Question about Quasar SP-2725 27" TV
After TV warm, picture and sound go out.
We acquired an older standard type Toshiba TV that the kids use for Wii. It seems to have problems after it warms up. The screen goes black. There is also no sound when the screen goes black. The picture (along with the sound) often comes back when you hit the TV. It seems to be getting worse. Is there an easy, inexpensive fix we can try?
  • c_parendo Jan 15, 2009
    Thanks for the thorough response. The fix makes sense. I will try it this weekend when I have more time.
  • Quasar Master
  • 5,568 Answers
This could be due to what we techs call a 'cold solder joint.' The mere fact that temperature and whacking the set seems to help, reinforces this diagnosis.
There are a number of points on the circuit board that get quite hot and solder joints can fail from metal fatigue; the swelling and shrinking of the joint until the copper leads and solder (tin/lead) separate.
To inspect the main board, please pull the plug from the AC and let the unit sit overnight to eliminate the chance of a nasty shock, then remove the back (~6-10 screws).
If you have a digital camera make a couple of pix of the guts from different angles unless you trust your memory, then pull plugs from the board (marking them in some way is best).
The heavy-looking lead attached to the picture tube (CRT) has a spring clip that needs to be compressed from the side to free it, otherwise the various cables can be removed by unplugging.
You should have a quality soldering iron for this, NO GUN! These are too hot and may cause the traces on the PC board to lift. The soldering tool needn't cost a hundred bucks but should be designed for electronics work, preferably with an iron-plated copper tip; these stay clean better and are easier to tin. The solder should be some designed for electronics use (no acid!) and with a rosin core that serves to clean the surfaces to solder. In the same place, pick up some 'solder wick' or if they have cheap solder suckers, any of these should be good enough unless you are planning on doing this for a living. The total cost will be under ~ $20 US.
You should have a cellulose sponge, wetted and wrung out so you can often clean (wipe briefly) the tip and put fresh solder on it.
Now you are kinda prepared (40+ years experience is better) to look for solder joints on the underside of the board. If a joint, especially a larger one (they are more sensitive) that appears dull or even cracked around the pin coming through from the other side, use the wick or ****** to remove the old solder, clean the tip, flow some of the new solder into the joint. It should look shiny and obviously flow onto the pin and the board joint. Try to keep the length of time short; otherwise, the trace may lift from the board. If it does, use something non-metallic and heat proof to hold it down, reheat the solder joint briefly and press the trace down onto the board again with the tool.
If you cannot identify any specific joint that might have failed, I would recommend you do all except the smallest ones (called shot-gunning) so you have some chance of hitting the right one.
You can do this!  Just think, you've learned a new skill! Unfortunately, it isn't one particularly valuable anymore since we now just throw stuff away instead of trying to compete with Chinese child-labor.
Posted on Jan 15, 2009
Toshiba tv, turns on with sound but no picture.
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Feb 22, 2015 | Toshiba 36A40 36" TV
Toshiba Theaterwide HD 51h84
It is your projector tub if you are getting alot of blue in the picture. Those guns are very expensive to replace. I am sorry to tell you that. It would be cheaper set from wal-mart for your kids to play on.
Nov 23, 2009 | Toshiba 51H84 51" Rear Projection...
50hz not supported on Regza 26HL47?
You should have no problem displaying a 60hz 720 format as that is what this TV is based upon or a maximum of a 1080i 60hz picture. The TV will not support a 1080p or anything trying to feed it a 24 fps picture such as a blue ray player set for that mode. If you connected a standard video signal to a component connection on the TV, yes it will work but as you saw it will be in black and white. With the correct component connector for the Wii I believe the maximum it can be set for is 480p (DVD quality) which is much better than 480i (standard TV). If the picture is stretched out too much check the TV setting by using the FORMAT button on the Toshiba remote to change aspect ratios IE: WIDE, ZOOM, STANDARD etc..The other settings you want to check is in the Wii control panel. It probably asks you the type of television you are connected to such as 4:3 or a 16:9. You will want to set it for 16:9 wide-screen and if the setting is there you want to set it for 480p or 720p if the Wiii has that capability.
Jun 15, 2009 | Toshiba REGZA 26HL47 TV
Every thing works except the sound
press mute on the remote control
Jan 25, 2009 | Toshiba 32A33 32" TV
No picture
Try a "hard restart"', which simply means unplugging the power cord of your TV, and replugging it after 4 hours have passed. This technique helps to reprogram the electronics of your TV.
Hope this suggestion works for you.
Jun 05, 2008 | Mitsubishi VS-60607 TV
Panasonic CT-32SL14 flat screen tv stopped working
We played Wii sports and fit for few hours than tv started to flicker and change colors to green and black and white. We shut down Wii and not TV screen doesn't show any picture. The power is there and the sound... but the screen is just blue. Any one experienced anything similar?
May 20, 2008 | Panasonic CT-32SL14 32" TV
Toshiba 36AFX61
Just Connect signal to tv and run autoprogram. Or use video input jacks from converter to tv ( yellow,white and red video in ) and select tv/video on tv pannel front ( don't need remote control) I hope this work for you.
May 11, 2008 | Toshiba 36AFX61 36" TV
Picture problem
Since it is 9 years model definetely loose contact and flux corrosion is there in wire connector and pcb also. Make one general service. Prolem solved.
Aug 23, 2007 | Toshiba CF35F50 TV
Set needs to be slapped to get a picture
TV's need a good slap once in a while to set them right! Just kidding. Sounds like you have a bad connection that once the set is warm it mends itself. Have a technician look at it.
Apr 18, 2007 | Toshiba CF27H50 TV
Quasar SP-2725 27" TV Logo
258 people viewed this question
Top Quasar Televison & Video Experts
 Grubhead
Grubhead
jason
Are you a Quasar Televison and Video Expert? Answer questions, earn points and help others
