Question about NetGear WGR614 Router
The lights won't turn off
My netgear router hangs whn powered up...all the lights (1, 2, 3, 4 and the power light are lit up) except for the wifi and the tick mark are lit up and they stay like that...i was trying to reset the router to factory settings and i had pushed the reset button for like 3-4 times and over 10 seconds. It is still stuck. Please help!
    President:
  • 2,961 Answers
There is something wrong internally, i think, but if you can get into the routers settings via your browser using an rj45 cable (192.168.0.1) and enter the username and password normally admin and 1234 or admin and admin, and look for reset in the menu or restart router. If you are able also look under your router for the firmware version or it can be found somewhere within the settings menu and go to the netgear website and see if there are any firmware updates. If there are you will have to install it following the instructions and probably have to do a factory reset to initiate the firmware, if still having the same problem the hardware itself may be faulty.
Posted on Jun 15, 2007
SOURCE:
I have a Netgear WNR2000 v4 router. We recently had a power outage.Power came back on in 5 seconds.The cable modem is fine,however the router ONLY shows me a solid green light for power, nothing else.
I would just do the reset, this should allow you to access at factory defaults. (I hold button in for 10 sec).
A solid green (power?) light is good
LAN ports should only light if connected
WiFi port should light if set to active
Mar 02, 2015 | NetGear Computers & Internet
My Linksys E2500 router won't fully power up. The lights are dimly lit.
Start to change:
1-Charger / Cable then;
2-Test; no luck?
3-Device is dead
Apr 12, 2013 | Computers & Internet
Wifi stopped working
power cycle. if it still doesn't work then reset to factory defaults and set back up again from scratch.
Aug 09, 2012 | NetGear RangeMax NEXT WNR834B Wireless...
My wifi light won't turn on and i have no wireless connection
you need to configure the wireless settings
connect to your router using a cable and then go to your browser to 192.168.1.1
go to wireless and setup your wireless network settings
Feb 26, 2012 | NetGear MR814 Wireless Router
DG834g v3 Router continuously rebooting
1. Reset the router to factory settings.
- Before you reset the router, unplug all the cables attached to it except the power cord.
- Make sure the router is plugged into the power outlet, then hold down the reset button at the back of the router for 30 seconds using a paper clip or a pen. You should see the lights flicker momentarily on the front panel of the router. //
2. Once the lights are stable, connect 1 computer or laptop directly to the back of the router(Ethernet/LAN ports usually they are labelled by numbers and have the same color, just pick one).
- If you pick number 1, check the corresponding light indicator at the front panel of the router, make sure light 1 is also lit up if not choose another port at the back of the router. //
3. Access the router's setup page by typing http://192.168.0.1 orhttp://www.routerlogin.com/basicsetting.htm in the address field of your browser and then press Enter. Type admin for the router user name and your password (or the default, password). Setup and configure the router again.
Nov 01, 2011 | NetGear DG834G Router
I bought a netgear jwnr 2000 yesterday and tried to set it up at my sisters house for her, so i could take the other netgear router with me. It didnt work. The only indicating lights that were working...
router(LAN ports usually they are labeled by numbers and have the same color, just pick one).
3. access the router's setup page by typing http://www.routerlogin.net or 192.168.1.1 in the
4. If you notice the connection is not stable or the lights on the router are still not
displaying correctly, you may update or reload the same firmware(program or software) on the
router. You may download the updated firmware from http://support.netgear.com , just type the
model of your router, choose the version, press enter then click on Downloads, you should see
the firmware available for your router. Make sure to use wired connection when updating the
firmware.
Sep 18, 2011 | NetGear WNR2000 Wireless Router
Hiee I am using netgear N300 jwnr2000 router. The router worked fine for few days it has suddenly stooped working.Any of my wierless devices are not able to detect my router since the wifi in been...
Unplug both your DSL/Cable Modem, and the Router from power. Wait 30 seconds. Plug in power to DSL/Cable Modem only, and wait for it to connect. then plug in power to Router, and wait for it to start up. Give it about 1 min. If the lights are still not on, you may need to reconfigure your router. If this does not work, connect your cable/DSL modem to your computer directly, and power cycle it again. Once it is online, check to see if you can get online, if you cannot, contact your internet service provider, as you have ruled out a problem with the router.
Dec 28, 2010 | NetGear WNR2000 Wireless Router
Can you tell me if all of the four numbers should be lit up to reflect the Netgear WGR614 is working? My internet connection suddenly quit and I just noticed that on the number "1" is lit.
On a router, the numbers light up only if there is an active computer plugged in to that port. One computer plugged into port 1 the number 1 wil light, and same with 2, 3, 4. No device plugged in to port = no light. Different color lights with different data rates.
Nov 05, 2009 | NetGear WGR614 Router
Router will not work only the power light is lit up
1. physical connections
2. hard reset
3. check ip. (if 169, assign static ip)
4. assign static ip
5. ping router (if getting replies, access webui, reload firmware. if not getting replies, the router may already be faulty, advise to phone netgear)
Jul 09, 2009 | NetGear WGR614 Wireless Router
NetGear WGR614 Router Logo
107 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Mike
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
