Question about Sony SLV-D380P DVD Player/VCR
Pulsing screen when playing a dvd the tv screen pulses. but when i try a vhs it doesnt' do this. The tv itself is hooked up to cable and it doesn't pulse when it's switched to the cable. Can anyone help me?
  • jessiecrego Jan 16, 2009
    it looks as if the screen has a heartbeat. the screen gets dark and light then dark and light. then it just stops and it's a normal picture!
  • Shahid Electronics
    Shahid Electronics May 11, 2010
    What does that mean Pulsing? need bit details to know what is pulsing?
    President:
  • 2,992 Answers
It sounds like the TV is responding to copy-protection on the DVD. Do you have the player connected through the TV's antenna input on channel 3 or 4 (RF connection) or through AV inputs on the set? You're probably using AV as most of the newer combo players don't offer RF output. Depending on the way the TV is made, this can often cause the set to display the brightness changes you describe. (The copy protection was designed to make the copy play back that way so it would be unwatchable. Sometimes the TV would be affected the same way on normal playback. It's why companies started selling "image stabilizers" to put between the player and the TV -- or another recorder -- to remove the copy protection. These devices may still be available. I have one but bought it at least 15 years ago.)
Posted on May 10, 2009
I need assistance in connecting my DVC845E (VHS & DVD recorder) to my Samsung TV. A VHS will play but cannot get it to record.
Some of the Newer VHS/DVD units don't have cable inputs. If this is like yours you can hook a RCA Audio/Vidio cable from your Samsung TV Vidio/Audio outputs (if set has them) to VCR/DVD inputs................... Larry
Oct 08, 2010 | Sylvania DVC845E
We just bought a new 32" panasonic led tv. Hooked everything up and works fine with normal television broadcast. However, we have a Sony DVD/VHS combo hooked up that doesn't perform well. When we play...
If you are using the composite cables (RWY) make sure the red and white are plugged into the audio jacks and NOT the component cable plugs (RGB.) If you have the red audio cable plugged into the red component plug this will cause issues, especially with the sound.
Aug 10, 2010 | Panasonic Televison & Video
My dvd/vhs combo has sound but no picture on the vhs side?
Check ur RCA cable setting might have a short in the cables.
Dec 12, 2009 | Televison & Video
Can't see dvd on TV
how to hook up to watch dvds
May 25, 2009 | Sansui VRDVD4005 DVD Player/VCR
Hooking up my DVD/VHS player to TV & Convertor box
I would just hook up the dvd/vhs player with the red,white,yellow rca cables that should of come with your unit and just go to the input on the tv to watch your dvd/vhs player. This will give you a better picture and sound while allowing you not to have to watch dvd/vhs on a channel which helps make the dvd/vhs player independent. Also if possible I would hook the converter box up with the red,white, yellow rca cables to the tv as well if your tv has more than one set of red,white,yellow plugs since it is a better connection that coax and you probably watch more tv than vhs/dvd anyway. So bottom line try to hook up both boxes red,white,yellow and watch each box on different inputs instead of like channel 3 or 4. Also to record of converter box you can run coax from converter box to dvd/vhs combo and make sure your dvd/vhs player is on tuner input or channel 3.
Nov 16, 2008 | Insignia Digital-to-Analog Converter for...
Hi' I have a Denon 3910 that is connected to an Infocus Projector via HDMI out on the Denon to DVI on the Infocus(One end of the lead is HDMI the other DVI) .problem has always been without the projector...
You can try this reset method, if it doesn't work it will probably need service by a professional. Remeber that all setting will be lost, make sure you know them so you can put them back in after you are finished.
At the player stop condition,
press 3 buttons for DVD operation
(“PLAY”,”OPEN/CLOSE”, and “ SKIP”) until
“INITIALIZE” appears and disappears in the display.
(“Initialized” appears and disappears on the TV screen.)
******All user setting will be lost and its factory setting will be
restored when this initialization is made. Be sure to memorize
your setting for restoring again after the initialization
Jul 03, 2008 | Denon Audio Players & Recorders
NO picture showing on screen even though the VCR is running and hooked up properly
u have to run it directto tv yellow cable ok and sound cables not throw dsh tv
Feb 03, 2008 | Quasar VHQ400 VHS VCR
The DVD will play and display, but the VHS will play but not display.
It could be that the output to TV from VHS only works through the composite cables (the red, white, yellow).
Dec 11, 2007 | Samsung DVD-V8600 DVD Player/VCR
Pulsing screen
Are you getting this on all video outputs from the DVD? the yellow analog out + the red/blue/green + the S video? Did you try connecting a different source? a digital cable TV tuner, or another DVD player? sometimes DVD players get screwed on some outputs, while the rest stay fine. I have a DVD that has an analog video out that shows an only black and white picture, while the red/blue/green works fine. Good luck
Apr 21, 2006 | Yamaha DVXS60 System
Sony SLV-D380P DVD Player/VCR Logo
85 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
