I have a problem with a printer which is connected locally to a pc (comp1) on the network. I can access it from one pc but can not access from 3 other pc. I have three printers locally connected and all pc can hace acces to two but this particular printer gives access to one pc only.
  • 728 Answers
Hi Shueb,
First off, I assume if your running a network, you'd have a server based product running. If so, I would have the server manage the printer as a shared printer. This can be accomplished by setting up the share either in your management console or your active directory. Then the server will administer the rights to the printer. If your running a network with just workgroups, then you will have to right click the printer and go to share and security. From there go to permissions and make sure that the users on those machines have permission to access it.
A real easy way to connect a shared printer on a network is to browse through the entire network icon, and click on the machine that is sharing that printer, and when you see the printer right click it, and go to connect printer, and that's it. As long as you've got all the drivers for all the different OS's on the differnent machine, it will install the driver and give you access.
Good Luck,
Mark
Posted on Jan 15, 2009
Check connections
The connection of the USB cable
Verify that the USB cable is connected between your Brother machine and your PC.
The connection of the LAN cable (if applicable)
Verify that the network cable is connected between your Brother machine and access point and the machine is powered on.
1.Access point/router
2.Wired Network machine (your machine)
3.Wireless capable computer connected to the access point/router
4.Wired computer connected to the access point/router
The connection of the Wireless network
2.Wireless Network machine (your machine)
Still having Problem Then follow Us For
Brother Printer Support
Feb 20, 2014 | Brother MFC 7840W Printer
Tip
How resolve cannot "Connect to Network Printer" with Windows Vista
One of the more interesting errors in Windows Vista happens when you try to connect to a shared network printer. Most of the time you'll receive an "Access is Denied" error when trying to connect even though you can see the printer on the network and everything else is working properly.
Everything else on the network appears to work properly, shared files, internet access, etc. However, you just cannot access the ahared printer and print.
The solution is to add the printer as a local printer and then try printing. Follow the directions below to accomplish this.
1. Go into Control Panel 2. Underneath the Hardware and Sound category, click on Printer 3. Click on Add a printer from the top menu 4. Click on Add a Local Printer 5. Choose Create a New Port with type of port remaining Local Port, then click Next 6. In the Port Name box type the path to the printer you wish to connect to and Click Ok
Ex. \\mycomputer\myprinter
If the computer you wish to connect to is named Bob and the printer is called HP then the path would be \\Bob\HP
7. In the Install Printer Driver screen, select your printer from the list or choose Have Disk and find the location of the printer drivers on the computer then click Next and then click Finish. 8. You should now see the printer installed in the Printers window. 9. Right-click on the printer and click Properties 10. On the General tab, click Print Test Page to test the printer.
You should now be able to printer from Windows Vista to this networked printer without any problems.
on Jul 20, 2010 | Computers & Internet
Use of HPJ4680 in a network with Mac & PC connected to router
Ok what you do is, install the printer as a LOCAL one on one of the PC's, Probably the XP, one, would be best. or perhaps the PC; actually "Connected" to the D-link router & Modem, then Now install this printer , as a LOCAL, printer, and set as DEFAULT, enable Printer Sharing. Now, ALL PC's MUST, have a Name, Belong to the same Workgroup, have a Password. On the "Other" PC's Install the Printer as a Network Printer, browse for it and connect. Print a test page from each. Remember the PC with the printer attached, must obviously be ON or the "Others" cannot connect and print.. Make sure all network permissions are set sharing is set, especially on the Win 7. Just make sure they can all "See" each other first, before try all this.. the network MUST be intact and communicatable from each PC to at least the PC with the printer attached. I have included 3 links below, to help
kb.parallels.com/4886 - support.apple.com › Support -
support.microsoft.com/kb/239418
Mar 05, 2010 | HP Officejet J4680 InkJet Printer
I can connect to the internet wirelessly, but I cannot access my home network to talk to the two other computers on the network or the printer. I get a message to contact my "administrator," that i don't...
regarding connectivity of wireless network, you must double check ung router if there is a security password or properly configure your router. regarding to accessability to other computer and printer you must work share your network by so that you can access the other computer on your local network....
Nov 26, 2009 | HP MINI 2133 NOTEBOOK PC - 1.6GHZ PC...
Two laptop connected to wireless router. comp1 can access files from comp2 but comp2 cant access files from comp1. both comps show network map and can get ip yet comp2 keeps timing out when attempting...
Considering that you are using both comp with dynamic IP and from same wireless roughter and OS is same from both laptop.
As you are able to ping from comp1 to comp2 and not able to ping from comp2 to comp1 .. check the firewall setting of comp1 or disable the firewall from comp1.
Aug 23, 2008 | Computers & Internet
COMPAC LAPTOPS
  1. turn on the computer that has the printer attached.
  2. configure computer to share (start/settings/printer-faxes/right click on default printer/select sharing tab/ select share this printer/ apply settings/OK)(This computer must also be connected to the router so your laptop will see it as a network device)
  3. on wireless laptop, add printer
  4. when prompted select network printer.
For my wifes ease of use I purchased for $20.00 network magic which auto configured all my devices and monitored any access to my wireless router so I could choose who could access my open router.
Jun 04, 2008 | Compaq Presario 700 470024-192 Notebook
EPSON STYLUS C90 PROBLEM
Let's start here:
Go through file and printer sharing in all three
Ensure that in PC#2 the Epson is the Deafault Printer chosen
Install the printer locally and directly on PC3 to test from the paralell ports. If it works normally, we continue to susperct network glitches.
Are you using the same operating system in all three PCs?
Let
Feb 18, 2008 | Computers & Internet
Connecting printer to SBS (Small Business Server)
You can physically connect the printers to the server and share it from there or leave the printers connected to your computer and have the server connect to them via a Local Port which routes to your computer!! To do the Create the local ports you'll need to 1.) share the printers on your pc 2.) Go to the server and go to printers in control panel 3.)Click on Add a new printer then next 4.)Select Local Printer connected to this computer; De-select Automatically Detect Printer 5.)Select Create new port and select Local Port 6.)In the enter a port name, enter the full network path to the printer i.e. \\your-pc-name\printer-share-name click ok 7.) Select the drivers for that specific printer(if its not there click on have disk then browse to the drivers to install them) 8.) Continue through the installation until finish) 9.) Repeat steps for additional printers Keep in mind that your computer still needs to be on! You can check to see if your printer support a network card to make them fully network printer you can add them to the server this way and only the server would need to be on! Or you can also get a print server(Device that makes regular printers into network printers). Now when it comes to the scanning, i don't know of any way to share a scanner with just windows alone, but there are third party software that allows you to do that Check out http://www.remote-scan.com/ There are also printers that sorta do the scanners sharing by automatically scanning and putting files in a designated area on the network! Hope this was helpful regards, babb
May 02, 2007 | Canon LaserBase MF5650 All-In-One Printer
Computers & Internet Logo
47 people viewed this question
David Payne
David Payne
