Question about Sony Handycam CCD-TRV37 Camcorder
Eject is flashing with fast beeps. Won't eject tape or open compartment.
I get C32:11 error and eject is flashing with fast beeps. Can't get the tape tray to open, won't record, playback, rewind, etc. Tried the Sony troubleshooting guides of resetting the power, and took battery out to dry out camera. All didn't work. When I put battery in and turn on, it makes a humming noise like it's going to eject but nothing happens.
  • jesjaden Nov 02, 2008
    I am having the same problem with my camera, it's a couple of months old. I hear it but does not eject tape.
    If its the timing gearr, is this warranty?
    model: dcr-hc52/hc54
    Thanks in advance for your expertise. j
  • 169 Answers
Sad to say that the problem of your camera is the timing gear is already damage....it need to disassembly the camera to fix the timing gear....go to the qualified service center for fixing or replacing the timing gear..
Posted on Aug 21, 2007
Cassette jammed after camera dropped
I think your ejecter motor is not working.temporarily open with any tool.
Dec 10, 2008 | Sony Handycam CCD-TRV107E Camcorder
Tape will not eject / Battery full
while the eject process is trying to happen remove the battery and replace it. keep initiating the eject process and removing the battery and it should finally eject. If you attempt to use the camera again put in a new tape so you don't lose a tape that contains footage you may want to save.
Dec 07, 2008 | Canon ZR100 Mini DV Digital Camcorder
Eject Error
Does your camera make a buzzing sound as if it trying to eject? Or if you listen carefully can you hear the very faint sound of a motor free-spinning? I have just repaired a friends camera of a very similar model to yours with the same problem. There is a tiny motor in the tape compartment which comes loose from its "pathetic" mounting. This causes the gears to disengage and in turn renders the eject mechanism useless. The motor is in the bottom left hand corner (looking in as if loading a tape) right underneath the Player, off, camera selector. The motor simply needs to be repositioned to engage the gears. I then added some glue to stop it happening again (be extremely careful though as ANY overspill of glue will ruin the camera completely).
Aug 15, 2008 | Sony Handycam DCR-HC42 Mini DV Digital...
Tape will not eject
If you open the eject thingy like normal then look for a small white plastic tap. its located right underneath the "start/stop" text you see on the back end of the camera (where the record-button is). You´ll need something like a small screwdriver or similar. Press it and and the tape ejects like normal. Worked for me. Saved me the repair bill :)
Jul 22, 2008 | Sony Handycam DCR-HC40 Mini DV Digital...
Sony Handycam DCR-TRV19E Pal do not eject tape
I think, your camera requires new DV Mechanism replacement.
May 08, 2008 | Sony Handycam DCR-TRV33 Mini DV Digital...
Cannot eject VHS tape from Sony SLV-X811
I had a similar problem with a Panasonic VCR. It would not eject the tape and gave an error code. I found that the door does not quite fully open, so that the top of the tape hits the door and cannot eject. If I turn off and then turn on the VCR the error code disappears. Then I press the eject button and simultaneously hold the door fully open with one finger until the tape starts to eject and clears the door.
Feb 29, 2008 | Televison & Video
Tape compartment won't open
eject the tape by disconnecting the power adaptor and removing the battery. After waiting a short time and then replacing the battery, the tape would eject.
Dec 07, 2007 | Sony Handycam DCR-TRV17 Mini DV Digital...
CAMCORDER GR-DVL167EK
YOUR TAPE MAY BE DAMAGED IF YOU TRY TO OPEN THE CAMCORDER - HOLD EJECT BUTTON DOWN BEFORE ! YOU REATTACH BATTERY THEN READ THE ERROR CODE ? IF IT STILL DOES NOT EJECT .
Sep 10, 2007 | Video Cameras
Sony Handycam CCD-TRV37 Camcorder Logo
676 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
