Question about Dynamode (HT809STP) Networking Hub
I have a Dynamode 6004 W-G1 wireless router
The range and signal strenth is very poor unless i am within 3 feet of the router?
  • 6,487 Answers
To improve wireless signal from your wireless router you can try changing the wireless channel of it from the router setup page, set the wireless channel to the highest one so it will avoid interferences on your location........
Posted on Jan 15, 2009
Sonos wont work with Dynamode R-ADSL-C4-W-G1
You have your Sonos bridge hardwired into your Dynamode correct? Your bridge needs to be physically plugged into your router at all times, it creates the SonosNet network that your Sonos players operate on.
Dec 25, 2012 | Computers & Internet
How do I secure my Dynamode BR 6004 WG1 Iam a
To secure your wireless network from unauthorized access, you need to at least configure the wireless router with encryption, and the SSID, and change the router's default login password.
Please follow these instructions :-
To connect to your wireless router, it needs the router’s wireless settings configured and also needs the wireless cards in all the laptops and or computers to be configured with the router’s wireless settings. Then the laptops and desktop computers can communicate with your wireless router.
To set-up and secure the wireless router from unauthorized access, follow these steps: -
1. Connect the wireless router to your computer with a LAN cable.
2. Start your browser and enter the router's configuration URL IP address.
3. Enter the router setup, login and password
4. Change the admin password
5. Go to the wireless settings and change the default SSID and turn off SSID broadcast.
6. Setup encryption key the strongest is WPA2 (if not then WPA). The encryption key can be easily set up using a passphrase (it can be an alpha numeric phrase or words).
7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
8. Record the settings you have made and keep it in a safe place and Save the settings.
9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router.
10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router wirelessly.
To access the Internet you need to connect the DSL or cable modem to the WAN (Internet) port on the wireless router.
Jul 23, 2010 | Dynamode (R-ADSL-C4-W) Wireless Router
I have a D link router a outdoor antenna which isadvertised for a 3 mile range. I am about 2oo yards from the antenna. My computer indicates a the signal strenth as good but i keep dropping off the net....
please observe signal strength as when you are connected to network and till you drop off, there may be distraction in signal strength while you are connected and when you check it again, it comes to good again.
Jun 27, 2010 | D-Link RangeBooster G WBR-2310 Wireless...
Securing my network. I have a Dynamode br-6004 w-g1
Hi
In order to secure your wireless network you need to do the following settings on your router....
  1. open interner explorer
  2. in address bar type : 192.168.1.1
  3. username : guest , password: guest
  4. go to wireless settings
  5. select the name of your network, enter security key & click apply
  6. now your network is secured
Enjoy
Apr 08, 2010 | Computers & Internet
It seems that the signal is strong next to the router, but drops to 1 bar within 30 feet away? What is the most likely solution.
Routers generally have a strong signal for up to 10 meters. However no obstacles should be in the way. 30 feets is about 10 meters so the router is loosing its signal strength. If you would like to extend the strength of your router you can buy a range expander. This device acts as a repeater of the signal so from 10 meters you can go to 15 or 20 meters.
Mar 08, 2010 | Hawking Hi-Gain 802.11g MIMO Wireless...
My BR-6004 W-G1 dynamode is unsecure,how do I secure it?
You need to change the wireless security mode.
Have you got your manual still?
Nov 22, 2009 | Dynamode (R-ADSL-C4-W) Wireless Router
Connecting to the internet with wireless router
Here's how to connect it.
PC > Connect to port 1 of the router
Modem's Ethernet > Connect to router's Internet or WAN port
Then do a power cycle, unplug the power to the modem and router. Wait for 30 seconds then plug the modem first, wait for the lights to go solid, then power up the router. Your laptop should see the wireless signal now.
Jan 12, 2009 | Computers & Internet
Dynamode br-6004 w-g1 maximum signal available, but won't Fire up computer
is this unit being used a central power supply? is there a 21 pin connector in use?
Jun 21, 2008 | Computers & Internet
Connecting my dynamode 6004 W G1 wireless router to modem
Cable modems and routers must be turned on in a specific way. First, unplug both the router and modem. Next, plug the ethernet cable from the modem, into the cable router, and unplug the cable from the modem to the computer. Next, turn on the modem, and wait for all of the lights to stay static (usually there's 4 lights, the main one we're interested in, is the status light). Next, plug in and turn on your router. You should now be able to access the router and configure it for your internet connection.
May 18, 2008 | Computers & Internet
Dynamode BR-6004 W G1
Try holding down the reset switch on the back with the router turned on for about 10 seconds or more.
the following info was found at http://www.help2go.com/component/option,com_forum/Itemid,32/page,viewtopic/p,126642/
i believe the default password/username for your router is:
username:guest
Password:guest
www.portforward.com wrote:
You should see a box prompting you for your username and password. Enter your username and password now. By default both the username and password are guest. Click the Ok button to log in to your router.
this info was taken from
http://www.portforward.com/english/routers/port_forward ing/Dynamode/BR6004W-G1/WinMX.htm
Mar 15, 2008 | Dynamode (HT809STP) Networking Hub
Dynamode (HT809STP) Networking Hub Logo
149 people viewed this question
Top Dynamode Computers & Internet Experts
Prashant M
Prashant M
gharibeh
Level 1 Expert
Are you a Dynamode Computer and Internet Expert? Answer questions, earn points and help others
