Question about Pioneer DJm500 Professional DJ Mixer W/Effects System
DJM 500 & 2 1200mkIIs -- Very Low Sound With Multiple Speaker Sys
Hi I have 2 technics 1200s and a pioneer djm 500 mixer and i'm having mucho trouble getting the damn things to play above a very quiet amplitude.
Both turntables have recently had some work done and both SEEM fine to me and I was told that they were fine internally by the repair guy.
I bought the DJM 500 for very cheap at an estate sale kinda thing, so it seems like it's probably a problem with the mixer? NO, the TTs play low when plugged directly into my roomates home stereo pioneer receiver.
I am currently using a pair of m-audio BX8a's plugged directly into the mixer via xlr. It's like listening to a tiny cassette tape/radio player from walgreens - there IS sound but with ALL SETTINGS turned all the way up, it's light as hell.
I've also used a single 12 inch powered PA speaker that was the same way, soft...
Effing frustrating! I've been building this stereo for months so i can rok my jams loud as hell and it's doing nothing of the sort....
I have no amp, just the two 1200s a djm 500 and two pretty powerful powered studio monitors, STILL, very low sound.
Any suggestions?
  • 3 Answers
Looks like the mixers pre amp has failed thus the cheap purchase price, no easy fix, needs a qualified tech to look at it. I would reccomend a qualified Pioneer specialist.
Posted on Apr 09, 2009
Are you sure you have your tt's plugged into the phono line with the master booth knob turned up? Check the mixer too cuz the techs should be square.
Posted on Feb 19, 2009
I have a djm 400 and it has started producing a buzzing sound through the speakers. I can take the same speaker cables from the djm 400 and hook them up to my backup mixer and the buzzing goes away. What...
Since it works with your other mixer, the DJM400 is probably fine. You have a ground loop.
Make sure ALL, and I do mean ALL... (re-read that if there is any confusion) interconnected equipment WILL BE powered from the same receptacle or source. If speakers or amps are powered from one place and the DJM is from the other end of the room you likely have a ground loop and you can ex[ect buzzing. Run extension cords alongside the audio leads if necessaryy to carry power from where the amps or speakers are plugged in back to the DJM400 and ANY pther connected equipment.
Jan 07, 2011 | Pioneer DJm 400 Professional DJ Mixer
Hi, I have a DJM 400 Pioneer mixer, I'm having trouble with the output levels. It seems the left output is only putting out about half the sound of the right output.I have used different RCA cables,...
Please try a set of headphones. If it is balanced in the phones, then I suspect trouble might be in the muting circuits of the main output.
Next test is to verify the outputs using direct inputs to the CD input...
Dec 01, 2010 | Pioneer DJm 400 Professional DJ Mixer
DJM 400 Keep going into over on the channel and the master volume
To keep your levels down keep the TRIM don which is the gray knob. Also keep the hi, mid, and low knobs at the medium level. The control cables are for using the fader start function.
Jun 02, 2009 | Pioneer DJm 400 Professional DJ Mixer
How to connect my qqualizer to my djm pioneer 400 mixer
Use the stereo master outs from the DJM into the A and B Inputs of the EQ (you'll need 2 phono to Jack or 2 phono to XLR cables) then from the A and B Outputs of the EQ to the power amp/ speakers, etc (you'll need jack or XLR cables depending on what is powereing your speakers)
May 27, 2009 | Pioneer DJm 400 Professional DJ Mixer
One Output low on DJM 400
This may not be the correct solution, but have you checked the switches on the back of the DJM-400 to see if one output is set to "PHONO" mode?
Apr 17, 2009 | Pioneer DJm 400 Professional DJ Mixer
Pioneer djm 800 will only play through 2 channels on mono??
try to clean your fader with contact cleaner and move it many times after cleaning -check your connection plugs(buy it from radio shack near you.
Apr 11, 2009 | Audio Players & Recorders
Pioneer DJM-400 mixer turns on, but channels aren't working
could be a few things , what have you tried to trouble shoot the problem ?
My steps would be ;
check all leads (even if you KNOW u pluged them in)
check the gain is set corectly .
check the line phono slectors are set to what ever you have you leads pluged into on the back of the mixer ( there is 4 red and white RCA plugs , 2 for phono,2 for line CDJs shold be using line )
if you are using digital cables to conect your CDJs , on the back on the mixer there is a small switch marked "CD or digital" make sure that is sleceted "digital " . if ur not using digital cables make sure it is on "CD" .
the info iv put here is based on the DJM-800 so your mixer my not have some of these featers as iv never used a 400 . hope this helps dued . check out www.djtutor.com for more tricks and tips . Pratices'N'enjoy !
Dec 28, 2008 | Pioneer DJm 400 Professional DJ Mixer
Pioneer DJM-600 Bad feedback when i turn up the master volume
It's not your ground wire with the issue, but your RCA cables. Try disconnecting both turntables, and connect 1 at a time, and do the same test, this way you can isolate the problem. Once you've isolated the problem, then you'll need to have the RCA cables replaced on your turntable.
You might also want to check the Cartridges as well. Sometimes a bad cartridge or headshell connection will cause this issue. Worst case scenario, its your tonearm, but that should be test last.
Also, on the rear of your mixer, there is a gain volume pot, make sure this is not maxed out. Keep it about 3/4 of they up. Again, this is on the rear of your mixer where you connect everything.
- OPTiC
http://djproaudio.com
http://djprolab.com
Dec 04, 2008 | Pioneer DJM-600 Silver Professional DJ...
Djm 600
start with connections and try to clean fader with lubricant contact cleaner from radio shack or any electronics store.
Sep 10, 2008 | Pioneer DJM-600 Silver Professional DJ...
Pioneer DJm500 Professional DJ Mixer W/Effects System Logo
195 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
