Question about HP Officejet Pro L7590 All-in-One InkJet Printer
L7590 printing right to left
All of sudden my printer started printing backwards - can anyone help.
  • 1 more comment
  • staunchenrgy Jan 15, 2009
    Wow, great printer HP. [/sarcasm]
  • dina_hartsto Jan 15, 2009
    It worked, now can you tell me how to make the fax speed faster on sending.
  • Wayne Mineard
    Wayne Mineard May 11, 2010
    Dina,
    Is this a mirror image you are getting?
    If so, open a document, select Print.
    When the Print window opens select Preferences or Properties (whichever yours has). Click on the Advanced tab and look for a Mirror Image option. If it says ON, click on it and it will change to a drop down menu. Select Off.
    President:
  • 1,901 Answers
Dina, I'm posting this as a solution so you may rate it as Fixya:
As for the faxing...There is not much that can be done except perhaps check the resolution you are sending faxes at. The higher the resolution the longer it will take to send.
W
Posted on Jan 15, 2009
  • bertyom1 Feb 11, 2011
    Hi, i also had this problem with a HP L7590 and it worked for me . Thanks!!
Brother MFCJ870DW Cuts Off/Chops Off/Truncates Left Side Return Address By About Half An Inch On #10 Com Envelope, Suddenly Started Happening
Check carefully that you have specified it to use the # 10 and that the format does not include a wide margin. If that fails, try printing the Return address 'right justified' and see what happens.
Feb 01, 2014 | Office Equipment & Supplies
Printhead has a problem HP Office Jet Pro L7590
I suggest you go to the HP support website and see what assistance you can get for this model.
Start by downloading HP Assistant
Oct 06, 2017 | HP Office Equipment & Supplies
Officejet Pro L7590 print test indicates print heads are "good" but cannot get through align printheads procedure without getting a fail message.
ALign the printer manually. TO to that follow these.
Click Start and then go to Printers and Faxes (XP), Printers(Vista), Devices and Printers(Win 7)
1. Right Click on your printer Icon 2. Go to Printing Preferences 3. Click the Features Tab 4. At the bottom of the window you will see Printer Services or Device Services. Click on it. 5. Choose Align Printheads on the list.
Try Printing Again. I hope I was able to solve your problem. :)
Feb 05, 2011 | HP Officejet Pro L7590 All-in-One InkJet...
When I print something instead of comiing out completely opposite like the printer is Dyslexic. In order to read it you need a mirror to see it like a normal print. Even the words in the shapes are...
Hi
In your printers properties
you have change printing properties
and you have choose mirror printing
just go to the menu and change it
Pls vote us to keep us alive
Nov 17, 2010 | HP Officejet Pro L7590 All-in-One InkJet...
How do I print a fax confirmation AFTER I've sent a fax on the HP L7590?
The product can print confirmation reports automatically for each fax that is sent and received.
Printing fax confirmation reports
  • The default fax confirmation setting is Off . Use these instructions to enable printed fax confirmations.
  • Press Setup on the product control panel.
  • Press the right arrow button until Print Report appears on the control panel display, and then press OK .
  • Press the right arrow button until Fax Confirmation appears on the control panel display, and then press OK .
  • Press the right arrow button to select the appropriate option (listed in the following table), and then press OK .
Sep 25, 2010 | HP Officejet Pro L7590 All-in-One InkJet...
Print head on Officejet Pro L7590
Press Setup on the control panel.
Press the right arrow button until Tools displays, and then press OK .
Press 2 to begin the cleaning process.
Nov 21, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
Prints backwards
You have probably turned on the "Mirror Image" option.
When you go to print and the Print window comes up, select Preferences and then the Advanced tab. Look for the Mirror Image option and Disable it by clicking on the underlined option and change it.
(BTW, the Mirror Image is used to print iron-on images for t-shirts, etc.)
NOTE: If you don't see it on the Advanced tab, look on the Effects tab.
Nov 17, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
Prints backwards
LOL Awesome!
I would recommend reinstalling the driver
Be sure that the device is not connected to the computer until the software prompts you to plug it in
Sep 26, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
Prinitng backwards
Try this....
Turn off mirror imaging in Printer Preferences . To do this, use the following steps:
  1. From the Windows taskbar, click Start and then click Run .
  2. Type control printers in the Open box and then press Enter . The Printers and Faxes window displays.
  3. Right-click the HP product from the list of printers and then select Properties . The Properties dialog box displays.
  4. From the General tab, click Printing Preferences . The Printing Preferences dialog box displays.
  5. Click the Advanced tab.
  6. Under Printer Features , click Mirror Image , click the down arrow (c01320592.gif ) to the right of the field, and then click Off .
  7. Click OK to apply the change.
Dec 22, 2008 | HP Officejet J5780 All-In-One InkJet...
Printer prints backwards/upsidedown
This sounds like an advanced setting on your printer setup. When you get to the print dialog, hit Properties for your printer, then look around there for a "mirror" or "reverse" setting. Different printers use different drivers, so your configuration options are difficult to predict.
Apr 18, 2007 | Brother MFC-5840CN All-In-One InkJet...
HP Officejet Pro L7590 All-in-One InkJet Printer Logo
220 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
