Question about KitchenAid K5SS Heavy Duty Commercial Stand Mixer
My worm gear is stripped
I have the replacement gear but I don't know how to take apart the assemply
  • 118 Answers
Download the service manual from Kitchenaid, or several other sites on the web. Just google your part number and the words "service manual" and you should find it. Some of the gears in the head are held in with pins though them, and you may not see it with the grease on it. You need to tap them out with the right size punch.
Posted on Jan 27, 2009
Hlamilton beach hand mixer. One beater doesn't turn. Does this mean that a worm gear needs to be replaced? If so, can I do that myself? Thanks
You can take it apart and check, but if a cog has stripped you won't find a replacement for it. Hand mixers and termed as disposables when they break down. Could it still be in warranty? The warranty is 5 years!
http://www.hamiltonbeach.ca/warranty.html
Nov 30, 2016 | Food Mixers
Speed problems with kitchenaid artisan mixer.
It sounds like two issues, the first is going to be the phase board, you will need to replace it, that should fix your speed issue.
The second issue will be a stripped gear, in that mixer there is a nylon gear that commonly goes bad, that would be the worm gear.
Here is a link to the phase board: http://www.mendingshed.com/kaphaseboard.html
Here is a link to the worm gear:
http://www.mendingshed.com/kawormgear.html
Also here is a link to the service manual: http://ep.yimg.com/ty/cdn/mendingshed/kitchenaidservicemanual.pdf
The service manual will show you how to take apart the mixer, and put it back together.
Jan 31, 2014 | KitchenAid Food Mixers
Grinding Sound
It could be a different gear that is stripped in the mixer. There is also the chance that the gear that was sent you was damaged before it was put in, we do see chipped gears come from KitchenAid every once in a while. The best thing to do would be to take apart the mixer, clean the grease off the gears, and carefully inspect each one for chips or gouges in the gears.
Jan 23, 2014 | KitchenAid ProLine 600 Stand Mixer
Kitchenaid Mixer Planetary becomes sluggish when met with resistance.
The problem will be with the worm gear, if the gear is not stripped then check that the locating pin for the worm gear is not broken or missing. Occasionally the plastic gear can detach from the aluminium boss between plastic and shaft. The worm gear is the 99.9% place where drive can slip. Afterthought, I suppose the planetary pin is not missing or broken??
Jun 28, 2013 | KitchenAid KSM150PS Artisan Series Stand...
Mixer noisey and not going round freely
Your mixer most likely has a stripped gears, or a combination of stripped gears. The 5kpm5ewh is an international model similar to the ksm5. The gearing inside the mixer will be the same, some of the electrical parts may differ.
Your mixer has a nylon worm gear inside, this is the most common gear to strip inside the mixer. I would recommend opening the mixer and inspecting all of the gears before you place an order.
Most likely you will need the worm gear, which is available by itself (http://www.mendingshed.com/kawormgear.html) or you can get it in the whole worm drive pinion gear assembly (http://www.mendingshed.com/kitchenaidgearassy.html) the whole assembly is a lot easier to replace, and will save you a lot of time. You may also need to replace the grease inside your mixer, KitchenAid recommends the Benalene 930-2 food grade grease, it is only available in a 30oz can (http://www.mendingshed.com/kagrease.html) And you will also need to replace the gearbox gasket (http://www.mendingshed.com/mixergasket.html).
To aid you in your repair, here is a link to the KitchenAid service manual (http://lib.store.yahoo.net/lib/mendingshed/kitchenaidservicemanual.pdf) This will walk you through how to take apart the mixer, replace the gear, grease and gasket, and reassemble the mixer.
Thank you,
ColleenCustomer ServiceMendingShed.com800-339-9297
THE MENDING SHED, HELPING YOU GET THE JOB DONE SINCE 1971.
Apr 09, 2013 | KitchenAid Pro-Line Heavy Duty Lift Bowl...
My stand mixer's motor runs but the blades don't turn to mix the food
Get a copy of the Repair Part List for your model at Kitchenaid.com
Download a Copy of the Kitchenaid Service manual.
http://www.kitchenaidparts.be/centers/servicemanual/mixer.pdf
The Worm Gear (12) teeth was stripped and needs to be replaced.
The whole Worm Gear Assembly can be purchased on eBay for under
$15.00
Aug 04, 2011 | KitchenAid K45SS Classic Stand Mixer
Beaters won't turn bowl still does turn
I just took mine apart for this same issue. What i found was the plastic beater drive gears have been stripped by the motor worm gear. I am currently looking for these parts to replace them.
Dec 28, 2010 | Sunbeam 2346 Heritage MixMaster Series...
Just replaced the worm gear and cleaned out old grease adding clean new grease. Plugged the machine in and it will not run at all. The machine had been working but not well since I had stripped the worm...
Hi PEGNGEORGE. I can understand your frustration after getting all that work done for the gear and grease replacement just to find that it won’t run. Makes you want to scream. But before screaming, let's see what might be causing problems.
If your machine is not getting power to the motor, and you’re confident that the motor was not damaged by the stripped worm gear, which necessitated the replacement in the first place, then there are a few things that we can look at.
The easiest to check are the motor’s brushes. During your disassembly, did you remove either or both of the motor’s brushes (from the side of the mixer’s head)? If yes, then you need to check their alignment on the armatures’ commutator. The concave contact face should be resting completely on the comutator. If you've turned it 90 degrees too much, it wont' seat properly and you'll get no 'juice' to the electric motor so it won't start.
If the answer is no, and you said the mixer worked, but not well after the worm gear stripped, that would lead me to suspect the problem most likely will be with your speed control assembly.
Since you’ve already replaced the stripped worm gear, I imagine you have your mixer’s Parts List manual on hand, but if you don’t, you can download a PDF version from the KA website: http://www.kitchenaid.com/flash.cmd?/#/page/home.
Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number, in your case use K45SSW, and select the file listed under Parts List (1), K45SSWH0.pdf (341.41 KB). Check to ensure it matches your mixer model.
Turn to pages 6 & 7, titled: Motor And Control Parts, which provides an exploded view for the disassembly and reassembly of your mixer’s electrical components, along with all the parts. You’ll want to focus on Illus. No. 25, Control Plate Assembly.
First inspect around the control plate assembly to ensure all the wire connections are OK. It's possible a connection has come loose. Unfortunately the whole controller assembly is fabricated on a little PC board which was not meant to be 'home fixed', and my 'expertise' ends there. A local small appliance repair shop should be able to determine if the controller assembly is functioning properly or not, or you can just order replacement parts without the testing.
As far as parts go, here are four potential vendors in no particular order: RepairClinic.com; mendingshed.com; searspartsdirect.com; partstore.com. Prices for the same part can vary widely between vendors, so do your comparison shopping.
You may already know about the website links below when you replaced your worm gear, but it’s always good to keep these sites in your ‘toolbox’. Here are some links to several excellent websites that detail the disassembling/reassembly of a KA Mixer.
Between these three websites and their excellent pictures and descriptions and your Parts List manual, you should now be able to completely disassemble and reassemble your mixer.
Good luck and have fun. I hope this helps. Howard, Burke, VA
If this solution has helped you, please rate it, thanks! - hslincoln
Dec 14, 2009 | KitchenAid K45SS Classic Stand Mixer
KitchenAid K5SS Heavy Duty Commercial Stand Mixer Logo
179 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
jack arons
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
