Question about Dewalt DC900KL Heavy - Duty 36 - Volt Cordless 0.5" Hammerdrill/Drill/Driver Kit
Not spinning pull the trigger and will spin for a second and stop, then a few seconds later will spin again and stop. Battery is fully charged.
    Problem Solver:
  • 8 Answers
Had the same problem figured out it was a wiring problem with the trigger, works good now.
Posted on Feb 04, 2009
My kenmore stick vaccum model. 116.36025510C stops after a few seconds and the light is blinking. This is after it indicates it has been fully charged
It sounds like the battery is no good, even if it shows full charge that doesn't preclude a defective battery.
Dec 01, 2016 | Computers & Internet
Peg pergo John Deere Gator goes for about 2 seconds then stops suddenly
it almost sounds like a thermal fuse, but these don't have a thermal fuse, so id say it might be a bad shifter switch
Dec 28, 2013 | Peg Perego John Deere Gator HPX Ride on...
The engine acts like it wants to turn over, but after a few seconds you can hear what sounds like a skate board wheel spinning. On some attempts, it just makes the spinning sound. Thanks
Check to see if the battery is FULLY CHARGED! If it isn't, theree will not be enough electric power to move the starter solenoid all the way into the flywheel gear. If you have a spare FULLY CHARGED battery use it to test or put a charger on the one you have and boost it! By the way, when did you replace the battery, or check it's water level last?
Jan 02, 2013 | Cars & Trucks
Pressing power button results in power light and hard disk light coming on for a couple of seconds cpu fan spins for same length of time then fan stops lights go off few seconds later lights come back fan...
it seems that you have damage memory card replacing may fix a problem but its better for it that you bring it to a technician in order to check much better because the motehrboard may possible be the problem.
Jun 30, 2011 | Acer Aspire 4315 Notebook
The problem of intermittent firing began some time ago. Now the gun will not fire at all. The gas bottle is full and the battery is fully charged. I disassembled and cleaned the gun. It subsequently fired...
what is the expiration date on the bottom of the fuel cell?? Also what were the condition of the o rings and did you relube with a good quallity oil. What I would do is remove the front assembly to expose the fan only and then insert a battery, pull the trigger and the fan should run for a few seconds, next there is a roller lever towards the top, depress it keeping fingers away from fan and again it should run for a few seconds, next depress and hold the lever and then pull the trigger and you should see it fire, repeat this several times, that will narrow it down to the spark unit/electronic assenbly or the cylinder.
Jan 09, 2011 | RTO PasLode 900420 Impulse Framing Nailer
My fully charged Roomba 560 just moves a few inches, cleans spins in a circle then stops and a red exclamation point appears. (I've misplaced the manual help !
You have dead nimh (nickle metal hydride) batteries
You will need a replacement. You can test for this by removing the battery and holding the power button for 15 seconds. This will restart the charging cycle as if the battery were new.
Feb 26, 2010 | iRobot Roomba 560 Robotic Vacuum
Turbo pro wheelie cycle from mattel
take it back to the store & get a replacement!!!
Aug 14, 2009 | Toys
Roomba cuts off after a minute or so.
If you have a 400 series Roomba, try removing the battery, then holding down the power button for ten seconds, then recharging the unit before you run it again.
If you have a 500 series Roomba, don't take out the battery-- just press and hold the "spot" and "dock" buttons for about fifteen seconds. The Roomba will play a tune, and you can then charge it and try running it again later.
May 13, 2009 | iRobot 4150 Roomba Vacuum
Rainbow SE power nozzle
If the brush is spinning ok, and the belt isn't slipping, then probably the circuit breaker is bad, or the motor is causing the problem.
Oct 23, 2007 | Rainbow 75th Anniversary Canister Vacuum
Dewalt DC900KL Heavy - Duty 36 - Volt Cordless 0.5" Hammerdrill/Drill/Driver Kit Logo
388 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
