Question about GE Profile JGSP44 Dual Fuel (Electric and Gas) Kitchen Range
My broiler works - but the oven does not - GE Dual Fuel range
I have a GE Dual Fuel Slide In Range model JS2968
The broiler works, the oven light works , the top of the stove works
BUT the oven does not get hot... it appears there is no flame at the bottom of the oven... HELP!
  • DianeDrey Jan 15, 2009
    OK... I made a mistake IT is a GE Profile model JGS968SOH255
    It is a gas unit (at least there is a flame when it broils)
  • Carl Schulzetenberg
    Carl Schulzetenberg May 11, 2010
    Please check your model number again. Get the number from the sticker on the range, usually just behind the lower drawer panel. (right below the left hand oven hinge)
  • 1,543 Answers
Thanks for providing the full model number, which allows us to look up part numbers and see exploded views of your product.
Most likely the bake ignitor is bad (even if it still glows, it may not draw enough amperage to allow the gas safety valve to open). One way you can test this on your model is to swap out the broil ignitor for the bake ignitor, as they are the same part number on your model. (part number WB13T10045) The broiler is normally used much less than the oven, so the part does not fail very often on the broiler. You will have to take the cover off the floor of the oven, then the flame spreader, to reach the burner area. The ignitor is the rectangular part at the back, on the side of the burner. (only two wires to deal with) (By the way, for future reference, your model number ends is SS, as in stainless steel, not a 55)
Posted on Jan 15, 2009
My broiler work but when I tried to put it on bake it does not light up of heat up I have a frigidaire model number FEF366ECD can you please tell me if I have buy a new stove please thank you
Posted on Feb 01, 2010
  • joshuaromero Feb 01, 2010
    the only one that works is the top and I can only put it on broil only and It electric frigidaire FEF366ECD. If you push the baking and put the tempeture on it goes but the baking elements does not light up
    Problem Solver:
  • 5 Answers
Bake and broil both out or just bake? also is this model electric bake and broil? alittle more description on the oven and ill point ya into what to look for
Does it have 2 plugs 110 and a 220
This is the oven spec, so it has to be 220 volts to support that wattage. The oven and broiler are electric and the hob is gas. Best of both worlds. (I am a chef)
Oven-Bake Element 2500 Watts
  • Oven-Broil Element 6 Pass 3400 Watts
    and then I found this :>)
    Power Power Supply Connection Location: Left Bottom Rear Gas Supply Connection Location: Right Bottom Rear LP Gas Conversion Kit: Included Voltage Rating: 240V / 208V / 60 Hz Connected Load kW Rating at 240/208 Volts: 3.7 / 2.8 Amps at 240 / 208 Volts: 15.4 /13.5 Minimum Circuit Required: 30 Amps
  • Frigidaire FGDS3065PF 30 Slide In Dual Fuel Range with 4 Gas Burners...
    Jan 31, 2016 | Frigidaire Gallery 30" Self-cleaning...
    Changing a broiler element on a Thermador PD366BS-03 dual fueal range.
    Maybe this link will help. https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Range-Stove-Oven/13-115-200411-/Thermador-Oven-broiler-not-working-PRDS484GG
    Nov 05, 2017 | Kitchen Ranges
    GE oven/broiler problem: oven works, broiler does not light. Model JGRPP17WEW4WW
    This would also go for the broiler also...
    The ignitor is not working right and is going bad....
    have the repair man replace the ignitor, or DIY....
    Check out this tip about your problem...
    Oven not Working or
    Oven not Heating
    Oven Problems
    Replacing the Igniter
    heatman101
    Dec 24, 2010 | GE JGBS23 Gas Kitchen Range
    Me GE Gas oven is not working, but broiler and range do ?
    I am working with model JGBP26WEH1WW GE Gas range: You do not need to remove the back or even turn over, just remove the storage pan at the base of the unit and disconect the two plugs (unique plugs). You will need to splice your old conectors to your new igniter. Yes you have the correct igniter for that model.
    Apr 06, 2010 | GE Profile JGBP79 Gas Kitchen Range
    I have a spectra gas range and the broiler works but the oven doesn't. When I turn the oven on the middle light blinks but oven won't light, what's wrong? Model#348A8035P017
    Mar 30, 2009 | GE Kitchen Ranges
    Oven, broiler don't work
    The main control board is what you need to replace here.Please Rate This !
    Jul 06, 2008 | Kenmore Kitchen Ranges
    GE Profile Spectra XL 44 gas oven
    If you can smell the gas when you turn on the oven, it may be on a separate igniter that has gone bad. I would check this first. If you are not getting gas to the oven, there is possibly an issue with the supply line.
    Sep 25, 2007 | GE Profile JGSP44 Dual Fuel (Electric and...
    GE Profile JGSP44 Dual Fuel (Electric and Gas) Kitchen Range Logo
    1,938 people viewed this question
    Top Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    Ismael Rodriguez...
    Craig Butler
    Craig Butler
    Are you a Kitchen Range Expert? Answer questions, earn points and help others
