Question about Roper RT21SKXLQ Top Freezer Refrigerator
Can you clean the hose with compressed air
Is it possible to clean the drain hose with compressed air after it is thawed out?
  • 311 Answers
Yes, iv'e seen it done with freeon years ago.i would not use air in a customers home because water may splater in places i didn't want.what i use is a weed eater line with a good knott in one side,then feed threw and pull out other side, knott then pulling and breaking up blockage,then flush with hot water .hope that helps God bless ,tom
Posted on Jan 15, 2009
Drains through hose and into bucket
this happens when the drain tube becomes blocked so unit overflows and water falls into bucket and not flows out tube , clean tube and drain port with compressed air (wear eye protection!!!)
Jul 17, 2015 | Keystone KSTAD70B 70 Pints Energy Star...
2002 jeep liberty heat only works at high rpm
Sounds like low flow issue. Flush and clean system, PROPERLY! Buy a flush kit, drain system, blow compressed air through, fill with cleaner/water mix, run for 30 min with heat on, drain system, blow out with compressed air, fill with water, run for 30 min, drain, blow out with compressed air, fill with 60% coolant mix.
Nov 26, 2013 | 2002 Jeep Liberty
The fridge works but water keeps filling the bottom of the fridge. Is there a way to prevent this?
Guessing this is a top mount, freezer on top. Sounds like a defrost drain clogged. Pull off freezer cover and check for ice build up. If there is, drain is clogged, thaw and use compressed air if possible to clear drain
Aug 19, 2012 | Kenmore Refrigerators
I have a Whirlpool-Estate refrigerator Model TT21AKXKQ03 and drain plug freezes causing water to drip into the refrigerator.
Something has plugged the drain tube, or has pinched it in the back rear of the fridge (yes the refrigerator is going to need to be pulled out so you can get behind it). Sometimes its just pinched on the rear bottom, othertimes something has gotten caught inside the hose. Sounds dirty, but find the drain hose on the rear of the fridge, after the frozen iceburg has thawed out, blow into/onto this hose. If you dont want to put your mouth onto the hose, alternative is compressed air. Hope this works! Please rate me. Good luck!
Jan 03, 2011 | Whirlpool Refrigerators
Liking water front door
You need to remove the panel inside the freezer compartment to access the evaporator rain line. Once accessed,you will see a drain hole. That drain has a hose leading to a pan in the back of the refrigerator; this drain is plugged an causing water from defrosting ice to drain to the pan in the back of the refrigerator. You need to unstopped that drain hose with compressed air and not chemical.
If you have any probem removed the panel inside the freezer, removed the cardboard panel to access the drain hose. Grab the hose and blow compressed air into it. Please note that you will be blowing back into the freezer compartment, and some cleaning will be necessary. The drain hole will then be opened.
Dec 16, 2010 | Hotpoint HSS25GFP Side by Side...
How can I thaw frozen heater coil hoses?
If your heater core hoses are frozen you should immediately drain the coolant out of your radiator and engine and refill it with the proper mixture. Your lucky if your heater core lines are the only thing that froze, it could have popped a freeze plug or two out of the block. You could use a hair dryer or heat gun if you need to unfreeze it quickly.
Jan 02, 2010 | 2005 Dodge Caravan
Freezer thawed, fridge leaking. Our refrigerator
Without a type of Freezer, I take it it's a froze free type ? Check the drain for food clogging it or the drain pan and hose to it ( may have a hole in pan or hose. Wrap everything but be sure to clean the unit from food that lays at the bottom .
Jul 15, 2009 | Refrigerators
Frozen drain line from top freezer to drip pan
Hi, Remove everything in the freezer. Get as much ice out as possible with out using sharp object. You will need to remove the rear evaporator panel inside the freezer and locate the drain hole below the evaporator. The safest way is to use a hair dryer. Once you can get to the drain hole and get the ice down inside the drain thawed (a few glasses of hot water usually gets the job done) Try and run a wire (I use a hose or biasting seringe) and get that drain hole flushed out real good. Sometimes it takes 45 minutes or so. After that is cleaned out, put the rear panel back on and you should be all set.
I hope I have helped you. Please let me know if I can be of more assistance.
May 12, 2009 | Freezers
hi thanks for the question the freezer is more than likely frosted up now with the door left open the drain hose from freezer is clogged shut down let thaw remove panel at the back of fridge allow 24 hrs to thaw clean out the drain tube re level the fridge so that if the door is left open the door will close by its self raise the front legs to achieve this thanks the appliance doc
Aug 12, 2008 | Jenn-Air JCD2389G Side by Side...
hi thanks for the question it would seem that the problem is with the drain hose, going to the drain pan very common problem with all fridges let the fridge thaw 24 hrs let the ice melt in the drain cavity clean after thawing make sure the hose is in the pan vac *** under neath & coils thanks the appliance doc
Jun 27, 2008 | Jenn-Air JCD2389G Side by Side...
Roper RT21SKXLQ Top Freezer Refrigerator Logo
89 people viewed this question
Top Roper Refrigerators Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Roper Refrigerator Expert? Answer questions, earn points and help others
