Hi ,My Acer Aspire 5315 Screen Keep Go Black When I Move Laptop Or knocking Him , Note That I Can Get light Back Opening Task Manager , This Problem Happened With Me After I Removed My 1 GB Ram And The Hard Disk And Battery And Putted Them Back , And I Tried To Put Them Again That It May From Them ,:) Thanks
SOURCE: How to change add RAM to Acer Aspire
open one say r on it bigger squeare smaller chip in there read what it says buy that in 1gb ext sodimm labtop ram in pc266 mhz speed ect 2 gb max on yours ok 1 gb max per slot
SOURCE: black screen with cursor acer aspire 5315
start your laptop in a safe mode by pressing f8 during booting, the restore your system to a back date where its working fine
SOURCE: erecovery acer 5315
You can "try" to stop the process from starting by unchecking the appropriate box under boot menu.
go to RUN, type MSCONFIG, check the startup tab.
Hope this helps.
SOURCE: hi i have an acer aspire 5315-2326 laptop and i
Dear Sir According to your problem regarding RAM upgradation issue,here is the solution
Acer Aspire 5315-2326 laptop comes with following RAM specification
According to you your laptop already had 1gb RAM,so you can buy another 1GB RAM of DDR2 SDRAM - 667.0 MHz,only if your Laptop had two RAM slots.If it had only one RAM slot you have to purchase 2GB DDR2 SDRAM(frequency may differ). And also your laptop cant support more than 2gb RAM.
I think it deffinately solves your problem
good luck
SOURCE: acer aspire 9300 notebook black screen while in use
If there is power beside you,why not connect you laptop to the family power,it will be good to your acer aspire 9300 battery life .Pay attention to your acer aspire 9300 laptop have been 2 years old,i think it most properly some problem to your acer aspire 9300 battery.
