Question about Kitchen Ranges
Burners burn too hot at lowest settings
At the lowest setting on the dial they still burn too hot to simmer food. i would like to adjust them so they would burn lower
  • gboardman99 Jan 15, 2009
    It is a Kenmore gas propane gas range, about 10 yrs old. It has pilotless ignition but burners will not go low enough to simmer things
  • Lou Cook May 11, 2010
    why type of range?gas?
    Problem Solver:
  • 5 Answers
What type of range? what type of gas? propane or natural gas? thats a start...
Posted on Jan 15, 2009
Control knob will not turn burners down
If flame is to high on low setting do the following.
Pull knob off. Look in and see a small set screw. Take a tiny standard screw driver and turn this screw in a fraction. Make sure the stem for knob does not turn I just hold it in my fingers and turn screw. Make sure you have the burner on its lowest setting and adjust while flame present to get it as K ow as you like to simmer
Jan 01, 2018 | Kitchen Ranges
The oval burner has only very low flame, even when set on high
Every one of these ranges that I have seen with the oval style burner on them have a smaller flame then the normal round burners. And there is very little difference between the low and high settings. It sounds like what you are experiencing is normal. What the GE repairman was adjusting is called the "simmer stop". There is a small flat head screw inside the burner stem. By turning this screw you can adjust the size of the burner on the low position of the burner knob. This should be adjusted to where the burner still stays on when the knob is at the lowest setting. I do not think that you need the burner repaired. From my experience they are all like that.
Mar 10, 2010 | GE Cafe CGS980S Kitchen Range
My Kenmore grill that was purchased maybe 6 weeks ago, burns all of our food in min. even on lowest setting. Sometimes the food is burnt outside but not quite dont inside.
you have a multi burner grill start out grilling direct then move to indirect to finish food turn off burners that are directly under food
Aug 03, 2009 | Kenmore 700 sq. in. Cooking Area Gas Grill...
I use one of the large burners most of the time and the minimum setting(simmer or ?) seems to have increased over last 4-5 years so that I have to turn burner off and let food cool, then turn on again,...
I am not sure of this Model but most of the Gas Rail Cocks ( Taps) when you remove the knob you will find either a small hole drilled into the spindle This would be the Low Burner (simmer Rate) Adjustment there would be a small screwdriver requiredto do this , if its not there ,then there is usually a small screw on the side of the tap under the Knob Hope this will help you
Jul 18, 2009 | GE 36 in. Profile JGP963 Stainless Steel...
GE Profile Gas Cooktop, Model JGP975SEKSS
Buy the Burners for my 36" GE Gas cooktop.
Jul 09, 2008 | Cooktops
Burner controls
if you remove the knobs from the unit nad look closely doen the shaft of the protruding valve stem you should be able to see a slot for a regular screwdriver to fit down, its gonna have to be long adn thin but that is the flame adjustment screw,
put the flame down to low and use a pair of pliers to hold the valve stem from turning as you try to adjust the screw, turn it very slowly you seel an adjustment happen (dont really know if its counter clockwise or clockwise, but youll figure it out playin gwith it for a bit, just remember to hold the shaft from turnig, and although your turninf the valve down to simmer it does not afffect the high setting
Apr 06, 2008 | Jenn-Air JDS9865BDP Stainless Steel Dual...
Gas range top burners too hot
Get the installation manual for your range, and find the part on adjusting the low heat for the burners. On my Whirlpool, I found there is an adjustment screw inside the control knob shaft of each burner. The manual says turn the burner on low, remove the knob, then turn this screw until the flames are 1/4" high. Super-easy, it took me 5 minutes to do. I am sure all ranges have similar adjustments, might be in different locations - check the manual.
Feb 05, 2008 | Kitchen Ranges
Burner doesn't simmer
Switch that controls that burner is bad and needs replacing
Nov 03, 2017 | Cooktops
Kitchen Ranges Logo
249 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
