Question about Ariens 34 In. Zoom Series Riding Mower
Ariens snowblower bearing support & model number help
I have an OLD snowblower that I need to replace the bearing support on and I would like to get some knowledge in order to do it right the first time.I am looking at the right side of the machine (standing at the operators position), it is a triangular shaped ''pot metal''/aluminum piece that bolts to the outside of the case and over the axle. I looked at it (it is cracked with a piece missing out of it) and I mentally can picture taking the tire off,but I think that I would need to pull the hub off but am unsure if the axle can or would pul off to get the support off. Also I do not know what the model number is. I got it VERY used and therefore some of the stickers are gone,how can I determine what model numer it is ? It is a very old machine ( I was told poss. early 60's?) orange body,white Techumseh engine, 4 forward speed one reverse speed,two stage, two levers on the side(one to engage the wheels and one to engage the tines), one lever on the handle(clutch). Thank you in advance for taking the time to possibly help me out..Dave
  • ddc726 Jan 27, 2009
    Hello and sorry I did not write back. I was able to get the bearing support (triangular) piece from my local "Hector's" (very knowlegable parts guy) along with the copper/brass bearings that he told me I would most likely need.
    I guess what I was trying to get from this post was a more detailed "how-to" on pulling the hubs in order to get to the bearing support. (sorry I was'nt more explicit on what I was after)
    SO to answer your question..yes it was helpful to the degree of my fuzzy explaination of my question. So thank-you for your time in replying....Dave
  • kileybrown Feb 10, 2009
    I have the same question/ problem. I have a 910995 (7hp Tecumseh). I am trying to replace the triangular bearing support and the bushing on the right side. I don't know how to remove the hub from the bearing so that I can slide the new bushing and bearing support onto the shaft. Any info would be greatly appreciated.
trippssmengi
  • 76 Answers
SOURCE: Ariens snowblower ST724 leaks gas from the carbourater
The little metal peice with the wire ataches to the float at the hinge part of the float, if you use yahoo type in tecumseh carburetor diagram then click on Parts and Diagrams and the web address is partstree.com it will show you a breakdown of a carb and how it goes together. It may not bee your exact carb but they are all pretty much the same. It also sounds like you may need to rebuild your carb. If you get it back together and it still leaks, I suggest you take it to a small engine repair shop and have them rebuild it for you only cause you need a special tool for the seat and the float will have to be set.
Posted on Dec 28, 2008
  • 11 Answers
SOURCE: Parts for Ariens Model Number FM626E
you need to get the model number from the mower body and verify that it is correct the age should not matter some hardware stores work primarily on ariens mowers hope this helps
Posted on Apr 03, 2009
panilling9
  • 284 Answers
SOURCE: PTO does not engage
if your belt was tight when you finished installing it and all the pulleys that it went around are free turning by hand and lining up reasonably well you should be ok.
to the clutch
are you good with a volt meter 12volts dc?
Find your connector close to the clutch
unhook it from the clutch
take your volt meter and engage your red knob (Have the key on and parking brake applied)check your voltage to the connector
Do you have 12volts dc?if so your clutch should work if not you need to trace the wire back to the red knob
check all of your fuses check all of your safety switches.
Or have a 12 volt source (a battery )and hook it briefly to the connector you found directly to the clutch connector pos. and neg. from your battery you should hear an audible CLICK if so your clutch is good if not you are losing 12 volts back toward the red knob
this is the best way to check the clutch while it is still on the machine.
if its the bad clutch get your wallet out they are expensive.
to remove it unlosen center bolt on the crankshaft
remove or move belt guards out of the way and whole assembly should slide right off, note any shims and spacers that may come down with it and their locations
put back the same way it came off and tighten center bolt to 55 ft.lbs.
goodluck
Posted on May 26, 2009
  • 5 Answers
SOURCE: looking for manual Arien EZR 1742
Go here:
http://www.ariens.com/corporate/pages/partsradar.aspx
Hope this helps
Posted on Jul 07, 2009
SOURCE: My 1999 Ariens EZR 1742 will not move. Cranks and
if both belts are present are they both moving? Could be tensioner froze up and it is not applying tension. mine had and i had to remove and free it up.
Posted on Sep 29, 2009
Need a carburetor for old Ariens snowblower. Number on carb is 510121 but can't find anywhere?????
Carb was probably bought in from a specialist manufacturer by the engine maker along with the ignition equipment and the maker of the snow blower in turn would have likely bought in the engines.
Few manufacturers bother making stuff for themselves when others can do it better and cheaper.
If you want it to be authentic I suggest you get in touch with Ariens with details and pictures of your snowblower and ask them if they have anyone there with a long white beard and a memory to match who could tell you where the carbs were sourced. It will be a matter of playing detective and following a line of clues.
If you aren't bothered about authenticity there are a number of generic replacement carbs that could be made to fit and jetted to suit and if it is a governed engine the governor could probably be made to fit too.
Feb 26, 2015 | Ariens Garden
How do I replace the carburetor on a 1995-98 Ariens snowblower? Very hard to get to!
No you do not need to remove the engine. How hard it is depends on which engine you have. First is it a briggs or Tecumseh. Then tell me which model, number and I will let you know.
Nov 24, 2014 | Ariens Garden
Parts not available for Ariens ST724 7hp snow blower?
As far as the bolts you should be able to match them at a small engine and lawnmower repair shop and as well if you take the old recoil they might be able to get you what you need.
Nov 10, 2014 | Garden
Parts not available for Ariens ST724 snowblower?
No you do not..you have the model number and hp should do it ..go in on your computer and just put the name,model number,hp and model in that order .or better yet go in on eBay and put that in and most likely you will find it a a reduced cost..good luck
Nov 10, 2014 | Ariens Snowblower Belt 72098, 8hp 1/2 X 37...
Want to repower an ariens model 10M6d snowblower engine. Is there a replacement engine I can use?
Go to small engine warehouse. There is an button on the top, repower old equipment. They have a few briggs & stratton engine options there.
Jan 17, 2011 | Ariens Garden
We are looking for the service manual for an Ariens snowblower Model 92001. I would like to print it from the computer.
Try printing from here. You'll need a model AND serial number
http://apache.ariens.com/cgibin/ctrg0005?SESSIONID=gsw0uz210g3q1n45lcz3mtig&site=arienss
Dec 28, 2009 | Garden
Ariens 34 In. Zoom Series Riding Mower Logo
723 people viewed this question
Top Ariens Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Paul Sikkema
Paul Sikkema
Are you an Ariens Garden Expert? Answer questions, earn points and help others
