Question about Nokia N70 Cellular Phone
Power problem my N70 automatically goes down the power and shut off after 1 or 2 hours, what to do with it? thanks! Cezar
  • 50 Answers
I am sure your battery is not too old. And I hope you are using a good anti virus software for your phone.
If your phone's battery is ok, the next thing that we need to make sure is that your phone is not infected by any virus or worm, common symptoms of infection are non responsive blue-tooth, slow performance, unstable operations, etc.
There are many anti virus softwares available for your phone like Symantec mobile security. Download a trial version and install it on your phone, run the live update (requires gprs/3g internet access) and run full scan.
Another work around would be to format your phone's internal memory which you can do by pressing *#7370#. Please remove the memory card before doing so. Also make sure the battery is fully charged. In your case, plug in the charger before proceeding. Format the memory card as well through a PC before using it on your phone again.
I hope this will help...
Posted on Jan 15, 2009
IN104 automatic shutdown
Hello, my infocus in104 will power up for a while (1- 5 minutes) when connected to the power supply and turned on, after that it automatically shuts down. Power button does not light red when it automatically shuts down and need to be unplugged for a minute or more before red power button will light up again.
Mar 21, 2013 | InFocus IN104 Projector
My desktop computer shuts down automatically after using 1 hour. What may be the problem?
Please and see if the processor fan is ventillating to the processor and so there is no heat build up to shut down the thermal switch. If there is dust use a good blower an brush to clean , make sure the fan works. Also the fan on the SMPS unit also must work well.
Check on all the connectors, press them all down. check the mains power .
Finally check on the power options for any changes or settings for shut down./ hibernate or sleep mode
Apr 11, 2011 | Computers & Internet
Power problem I closed my Compaq F700 and opened it 10 minutes later and it shut itself down and won't power back up. Battery is good and the power cord light comes on when plugged in. Any help? Thanks...
Press the power button and if it goes on keep pressing the button until it shuts off. Then try to power it up by tapping the power button once.
How have you tested the battery? In my Acer laptop I'm on my third one in 2 years and recently got a 9 cell high capacity one that lasts 3.5 to 4 hours when my original lasted only 1 or 2 hours tops.
Jul 22, 2010 | Compaq Presario 700 470024-192 Notebook
The power button on my HP monitor keeps getting a message saying "Power button lockout" and the monitor will not turn off whenever i push the power button it just goes to sleep and i have to unplug it and...
Hold down the power button on your monitor, with the power on, for approx. 25-30 seconds and the monitor will shut down for good. When you will start it again, wait at least an hour, the message will be gone and the monitor will work as intended.
Jun 23, 2010 | Computers & Internet
When i restart the system don't turn on again
something may be wrong with the power supply. i have a computer where the power supply is faulty and it used to shut down automatically after 1 hour. nowadays, it shuts down more frequently, whenever restarted, it will not come up again. i have to wait for sometime so that power-supply can cool down and i can start. -Nitesh Kumar Anand
Apr 16, 2010 | Mercury P4VM800M7 Motherboard
I have a Compac Presario, running VISTA. When
simply disable the automatic update service by following these steps.....
start | run | services.msc | automatic update
stop ...and disable it...click ok
and close the service manager....
then try to shutdown the machine ....
Dec 30, 2009 | Computers & Internet
Works good for 2 minutes, Then shuts down & light goes red. Remote wont restart , so turn power off then on, Works again for 1 minute then shuts down. Panasonic PT-AE900U... projector
change the Bulb if that does not work it could be a power supply or power supply regulator this should be done by a professional except the Bulb
how many hours of operation does the unit have ??
Sep 21, 2009 | Office Equipment & Supplies
Automatic one hour shut down
Hi there.
Click on the start menu and go to the control panel, select power options and there you can set the PC to never shut down.
Good luck and thanks for using FixYa!!
May 13, 2009 | Compaq Presario 5000 PC Desktop
COMPAQ CQ60-104Tu goes blank... improper shutdown
It might be a problem with the computer. I would advise going back to where you bought it and returning it to either get a new one or a different one. Glad I Helped!
Jan 28, 2009 | Compaq Presario Notebook
Honeywell oil radiator
Press the *power button* once to start the heater on high power, continuous run. If left at this setting, the unit will run continuously on high power (1500 watts, 12.5 amps) and will not shut off until the unit is manually turned off.
Press the *power button* again, to change to low power, continuous run, (900 watts, 7.5 amps) and will not shut off until the unit is manually turned off.
Set temperature:
Press the temp/timer button until the temperature icon blinks. Use the up and down arrows to set the desired temperature.
The temperature icon will stop blinking and the current room temperature will reappear after the desired temperature is set.
The heater will turn off and on to achieve the desired temperature.
Set timer: (auto off)
Press the timer/timer button until the timer icon blinks. The hour display will appear. The auto off icon will also appear.
Use the up and down arrow buttons to set the heater operation time between 1 and 10 hours. This function will activate once the timer icon stops blinking. The heater will automatically turn off whn the times runs out.
Set timer: (auto on)
Press the temp/timer button until the timer icon blinks. The hour display will appear. The auto on icon will also appear.
Use the up and down arrow buttons to set the heater start time between 1 and 10 hours. This function will activate once the timer icon stops blinking.
The heater will automatically turn on when time expires.
Hope this helps!
Sep 24, 2007 | Honeywell /KAZ HOME ENVIRONME HZ-705 7Fin...
Nokia N70 Cellular Phone Logo
70 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
