Question about Linksys Wireless-G WRT54G Router
Linksys Wireless Router Stopped working
My wireless network is not working. I was on-line last Thursday and at some point my internet connection got disconnected. I haven't been able to get back on since. (At some point, the switch for the wirelss got flipped -- not sure how -- but it's connected now.)
I've tried , unplugging, waiting and plugging the device back in, pushing the reset button and re-installing the software -- but nothing is working.
I'm not sure what to do to get the connection back.
    Problem Solver:
  • 17 Answers
Try holding the reset button for 10 seconds, while holding the reset button in, unplug it for 10 seconds, plug it back in, but don't let go of the reset button for another 10 seconds. Respond with any results.
Posted on Jan 16, 2009
Cant get the Linksys to find the Optus DSL network
do you have security enabled on the wireless router?
if so, disable to security and see if you can connect.
if it works, check if you set the router security to use WPA2- it is possible that your laptop/wireless card doesn't support it- try to use WPA instead
Aug 02, 2009 | Linksys Wireless-G WET54G 802.11g/b...
Linksys wireless-g wmp54g cannot access internet
Hii
Solution- For windows XP
#1--On your computer in the right lower corner you will a green icon for linksys adaptor --
Right click on linksys icon- select option "use windows wireless configurastion --- Select Yes ---
Green box turn Grey --
#2-- Start - Control Panel-Network Connections ---
Rigfht Click on wireless network connection- Selct View Available wireless network - Here you can see your network --
Mar 29, 2009 | Linksys Wireless-G WMP54G 802.11g/b
Have wireless connection, but can't get online
Linksys wireless router has many bugs: connection issues like no connection or constantly having to reset the router. It isn't compatible with many network adapters. Hope this helps!
Jan 25, 2009 | Linksys BEFW11S4 Wireless-B Broadband...
Can not get the second laptop on the internet with the wireless
The post says he has a router "linksys wireless-g access point router" ???
If it is only an Access Point then Joed is correct you need the router to access your broadband with more then 1 PC
If you have a wireless access router then here are the instructions:-
Easy Solution (you should be so lucky)
Sometimes the value for the Wireless Key is written on the underneath of the router, look for SSID (this is the network name) and WEP or WPA key (called the encryption key)
Alternative Method
In order to find out your Wireless Network Key you must first use a cable to connect to your router.
Once connected check that you are connected to the internet by opening Internet Explorer
The address or the router is usually one of the following values:-
http://192.168.0.1
http://192.168.1.1
http://10.10.0.2
http://192.168.2.1
http://192.168.2.254
Try clicking on each and see if you get a logon box popping up
If you do, that is the correct address for your Wireless router, note it down.
If the box has the username and password completed, then click OK
If there is no value for username try "admin" and for the password try one of the following "password", "admin",
Also try nothing for the username and "admin" for the password
Sometimes the value for these are written on the underneath of the router
Once the router page is displayed, look for an item called Wireless Settings.
Next see if a further option for Wireless Security exists.
The names of these items vary from Router to Router
Once security is displayed the SSID (Network Names) and the WPA or WEP Key can be found.
If there is no security I would set it to WPA or WEP then the original computer connecting will need this value if it is connecting wirelessly
Dec 26, 2008 | Linksys Wireless-G Broadband Router
Going wireless with a T1 Line
Going wireless should not be influenced by the nature of your internet connection. Here, I will assume that your definition of "standard router" is the kind of router we can buy at any electronic store (DLink, Linksys). I you are think more about a high end router such as a Cisco 2600 or 2800, please post a comment and I will adjust my answer.
If you already have internet access through your T1 using a wired network, you may just add one (or more) Wireless Access Points to your existing network. No need for a router here since you already have one for connecting the wired network.
On the other side, if your T1 line will be dedicated to your Wireless access, then a router should do the job. Usualy a T1 line uses a static IP address on the WAN side. If your Wireless coverage required more than one Access Points, then I would suggest you to use a standard router (no Wifi) with seperate access points.
Apr 20, 2008 | Computers & Internet
Wireless-G LinkSys Model WAP54G random Internet Access
i think the problem is that when there are a number of pc's sharing the same wireless network the bandwith has to be shared and can be with upto 255 pc's. Connecting 255 computers to a single WiFi access point, while theoretically possible, is not recommended. Performance of such a network will be very poor. Install multiple access points instead to distribute the network load. By adding more access points to the network, effectively any number of computers can be supported (though the network becomes progressively more difficult to manage). On a home network, while dozens of computers and other devices may connect to the router, the performance of a shared Internet connection will quickly degrade as more computers access the Web simultaneously.
Sep 10, 2007 | Computers & Internet
Linksys WAP11 Wireless-B (802.11b) Access Point
you have to go into the routers settings, by typing it's ip address (refer to manual) in your internet browser and look for DHCP and make sure that it is enabled to automatically assign both your pcs an ip address. This must be done using a lan RJ45 cable that was supplied; first before going wireless. Next go to each pc and either use the wireless network setup wizard or go to your wireless network connections (in control panel>network connections) and right click on the connection(this is not the lan connection icon, make sure you choose your wireless icon) and select properties, then click the internet protocol line TCP/IP and again click properties. make sure that 'Obtain IP address automatically is ticked and click ok. Your pcs may need a restart and should find the router will be seen in your found connections, click connect and your away
Aug 10, 2007 | Linksys Instant 802.11b Wireless Network...
Linksys Wireless-G WRT54G Router Logo
63 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
