Question about Rockford Fosgate Punch P4002 Car Audio Amplifier
Rockford Fosgate P4002
Left channel problem, the speaker when hooked up, peaked to full excursion. amp turns on just fine and right channel works great. Possible output transistors shorted?
  • 4 more comments
  • mike sanson Jun 15, 2007
    It stays at full excursion as well!! might burn speaker if leaved it hooked up.
    do I just replace the damaged transistors, pull and test all of them, or is there another problem in the circuit?
  • mike sanson Jun 17, 2007
    Does anyone know of a replacement transisitor for this amp, the part number isnt crossable with NTE
    The # is
    Q220
    BO347
    FQA
    46N15
    what do you suggest, replacing both , and is there a cross for these?
    that is a power transistor
    Its a QFET (same thing) is there a replacement?
    President:
  • 3,130 Answers
Yes they are ! And that means the DC is on the speaker and will for sure damage the speaker if it already hasent
Posted on Jun 15, 2007
  • 1 more comment
  • Larry  Dillon
    Larry Dillon Jun 17, 2007
    You should NEVER ever use a replacement transistor on a power amp! these amps are designed to work in harmoney with the output transistors!
  • Larry  Dillon
    Probably a MosFET
  • Larry  Dillon
    Larry Dillon Jun 18, 2007
    Nope, i would not recomend it. Contact the manufacturer
Repair t7512
Hi, Make sure the connection are correct + to+ and - to -.
Also make the same connection to your amp + to + and - to -.
Make sure that your amp can run the subs, wattage and ohms.
Hope that helps.
Jan 21, 2014 | Rockford Fosgate T212D4 Car Subwoofer
How many peak watts is a rockford fosgate p500/2 amp...i belive it is the last gen...the one with the silver cover plates...thank u
Hello
Rockford Fosgate P500-2 is capable of delivering 125Watts to 2 channels @ of 4 Ohms speakers, and 250Watts to 2 channels @ of 2 Ohms speakers.
Dec 29, 2011 | Rockford Fosgate Car Audio & Video
How can I bridge my Rockford fosgate t1500-1bd
if ur amp has to channels then u hook up the + to the right side of the amp an the - up to the other side of the amp , make shore u turn down ur amp if u do so
Jul 12, 2011 | Rockford Fosgate T15001BDCP Car Amp
How do I hook up one sub to my rockford fosgate p3001 amp
Hey i have looked over many rockford manuals,(i own a 300.1 my buddy owns a 325.1) and for there mono(.1) amps there hooked together on the inside so channel A+ and B + are cencted on the inside the amp. So you ither hook one 2ohm sub to channel A or you can hook 1 4ohm subs to channel A and 1 4ohm sub to channel B. There 2ohm stable so any lower will eventualy burn the amp out.
Jan 08, 2010 | Rockford Fosgate P3001 Car Audio Amplifier
Amp powers up. the right channel works fine left not at all
If you didn't find any burned parts that would mean one of the buffer amplifiers before the power amp could have died. They could either be transistor based or opamp based. They are fairly low power so they will not explode like the output transistors like to do. Contact rockford, they should be able to send you a schematic. Let me know I will try to help you through it.
Dec 14, 2009 | Rockford Fosgate Punch 401S Car Audio...
I installed a sony 600watt amp and it works but old rockford fosgate 200 hit harder how do i make my amp louder and evenly spread throughout my car
Hello jmanbutt99,
The old Rockford-Fosgate was probably producing the rated power. The Sony is most likely overrated. But, it's supposed to be stable on each individual channel down to 2 ohms and will deliver 65 watts RMS into that load. So to get the most from it, your best bet would be a pair of 4 ohm speakers paralleled to each channel. A relatively efficient speaker like the Kicker 07DS600's shown here should provide pretty good sound.
http://www.crutchfield.com/p_20607DS60/Kicker-07DS600.html?tp=105
These will work with as little as 6 watts RMS and can handle up to 50 watts RMS so the Sony should power them really well. They're 4 ohm so a pair in parallel will present a 2 ohm load.
Hope this helps
Oct 30, 2009 | Sony Xplod XM-554ZR Car Audio Amplifier
Connect rockford fosgate amplifier & speaker together
Assuming your P3 has a single voice coil (it will have only one place to plug your wires into) you will be running this in a bridged mode. You will take the left (+) coming off the amp and plug it into the (+) on the P3. Then take the right (+) from the amp and plug it into the (-) on the P3. This will make your amp push 500 watts to your sub. Now on the amp make sure your adjustments are as follows: Signal input switch is set to unbalanced for RCA input. Left Phase switch is set to 0. Right phase switch is set to 180. your X-card should be set to low pass. And adjust the gain for both R and L equally so it has equal power from both channels.
Aug 09, 2009 | Rockford Fosgate Punch 401S Car Audio...
Amps that work with 10" RFZ2410
well how manny amps can the sub hold? any amp will work you can bridge it to doulbe the power but i would say a 200 wat amp would do you good
Aug 02, 2009 | Rockford Fosgate RFZ2410 Car Subwoofer
Rockford fosgate 800 a2 amp power?
Hello desperate2le,
Watts delivered is a function of the voltage times the current. If the amp was 100 percent efficient, it would need 33 amps at 12V for 400 watts. At 14.4V, it would only need 28 amps. Of course, amplifiers are NOT 100 percent efficient, only about 50-60 percent in many cases, but somewhat higher for monoblocks, maybe 80-90 percent. So you're looking at a fuse in the 60-80A range. In the absense of a specific fuse size from the manufacturer, I'd start the primary fuse at a 60A and if the amp blows it on power up/immediately/frequently, move up to an 80A.
All of the Rockford-Fosgate 2-channel bridgeables I've ever seen show using the left positive (+) and the right negative (-) for bridging. But if it's not shown right on the amp, I'd call or email RF for the correct connection. The new amps do show it.
Hope this helps.
Apr 27, 2009 | Rockford Fosgate Punch 800a2 Car Audio...
Rockford 750X
Check your wiring, and if everything is fine you might have a blown or broken channel on your amp
May 22, 2007 | Rockford Fosgate Power 750X Car Audio...
Rockford Fosgate Punch P4002 Car Audio Amplifier Logo
278 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
seankane89
Level 1 Expert
hoyzee1
Robert Rankin
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
