Question about GE WBSE2090A Top Load Washer
Not spinning Started making squealing noise recently, mostly during wash cycle. However, now it won't spin, though the motor sounds as if it's working and it is draining
  • 1 more comment
  • diannamyrtle Jan 19, 2009
    washer will not spin but moter starts and then stops will not drain because it does not go into spin what can i do
  • billsnsabres Jan 24, 2009
    turned out to be the motor pulley broke, but the belt obviously must've been loose before it happened and then fell off. had to take pretty much the whole unit apart but had pulley tack welded and got belt from AP Wagner for only $7-$8
  • sriley595 Feb 07, 2009
    Pully isn't broke, but there is a small clip right below the pully. It is solid on one side, folds over on the edge and then is open save for a clip on either side. This clip is square, but if you looked at it down the side, it would have the shape of a cotter pin (spelling?).
  • 716 Answers
Sounds Like Its The Belt Open Up The Unit Get The Broken Belt And Take It To The Auto Parts Store And Have Them Give You One Of The Equal Length.
Posted on Jan 15, 2009
I have a 2012 top loading frigidaire gallery washer. It recently started making a loud thumping noise during the wash cycle. When it spins out it smells like burnt rubber. Any ideas? Thanks
There is a rubber belt between the motor and the rotating cylinder.
If it is frayed, then part of the belt is hitting something during the "wash" cycle, and rubbing much faster during the "spin" cycle.
Replace the belt.
Aug 27, 2015 | Frigidaire Washing Machines
Know when clutch going bad
Needs agitator dogs in agitator.
Mar 13, 2014 | Whirlpool Washing Machines
My washer has recently started thumping and banging during the spin cycle. I thought it was uneven weight distribution, but it does it every spin now. And when the spinning slows down it has started...
Hi, . according to your washer problem i m writing solution ,please read and follow it:-
  1. Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
  2. check out this following options one by one to locate the fault in your machine.
  3. 1)Check for drum bearing failure if your washing machine is noisy on the spin cycle. Drum bearing failure is common when the bearing seals start allowing water to enter. You can take the belt off and spin the drum by hand, and if the drum rumbles, replace the bearings.2)Turn the drum by hand and listen for loud noises. If the drum itself is split or the 'spider' is corroded, broken or has come apart from the back of the drum it will create a loud noise on every turn of the drum. (When the bearings have gone bad, the noise is constant the entire time the drum is spinning.)3)Look for obvious dents and creases in the drum or look for coins or small objects stuck inside the tub underneath the drum when a horrendous noise is made while clothes are in the tub.4)Clear thewater pumpfrom obstructions like coins or small objects when a noise occurs while the washing machine is emptying water.5)Remove the sump hose and look for bra wires if you hear a light scraping noise when the drum is turned by hand. You can also check to make sure a wire isn't poking out of one of the holes in the drum. In this case, you can pull the wire out easily with pliers.6)Take the belt off and run the motor alone if you hear a high pitched squealing noise to check for motor bearing damage or wear. If you still hear the noise without the belt, it's the motor bearing.
  4. you can get the required partys from
  5. www.repairclinic.com
  6. I hope this will help.
please don't forget to vote me. goodluck.......
Jan 21, 2011 | AEG Lavamat 72640 Front Load Washer
Washer squeals during wash & rinse cycles.
It sounds like you're brake stator & rotor is worn and merit replacement, it would also be prudent to replace the thrust bearing as well since you'll be in the same area for the repair. The way to verify is to place the unit in spin & allow it to reach speed then open the lid. If it squeals then the repair would need to performed, if it does not then further troubleshooting would be needed. Hope this helps... Bill
May 29, 2009 | Maytag PAV2300 Top Load Washer
Load squeal when it in the agitation cycle.
for detailed help with diagrams and step by step instructions click the link http://www.applianceaid.com/washerspinnoise.html
Dec 29, 2008 | Admiral AW22 Top Load Washer
Loud squeal during wash and spin cycles, maytag atlantis washer
Squealing normal occurs due to belt slippage. I would check your belts (look for cracks. Check the belt tension as well, most washers have an adjustment, normally on the motor that allows you to increase the tension of the belt.
If part of a belt gets torn and it is long enough, it will hit any part of the washing machine within range and make a clicking noise at every revolution of the motor.
I am pretty sure you need new belts. You should be able to remove a few screws and open the back cover. Between the pulleys there is a tensioner...loosen that so you can remove the belt easily. replace it with a new belt and adjust the tension.
hope this helps
Feb 23, 2008 | Washing Machines
Squealing noise during spin cycle
The spin cycle activates the fast mode on the motor, squealing normal occurs due to belt slippage. I would check your belts (look for cracks. Check the belt tension as well, most washers have an adjustment, normally on the motor that allows you to increase the tension of the belt.
Jul 08, 2007 | Whirlpool LSB6200KQ Top Load Washer
"howling" noise during spin cycle (still there after changing burned off belt)
Travioso, there was two service flashes out on this model concerning the seal and bearing which means they had an issue with this washer. The howling noise you are hearing is the bearing and will need the new designed triple seal and bearing kit. This should be covered under your warranty, I believe it is 5 years. The numbers for the service flashes are TDL-0048A-B. Call Maytag and inquire about these service flashes, these should be covered. Catriver.
Jul 25, 2006 | Maytag SAV5701A Top Load Washer
Loud Noise - Spin Cycle
If the washer is making a squealing noise, the problem is more likely to be the basket drive. If it is more like a rattling sound, the centerpost bearings are probably worn out. Open machine's rear panel and spin the basket manually by turning the drive pulley, to find out from where exactly the noise come from. Defective part should be replaced. Good luck !!
Jun 29, 2006 | Kenmore 43042 Front Load Washer
GE WBSE2090A Top Load Washer Logo
119 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
