Question about GPX ML648B MP3 Player
Error Installing Utilites Software
I get several errors stating that the MP3 Player Utilities 4.19 failed to register
  • 8,596 Answers
. Connect your ML648B to your computer with Windows XP or later.
2. By default your computer will recognize ML648B as GPX MTP Device. (Wait for few seconds to a minute allowing your Windows computer to recognize and install necessary drivers for the device for first time as MTP Device.)
3. Press the POWER button from top of your ML648B, to change it to USB mode connection. You will also see USB on the screen of ML648B. (Wait for few seconds to a minute allowing your Windows computer to recognize and install necessary drivers for the device for first time as USB device.)
4. ML648B will now mount 2 drives, one as Tools (as CD-Drive) and second as Removable Disk (Drive) – under My Computer on your Windows Desktop.
5. Double click & open Tools, and run Setup.exe to start installing Video Conversion Software tool.
6. Select defaults options and finish the installation by clicking on Close or Finish.
7. If asked, click on Continue Anyway on Windows XP or Install this driver software anyway on Windows Vista.
<!--[if !supportLineBreakNewLine]-->
<!--[endif]-->
Posted on Feb 15, 2009
How do i fix a disk error on a mp3 player
There are several possible solutions to your problem.
First, try restarting your MP3 player.
Second, try connecting it to your computer to sync with your music management software.
If the first two options don't work, then you need to format the MP3 player because some of the data is potentially corrupted. Be sure to back up your music before formatting the MP3 player.
To format the device: Plug it in to your computer In Windows Explorer, right-click on the device and click Format. Perform a quick format.
After formatting the device, reload it with music and the disk errors should be gone. If these solutions do not work, then your problem is probably due to a hardware failure. If the hardware has failed, your best option is to consult your warranty information.
Mar 01, 2011 | Audio Players & Recorders
PC not downloading device driver software
I have the same problem, except that I can get sync if i power the unit down after discoeccting the failed attempt to recognize USB device. Sometimes the MTP device prompt shows up and then doesnt when I try again, I solved this by downloading codecs and utilites for windows Media Player. I had ver,.10, went to 11. This seems to be better as the available downloads are more effective,
Now i can sync, still doesnt recognize all the time, but just unplugging it and restarting windows media player with the device unplugged seems to work. Use the Settings in WMP and open the "available devices or supported devices on web " and you can download free updates, codecs, etc,,, that got mine working.
Jan 03, 2009 | SanDisk Sansa c250 (2 GB) MP3 Player...
Format error in LG MP3 player CM60022 ACT_V9.1.52
first, go here and download the utility:
http://mp3-player-utilities.software.informer.com/
Then:
Start up MP3 Utilities Disk Tool.
Ensure that you select LOW Format Type.
Next, go to the Partition and Encrypt tab as shown below.
Slide the Partition slider to the Left, and click on Start.
You will repeat the process and the "Complete setting disk partition!" dialog box would appear.
Then Format again your player on Windows..
Jul 21, 2008 | iLO (2 GB) MP3 Player
Registering
What is your reason for registering? No need to register your mp3 player. I know someone who did not register his player and it worked just fine.
Jun 29, 2008 | Sony NW-E002 MP3 Player
Ilo mp3 player
This could be caused by several issues - I will mention two likely possibilities. If you tell me what music service you are using, I can tell you more.
If you are getting a file format not supported error message, then the songs are in a format that the Mp3 player doesn't recognize - you can read my 2-part article in the tips & tricks section to get more info about this.
If Windows Media Player is not recognizing the player, then that would also cause the sync to fail. Unplug and replug, try again. If that fails, uninstall and reinstall the player and all software, then replug the player into the computer.
Jun 15, 2008 | iLO (2 GB) MP3 Player
Mp4 player defect and disk error
initially,i was experiencing format error when i tried to open somefiles but i tried to format the player using windows, but i guess itmessed it up because i started having disk error2_bing.gif messages. Now, i canteven use the mp4player or look for a possible way to reformat it. iahev even tried mp3 utilities disk tool but it didnt work. Please helpme the firmware version is 2007/02/14 9.1.51 7515_2.2TFT 2007/01/25
please help
Jan 06, 2008 | Audio Players & Recorders
Installing ilo 2g software
This player is useless - you probably have Vista - it is not compatible
Dec 26, 2007 | iLO (2 GB) MP3 Player
PD-6030 MP3 player flash error message
MyMusix's PD-6030:
If you have a Windows-based computer,
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If that fails,
Check the battery polarity. (+ and - must be in correct psoition)
Set the hold button to the unlock position.
Check if the file system is NTFS. If yes ,format it to FAT or FAT32. - Connect player to computer, click my computer, right click on icon of mp3 player and select format
If that fails,
go to www.mymusix.com to see if the latest software update will correct the problem
-Tha Mp3 Doctor
Nov 08, 2007 | MyMusix PD-6030 MP3 Player
Transfer error - Disagreement between player and software
I had the same issue and I eventually re-formatted the player. Once I had finished that, it seemed to work again, letting me add songs.
Feb 25, 2007 | Rio Nitrus MP3 Player
GPX ML648B  MP3 Player Logo
151 people viewed this question
Top GPX Audio Players & Recorders Experts
Are you a GPX Audio Player and Recorder Expert? Answer questions, earn points and help others
