and put them in. It came with the range hood. If you get fingerprints on a halogen bulb, it can blow out quicker.
Dec 30, 2007 | Kitchen Ranges
How do you change a halogen bulb in my dacor range hood
Believe it or not - they just unscrew like regular light bulbs. There is supposed to be a suction cup that came with the hood to replace the bulb - we lost ours. I was able to remove it by using a little bit of pressure on the face of the bulb and twisting it back and forth. The other bulb was stuck, so I made a "handle" using duct tape on the face of the bulb.
Dec 22, 2007 | Broan-NuTone Allure II QS230SS Kitchen...
Kitchen Ranges Logo
499 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
