Question about Ricoh Aficio 1027 All-In-One Laser Printer
Ricoh printer prints nonstop when plugged up& is in code
When I plug up the printer to the computer it starts printing and keeps going, all the print seems to be in codes. Everytime you try and do a test page it starts all over again.
  • 58 Answers
Clear you print files in your print  que
http://www.websitetoolbox.com/mb/copierquestions
Posted on Jan 25, 2009
Prints the same picture nonstop, I have to shut the printer down to stop it. Now the printer does not react at all, almost like its not connected....??
Remove the power plug before stopping spooler to erase printers memory. and plug back in power when spooler service restarted.
control panel in windows operating system , services, print spooler, Stop the print spooler and restart spooler.
Mar 09, 2016 | Office Equipment & Supplies
Why do my c305 keep printing
open all paper tray, go to print button, rest job, select "all" job and confirm. keep doing this untill there is no more print jobs showing on your screen, then go to your PC and set your default printer to this device, printing to this printer using the wrong print driver will do exactly what you just described
Apr 30, 2014 | Ricoh Office Equipment & Supplies
Printer keeps saying busy printing another document
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB connected)> reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer (if USB connected). Then try to print again once the computer fully recognizes the USB connection or when the WiFi light on the printer turns solid green (if WiFi connected.).
If that doesn't help, try the steps below:
  1. Disconnect the USB cable connecting the printer from your computer.
  2. On your computer, go to Control Panel > Printers and Faxes.
  3. Delete the Lexmark print object.
  4. Reboot computer.
  5. Re-brick your printer by pulling out the power supply - black box where the power cord is plugged into on the back of the printer, and re-plug after 30 seconds.
  6. When the printer turns on, reconnect it to the computer.
  7. Wait until your computer fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, try to print a document to verify that the problem is fixed.
Feb 10, 2012 | Lexmark X4580 InkJet Printer
Lexmark z2300 keeps printing blank sheets
Try to re-seat the cartridges in the printer. Open the printer cover > remove the cartridges > close the printer cover > re-brick you printer by pulling out the power supply - black box behind the printer where the power cord is plugged in, and re-plug after 10 seconds. When the printer turns on, reinsert the cartridges and close the cover. Try to print a document again to verify that the problem is fixed.
If that doesn't help, the problem could be due to a clogged print cartridge nozzle. Please follow the steps below to fix print quality issues with your model:
  1. On your computer, go to Start menu.
  2. Go to Programs.
  3. Go to Lexmark 2600 Series folder.
  4. Select Lexmark Solution Center.
From the Maintenance tab, select Clean to fix horizontal streaks. Your printer will then print a page forcing ink through to clean the print cartridge nozzles.
Oct 06, 2011 | Lexmark Z2300 InkJet Printer
Print driver (2228C PCL 5C) shows printer queue offline. How can I bring it back online? I have rebooted the printer. There dosen't appear to be an option on the print queue when going in as admin on...
Remove the data cable from the back or size of the printer. Turn the printer on and let it cycle. Then plug back in the data cable. It should show a green light by the cable if you are reconnected.
May 12, 2011 | Ricoh Aficio 2228C Copier
Setting the duplex printing for RICOH Aficio MP 3351
You just need to go to printing preferences and set the tab duplex. (Opens a tab and you chose which one you want.)
If you want to put duplex by default, go to:
Start - printers - click on the right on your mouse - properties - Printer preferences - and Change the duplex. In the end just click on "apply".
Feb 24, 2011 | Ricoh Aficio MP 161 Black and White Copier
Ricoh Aficio 1015 Printer
Did you plug the router gateway address into the copier? And rember your not printing to LPT1 your printing IP address. Hope this helps. -Carl
Jul 12, 2009 | Ricoh Aficio 1015 All-In-One Laser Printer
MP 730 canon printer keeps printing out Activity Reports!
Check the printer icon at the bottom right hand corner of your screen and find out how many print jobs are in the quey. Delete all of them except the one that you are trying to print.
If you don't the printer will keep them in the quey and every time that it is turned on it will start printing old requests.
May 20, 2009 | Office Equipment & Supplies
Printing error log
reset the print jobs then check the printing refeperences.
Feb 08, 2009 | Ricoh Aficio 1515MF All-In-One Laser...
Ricoh CL2000 Printer Problems
If you are printing PDF files, that could cuase this problem. Otherwise, if your getting the issue from two different computers its possably a fualt with the Printer.
If it is a printer fualt, there proberly isnt alot you can do with this issue. You may be able to update the firmware.
Nov 04, 2008 | Ricoh Aficio CL2000 Laser Printer
Ricoh Aficio 1027 All-In-One Laser Printer Logo
85 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Bernard D'Souza
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
