The 4-digit error code consisting of an alphabet and numbers, which blinks at 3.2 Hz is dislayed on the screen when any problems occur. This 5-character display indicates the "repaired by:", "block" in which the problem occurred, and "detailed code" of the problem.
The error code C:31:22 and C:31:23 indicates T reel fault and S reel fault respectively. Load the tape again, and perform operations from the beginning.
The error code C:31:40 indicates FG fault when starting drum. Load the tape again, and perform operations from the beginning.
Furthermore, press and hold the power button for 30 seconds then try using the Camcorder.
error 91-1E5 is "communication error between system control and DIF microprocessor". look for a loose ribbon cable internally, although component failure is a possibility.
