Question about D-Link DGL-4500 Wireless Router
My router (D-Link DGL-4500) is set up as an access point
Its blocking my laptop from my network. i need my laptop to be able to see the network now, I cant set up my slingbox otherwise. Awhile ago i set the router to be used as an access point, i believe it was on the router its self, and i cant figure out where to set it to allow me back on the network. The main computer on the network is running windows xp, and it may also be a setting there.
  • eecom May 11, 2010
    ...sorry, should also have said that if you need to 'see' the network, a wired connection to the main router should enable this. Again, good luck.
    Hi...I don't know if you've solved this problem yet?
    The only thing I would offer is that (1) you need a wired connection to the router to change its settings, and (2) since converting a router to an AP requires you to disable DHCP, this needs to be re-enabled if you want to convert it back to a router.
    BUT - I'm not sure if this is what you need? If you want to set up some new equipment and need access to the router settings, it's best to make a direct, wired connection to your main router to do this. Hope this helps a little. Best of luck with the setup.
  • 60 Answers
SOURCE: Reset password
No need to reset the password, if you know how to login to the router you can check there the security that you needed to be able to connect wirelessly.
Posted on Jun 29, 2009
  • 6 Answers
SOURCE: d-link DGL-4500 is not accessing my dsl modem
make sure the dsl modem is in bridge mode. you do this by connecting directly to the modem then accessing modem configuration page. after doing this connect the way everything was before. now go to router admin page, then setup tab at the top, then choose internet, manual setup. in the place where its says my internet connection is select PPPoE. then put in your dsl username, password and etc. save settings. this should fix the problem
Posted on Aug 25, 2009
ElDopa
  • 295 Answers
SOURCE: My Dgl-4500 shows wrong date. How can I change it?
Download the official manual (in PDF format) here: ftp://ftp.dlink.com/Gateway/dgl4500/Manual/dgl4500_manual_11.zip
And refer to page 15 (time setup). In short, login to the D-link web-interface, choose 'Tools' and then 'Time', adjust it and press the 'Save Settings' button ...
Posted on Aug 27, 2009
arvinds88
  • 108 Answers
SOURCE: I have a D-Link DGL 4500 wireless router. I have
If you don't see any devices connected in the DHCP client list on the router interface even when you are sure of the devices being connected, only a firmware update or a re-flashing of firmware can help. You can find the latest firmware available on the d-link support site. You can verify the model and version numbers and download the corresponding firmware. This is only fix.
Posted on Feb 06, 2010
eagle338
  • 4889 Answers
SOURCE: Blue Power led Blinking. But nothing shows up on
You mean the DSL and LAN lights are not on?
Posted on Nov 07, 2010
Hello, My D-Link DGL-4500 router won't work properly. The wireless portion will not work. I know the Username & Password. But no device I have will connect to it wirelessly. It'll connect...
If the default password on the D-Link has been changed then-
To reset the D-Link back to the default settings -
Press and hold the RESET button at the back of the router with the power ONuntil the LEDs flash at the time the release the RESET button.
Connect a LAN cable from the D-Link to your laptop/computer's LAN port, openthe browser on your laptop/computer and enter the D-Link's configuration URL..
http://192.168.0.1
The default login = admin
The default PW = blank (just press Enter) You can now change the default admin password.
You can now configure the wireless settings. Now configure the wireless card in your computer/laptop withthe router's wireless settings.
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Sep 03, 2011 | D-Link DGL-4500 Wireless Router
How do I get into the routers homepage to change some settings so I can run a wireless internet connection to my laptop while my Playstation is hard wired. I have DGL 4500
To get into the D-Link DGL 4500 router homepage, simply open an internet browser window and type in the following address:
http://192.168.0.1 and press Enter.
When the login window appears, set the user name to Admin and leave the password box empty.
Then, click Login to continue.
Here is the link to the PDF version of the User Manual:
http://www.dlink.com/-/media/Consumer_Products/DGL/DGL%204500/Manual/DGL%204500_Manual_EN_US.pdf
Jul 29, 2011 | D-Link DGL-4500 Wireless Router
Is there a limit to the number of login attempts that can be made or can hackers make continuous attempts until they get in?
There is no limit to the number of login attempts, as far as I know, but there are ways to block hackers outside of your network...
You can use MAC Filters (Media Access Control) to allow LAN (Local Area Network) computers by their MAC addresses access to the Network (p. 44 in the user manual).
You can also use the built-in Firewall Settings for protection from the outside world (p. 45 in the user manual).
There is also an Access Control Wizard (p. 40 in the user manual).
Here is the PDF link to the User Manual:
Apr 15, 2011 | D-Link DGL-4500 Wireless Router
I just bought a D link dgl 4500 router and it works fine most of the time. Tonight and one other night before it will reset my wireless network almost every five minuets. I have reset both the modem and...
Make sure you have the latest firmware as this might help with your dropped connections. Also try to make a DHCP Reservation for each computer connected to your network (p. 32 in the User Manual), as that can also help prevent dropped connections.
Download the latest firmware ver. 1.23NA to your local computer. Connect your DGL-4500 router via a wired connection (ethernet) to your computer and install the firmware update following instructions in the user manual.
Firmware link:
ftp://ftp.dlink.com/Gateway/dgl4500/firmware/dgl4500_FW_123NA.zip
Feb 23, 2011 | D-Link DGL-4500 Wireless Router
I have cable internet and how would i connect the DGL-4500 wireless router to cable???
Turn the cable-modem off.
Turn the router off.
Use an Ethernet cable to connect the network-port on the cable-modem to the 'WAN' or 'Internet' port on the router.
Use another Ethernet cable to connect the network-port on your computer to one of the 4 'LAN' ports on the router.
Turn the cable-modem on.
Wait for its lights to settle-down to a repeatable pattern.
Turn the router on.
On your computer, you should have Internet access.
Feb 21, 2011 | D-Link DGL-4500 Wireless Router
My husband bought a dlink router (it says dgl-4500 on it) and i cant figure out how to use it to get wireless internet for my new laptop....i have three "codes" he wrote down- a "router pass", a "network...
Router password is the password to access the router settings.
SSID is the network name. When you try to connect to the wireless network on your laptop, you will see this network name.
If your network is secured network then it will ask you for the network key or the password. You need to enter the ' security key '.
Click Here for step by step by instructions
Sep 11, 2010 | D-Link DGL-4500 Wireless Router
Feb 05, 2010 | D-Link DGL-4500 Wireless Router
I am trying to get my laptop connected wirelessly to my dgl-4500 router. It keeps saying connection time out?
You will need to check the wireless settings of the router
is there any computer connected to the router ?
If yes then you can open the router set up page on that computer.
Router set up page is the page where you can check all the wireless settings of the router.
Click here for step by step instructions
Jan 11, 2010 | D-Link DGL-4500 Wireless Router
D-link DGL-4500 is not accessing my dsl modem
Apr 20, 2009 | D-Link DGL-4500 Wireless Router
Connection
Hello Krmn,
Are you running windows Xp or Vista ?
George
Sep 24, 2008 | D-Link GamerLounge DGL-4300 Router...
D-Link DGL-4500 Wireless Router Logo
1,170 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
