Question about Thermador C301U Electric Single Oven
Thermador C301 electric oven f33 code
There is a f33 code displayed by a Thermador c301 single oven. Please advise. Thanks.
  • 1 more comment
  • JackHandy Dec 19, 2007
    Tried to broil a steak on HI (550oF) and after a few minutes the oven beeped and F33 showed on the screen. I followed the troubleshooting instructions in the manual and waited 3 minutes. Set it on HI again and just got my steak cooked (medium rare) when it stopped again and F33 came up.
    DId not contact store yet. Is this a serious problem?
  • Bill Fraser-Harris May 03, 2008
    I also got an F33 ec and now the upper oven does not reach temperature set. About 50 -100 degrees F low. Ideas?
  • paulhayes111 Dec 28, 2008
    Ditto F33
SOURCE: Fading digital display on Thermador SC302ZS Double Oven
when the display is fading it has to be changed part number 492071 that is for a double oven display
Posted on Jan 31, 2011
  • 1894 Answers
SOURCE: Thermador C302U error code
most of error codes disappear when a hard reset is done.
did u try a hard reset first?
Posted on Jun 28, 2008
marked
  • 6487 Answers
From my experience when there is a power outage, This is likely to have wiped out the control board on your oven. I see it all the time after storms. If a storm comes through, I get a ton of phone calls about control boards not working anymore or doing crazy stuff. If resetting the breaker has shed no light on your situation. I would recommend replacing the main control.
Also when you get this fixed, plug the stove into a surge protector of some sort. This will decrease the chances of a power outage doing damage to the oven control.
Hope that helps........
SOURCE: thermador oven control panel light is not working
Please see post by bonanzsapilot on 14 March 2009; he gives exact & easy to follow directions for making this repair for <$10. It's listed uner 'Thermador SC301IT oven - FixYa'. In a separate post I added the correct capacitor numbers from Newark.com. I made the fix in abt 30 min & it's good as new. Thermador no longer makes control panels for this oven & no wiring diagram is available to help. Shop price was estimated at $500.
Posted on Apr 13, 2009
  • 260 Answers
SOURCE: thermador oven display fc
Try turning off your circuit breaker for a few minutes. Then, after you reset it, push clear, then set your clock.
Posted on Sep 11, 2009
Thermador over has f 24 code
fan/ air flow issue. search here for another post I did explaining the correction.
May 20, 2014 | Thermador SC272T Electric Double Oven
Flashing F33 error code thermador double oven
either a bad oven sensor or a bad power relay board.
Feb 10, 2014 | Thermador SC272T Electric Double Oven
I have a thermador oven x302xp getting code f33 on displ;ay
oven over temperature. replace oven sensor, replace relay board if repeats.
Dec 15, 2013 | Thermador C301U Electric Single Oven
Thermador c272u double oven error code f33
over temperature. Check the oven sensor, if ok, replace the relay board for that oven (upper or lower)
Sep 16, 2012 | Thermador Ovens
I selected "proof" and turned the oven on this
F33 ( upper oven over temperature while cooking ) Check sensor should read 1080 ohms at room temp.
You will need to replace the oven temperature sensor. There is no quick fix for this problem to get you up and running on this Thanksgiving day, sorry. Where are you located and I will see what resources are close to you so you can make the repair?
Nov 24, 2011 | Thermador C301U Electric Single Oven
F33 CODE
this is uper oven over temperature while cooking , check sensor should read 1080 ohms, at room temp, if ok replace power relay board
Apr 20, 2011 | Thermador C301U Electric Single Oven
Fan works, but Oven stays at 100 degrees. Tried
I had the same problem in December - I had to replace the circuit breaker and that solved the problem. My oven wouldn't go above 100 degrees in convection, bake and roast modes. Each of these modes are on a separate circuit so when one is bad, the others should work.
Jan 25, 2010 | Thermador C301U Electric Single Oven
Couldn't open door after using Clean Cycle Function
hi thanks for the question there should be a solenoid at the back where the lock rod comes out check there thanks the appliance doc
Sep 23, 2008 | Thermador C301U Electric Single Oven
Thermador C301U Electric Single Oven Logo
633 people viewed this question
Top Thermador Ovens Experts
Dan Webster
Dan Webster
goober123
Level 1 Expert
Oloyede Monsuru
Are you a Thermador Oven Expert? Answer questions, earn points and help others
