Motorola TalkAbout T5530 2-Way Radio Logo
Anonymous Posted on Dec 18, 2012
My Motorolla Talkabout T5530 will not transmit sound when I press PTT button. Also when PTT is pressed, all the displays come on, why? How do I get radio to function back to normal?
Anonymous
Level 2:
Prodigy:
An expert who has answered 500 questions.
  • Expert 607 Answers
  • Posted on Mar 06, 2013
Anonymous
Expert
Level 2:
Prodigy:
Answers
607
Questions
Helped
143849
Points
645
Yes it is a Motorola, no it is not made in Malaysia, USA or UK, but mass produced in China under license, and there my friend lies the problem.
From personal and from the many others who've posted on this forum re: Chinese made radios, they are ****, and a waste of money.
Very little info available, and what is available is written in CHINGLISH, which is a mongrel to understand.
Spend little, get little....
Spend more, get more...
That's what I did and still do on ebay, for a trusted brand from $150.00 upwards, you will be doing yourself a favour, stay clear of any radio equipment made in China, it's rubbish.
Cheers,
Peter
5 Related Answers
Anonymous
  • 123 Answers
  • Posted on Feb 14, 2008
SOURCE: One way comm only
swap batteries if does not work this unit should need repair or replace, display blinking can be produced for power failure ( battery, contacts, circuits) or can be a controller issue.
Anonymous
  • 250 Answers
  • Posted on Apr 07, 2008
SOURCE: Will a Motorola TalkAbout T5320 transmit to a Motorola TalkAbout T5530?
Hello Blindmaster,
Check the Continuous Tone Coded Squelch (CTCSS) settings on all the radios. (Note that some manufacturers refer to this feature as a “Privacy Code” or “Quiet Code.” The actual name of the feature may vary.) This feature encodes a low-frequency signal on your radio transmission. This signal is below the range of human hearing but can be detected by other radios. When the CTCSS feature is active your radio will ignore any signal that it receives that does not have the proper tone encoded on it.
In order for these radios to communicate, all of the radios need to be on the same channel and have the same CTCSS code programmed or the CTCSS feature must be disabled.
I suspect that CTCSS is activated on your T5530s but is not enabled on your T5320. This would result in the situation you describe.
Also take note that when using different brands / models of radios to communicate with one another that the CTCSS code numbering scheme may not necessarily be the same from radio to radio. For instance, CTCSS code “4” on the Motorola TalkAbout series actually corresponds to code “A” on the Motorola Sport models.
Best Regards,
Agent Ken
Go Ahead. Use Us.
Anonymous
  • Posted on Aug 18, 2008
SOURCE: Talkabout Motorola T5530
I found the T5000 manual here (It covers the T5000, T5500, T5530 and T5550)
http://www.giantintl.com/RadioPDFs/manuals/T5000.pdf
Semper Fi,
Jstwhln
Anonymous
  • Posted on Dec 31, 2008
SOURCE: Motorola Talkabout Basic
I believe you do not need to hold the monitor button when changing channels
Push the talk button till you have the channel you want then push monitor button to accept
Hope this works
eradiostore
eradiostore
  • 1672 Answers
  • Posted on Aug 07, 2009
SOURCE: cant reset my motorola talkabout t5000
Constant static can be a sign of a bad or low battery. If the battery is known to be good, try the radios outside the factory setting to see if the problem persists. If you have no problem when you are away from the machinery, you may need to set your interference eliminator code to a number other than zero. This will turn your eliminator ON, which will block out the radio frequency interference caused by the machines.
If the problem persists outside of the factory, then you should try replacing the batteries. OR possibly just cleaning the battery contacts with a pencil eraser.
The method you are using for resetting the radio will take the radio back to the factory default settings. It will not solve the problems listed above. It will only reset the frequency and code back to the original settings.
1helpful
I ptt and it immediatley 'roger beeps'
Beeping when you press the PTT button usually indicates a bad or weak battery. Check your batteries and charger. Clean contacts with a pencil eraser.
If you feel this is not the problem, then you have a radio problem. These radios are non-repairable, as parts and schematics were never released for them.
Best regards.
10helpful
I need a manual for a T5530
hey buddy follow this link and u will find a manual for all these devices from motorolla which are "T5000,T5500,T5530,T5550"
plz rate me as best as i must deserve
My T5530 don't transmit audio to another radio, you can hear the.
good am, if no audio, try to check the microphone if its ok? , if not, just change, if its ok, try the PTT maybe the switch is busted or need cleaning, most cases is the need to clean due to dust and moisture. just spray contact cleaning fluid. - DU7UV
1helpful
Motorola T5100 Radio
Setting and Transmitting Call Tones
Your radio can transmit different call tones to other radios in your group so you can alert them that you want to talk.
To set a call tone:
1. With the radio on, press MENU 3 times. The current call tone setting flashes and displays.
2. Press + or - to change and hear the call tone.
3. Press MENU or PTT to set the new call tone or turn feature off.
http://www.motorola.com/mdirect/manuals/T50-T55_UserGuide.pdf
Ring tone thingy
To set a call tone:
One way comm only
2helpful
4answers
Muting the sound
The sound produced by a Motorola radio when the mike is keyed refers to the "Transmitting Call Tone" which is another feature other than the "Interference Eliminator" or the "Roger Beep" feature.
On most Motorola GMRS/FRS TalkAbout radios, setting the "Call Tone" to 0 disables the feature. This is done with the radio ON by pressing on the "Menu" button 3 times which will result in the display showing the current Call Tone setting (flashing) and the letters CA; pressing on the <- or +> buttons will change selection (you will also hear the different Tones), select 0 (it may be up to 5 or 10 depending on the version). Press on the "Menu" or "PTT" button to set, save and exit.
Hope that this be of some help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Motorola Talkabout T6500 will not transmit.
Are you sure the batteries are ok?, try to change the batery, check the radio battery contacts, verify if when you press the ptt, appear an icon on the display that correspond to TX function. Try to use an audio accesory to TX, if all this fail, you should replace it. Good luck
Top Motorola Radio Communications Experts
eradiostore
eradiostore
ZJ Limited
ZJ Limited
ExpressFiX
ExpressFiX
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
