Question about Kitchen Ranges
How to get the light bulb out of a new ventahood????
  • alimae Jan 28, 2009
    Faber Inca ventilation hood has two halogen light bulbs that need replacement. I cannot get the bulbs out. Help
  • 10,865 Answers
Go to this website: http://www.faberonline.com/forowners.html
and go down to bulb replacement and you will see your solution. good luck and please rate my answer. thanks
Posted on Feb 03, 2009
Ventahood b200msc
That would depend on what country you are in. If it is not the USA then it is most likely the voltage is 220. The products are listed here: http://ventahood.com/specifications.jsp IT appears that you dont have the right model number.
Apr 07, 2014 | Kitchen Ranges
Neff bottom oven light not working after replaced blown bulb
Hi, My Neff oven bulb was replace with a new one after the old stopped working. The new bulb lasted 4 days and stopped working, could you tell me what seem to be the problem please.
Dec 28, 2012 | Ovens
The ventahood comes on by itself and difficult to tuen off. my husband had to disconnect
those are designed to turn on automatically while cooking. my parents hood does same thing. it comes on when stowe is in use and it turns off when cooking is done. it may be normal operation. check your owners manual.
Mar 22, 2011 | Broan-NuTone Allure II QS230SS Kitchen...
Kenmore micro model 721
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week or so.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
The lights can can be inoperable or stuck on or stuck in "night light" mode. Sometimes this will similarly affect the fan operation or inside light, too.
May 13, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
How to unscrew a bulb from a new ventahood over the cooktop
DID YOU TRY TAKING THE COVER OFF. IF SO TURN THE BREAKER FOR THAT FAN THEN PAT A GLOVE ON INCASE THE BULB BREAK'S WHEN PULING UNSCREWING. MOST TIMES IT WAS EITHER SCREW IN WRONG OR JUST HAS GREASE AND RUST.
Jan 15, 2009 | Kitchen Ranges
Frigidaire over the range microwave oven has stopped heating...you set the timer and it acts like it is coming on (light and timer works, but no heating happening). the ventahood and light still...
The high voltage power supply for the magnetron, or the magnetron, or the output drive from the logic uPC board may have failed. The service tech is able to test these areas by taking readings to determine where the fault is.
Jerry G.
Apr 19, 2008 | Microwave Ovens
Microwave/ventahood, everything works but will not heat
must replace magnetron, high voltage transformer, and capacitor.
Apr 03, 2008 | Microwave Ovens
Broan Allure QS2 Range Hood
Had same problem & fuse fixed it.
Before buying a new control board (approx $160), check the 3 amp fuse located on the inside of the vent on the control board. You have to take the light/bottom housing & black plastic air chute off to see control board/fuse.
Feb 21, 2008 | Broan-NuTone Allure II QS230SS Kitchen...
Light doesn't work on Kenmore Model 55022 Range hood...
If you have 120VAC on the center contact of the light socket, and a working fan, but the bulb won't light...the most likely cause would be a disconnected neutral wire (white) in the light wiring inside the hood....assuming everything else is wired correctly.
If you're comfortable with further electrical testing...let me know, and I can describe a detailed procedure to check the status of the neutral wire. Otherwise, you may need the assistance of someone familiar with electrical troubleshooting or appliance repair.
Jan 27, 2008 | Kenmore 51840 Kitchen Hood
Kitchen Ranges Logo
510 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
