Question about Home
I have a garden tub / jacuzzi in my master bath. I never have used it. I assumed the 3rd switch down on my bathroom light panel controlled the jets. Come to find out the 3rd switch isn't connected to anything. What should I do?
  • Thomas F. Schneider May 11, 2010
    If you are talking about using it to control the pumb and the pumb is laread wired,just break the black wire from the source GFIC, to one side of the switch, then another black wire from the switch to the pump. The white wire goes from the source to the pump as does the green. I am hoping this is what you were asking?
  • 125 Answers
Is there a logo on the tub? Some Mfg use the logo as a touch pad. You should try this. Fill the tub with water, get in it and touch the logo. It should turn on.
Posted on Feb 24, 2009
My new jacuzzi 6 jet tub is only working on one side. What could cause that?
Probably control panel or if there are separate pumps for each side, that side's pump probably doesn't have a relay working with bad switch from the control panel.
Mar 31, 2015 | Whirlpool Jacuzzi Bath Tub with Jets
Leaking jacuzzi jet
The workings of a bath jet...From the inside of the Bath there is a wall fitting that threads from the inside of the tub into the jet body located on the outside wall of the tub.
If the jet is leaking at this point behind the tub then you should take the wall fitting out of the tub and put a small bead of 100% RTV silicone around the flange of the wall fitting and reinstall it.
If however, the leak is from the PVC piping going into the jet then you will need to replace the jet.
Rod
US Parts Center
888-521-6183
Jan 14, 2013 | Kohler Home
Our jacuzzi tub is 20 hrs old and possibly is leaking. About 6 mths ago we remodeled bathroom &replaced all tile around tub & shower. We do not want to tear out tile. What would be best way to pin...
if you have a water stain on the ceiling below your tub then you have a water leak. There is no easy solution for this. You must get to the underside of the tub in order to watch the jets when the tub is full of water to isolate the leak and then have it repaired by a plumber.
Aug 15, 2011 | Jacuzzi Home
NOTHING TURNS ON, PLUG IS OK SAID ELECTRICAN
If you have plugged the tub into another outlet and the jets work fine, it is not a control module problem. The tub should be plugged into a gfci outlet. If it is, there may be a reset switch on the plug it is plugged into, or there may be a switch somewhere else in your bathroom that has the reset switch on it. You can buy a tester for about $3 or $4 that plugs into your outlet to test if it has power. Hope this helps.
Nov 19, 2009 | Jacuzzi EH85-959 Real Whirlpool Bath 6...
Jacuzzi outdoor bath tub i have there is power but the bubbles thing isnt working
Find the plug for the pump and plug it in ( tub full of water), if the pump works,the problem is in the contol box or switch. if the pump/motor has a plastic tube coming out of a black box, and the pump still does not work when plugged in, it is most likely the air switch connected to that plastic tube on the pump. the switch is avaliable online and not to hard to replace if you are mechanically inclined.
Sep 26, 2009 | Whirlpool 5"x36" White Bathroom Drop-in ...
Jacuzzi whirlpool hot tub, flashes Fl-1 has new filters,
Sounds like a bad heating element. This is located in a stainless steel tube under or around the main control box behind the cover around the tub. It is not hard to replace but should be done by a pro. The part is avaliable online.
Sep 24, 2009 | Jacuzzi Bath Nova H530 917 Black Soaking...
I know I can take a bath without turning on the jets. However; does the bath water with soap flow back into the jets? I like bubble baths, If I leave the jets off can I use the bubble bath without having...
The soapy water will fill all of the jets, tubes and the pump assembly. Will it hurt the tub if the jets are not running? The soap film will build up in the jets, tubes and pump assembly and can possibly cause damage if the tub is run at a later date. Contact the tub manufacture and see if there is a safe bubble bath you can use.
Aug 23, 2009 | Jacuzzi - Bathtub - Alcove - Navona -...
Want switch on
want switch on WHAT? need more details, type of switch is it digital, air or vacuum ETC.. switch to light ,switch to jets or switch to jet flow????????? Its there a wall switch on wall of bath room or gfi breaker for tub?????
Jul 08, 2009 | Jacuzzi Home
Home Logo
145 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
