Question about Brother LS-2125 Mechanical Sewing Machine
No lower thread
When I sew, the machine is not picking up the thread in the bobbin. I think it is in there correctly, and I pulled the bobbin thread through the machine, under the foot.
    Scholar:
  • 69 Answers
Make sure your needle is in correctly...flat side to the back and that it is not bent or damaged. Make sure to double check the thread is going through the tension in the bobbin case before inserting the case into the machine.
Posted on Feb 07, 2009
The needle with top thread couldn't draw the bottom thread from the bobbin to ready the machine for sewing
Are you saying that the upper thread is not pulling the bobbin thread up to the top?
Install a brand new needle.
Remove the thread. RAISE the presser foot and rethread from the beginning--allows the thread to seat completely in the upper tension disk.
Check that the bobbin thread is inserted in the bobbin case facing the correct direction and that the bobbin case is threaded correctly through the bobbin case tension. Be sure to leave at least a 6" tail of thread on both the upper and lower threads.
Retest.
If it is still not picking up the bobbin thread, the bobbin case may be defective/malfunctioning or your machine probably needs professional service.
Feb 27, 2016 | Sewing Machines
The needle is not picking up the lower thread, I have cleaned the machine but the bobbin is not being picked up
Doesn't pick up bobbin thread
1. The bobbin may be in backwards.
2. The bobbin thread & top thread need to be pulled to the back before starting the stitching
3. You need a ballpoint rather than universal needle to sew on t-shirt knits.
4. the needle is in the machine backwards
5. Make sure the needle is the correct one for the fabric being sewed
6. Needle inserted wrong in the needle holder
7. Warped needle
8. Warped bobbin
9. Also could be a timing problem
Feb 10, 2016 | Sewing Machines
How would to insert the bobbin in the sewing machine brother VX 1400?
There is not much of a secret to inserting a bobbin in a sewing machine. A couple of things to check, the thread from the bobbin should be pulled through the slot of the carrier, and make sure the thread comes through the sewing hole by manually lowering the threaded needle and then lifting it out of the hole again after it has picked up the thread from the bobbin. The video link posted below is useful if you have a Brother sewing machine.
If the stitching is still not right then check that the needle is fully inserted in its housing. (Push the needle up as far as it will go then tighten the screw.)
How to wind and install the bobbin and thread the sewing machine PART 2...
Aug 24, 2014 | Sewing Machines
The upper thread will not pick up the bobbin thread
You should do this by putting very slight pressure on the foot control (or turning the wheel by hand) with the machine's pressure foot up. Then pull the threads by hand to the back of the machine. If the upper thread does not catch the lower thread then the bobbin is not correctly threaded in the bobbin case.
Oct 16, 2013 | White Sewing Sewing Machines
Needle goes down but don't pick up the bobbin thread. It come up and tell me that my upper or lower thread is cut.
try changing the needle
try rethreading the machine top and bobbin
make sure to use every thread guide-this is improtant for the
thread tension
make sure the bobbin is turned correctly in the bobbin case
also could be a problem with the computer motherboard
or there could be a problem with the timing
Dec 03, 2012 | Brother PE-150V Computerized Sewing...
Lil sew & sew lss202 bobbin threading?
Drop bobbin in carrier such that the thread and bobbin form "P". When you pull on thread the bobbin unwinds counter clockwise. Lay loose thread in groove on plate coming toward front of machine. Replace cover. Rotate hand wheel towards you to pick up thread. Pull upper and lower threads to rear of machine under presser foot.
Sep 08, 2012 | Michley Lil Sew Mechanical Sewing Machine
I have a Brother sewing machine and whenever I try to pick up the bottom thread (or when I try to sew), the upper thread gets caught around the bobbin case causing a huge, knotted mess. It's just all...
Check your top tension dial setting is on 5, as this sounds like the thread is not in tension fully so is looping up around the rotary hook and not being held back by the tension device. Is the pressure foot lowered (this turns the tension on) fully and is the thread through the tension discs correctly. Lower the pressure foot and pull the top thread from below the tension dial, it should feel firm to pull, if it comes out easy, its not undertension, device could be faulty and machine will need to be serviced.
Also, check that the bobbin case is fully inserted into the rotary hook in the correct position, bobbin is in and rotating the right way and thread is into the tension spring fully.
If you have the manual pull it out, and carefully check the threading up instructions and follow on your machine - it is probably one of these things causing the jamming.
May 23, 2011 | Brother LS-2125 Mechanical Sewing Machine
My bobbin thread will not thread. When I bring the needle down, it comes up without the bobbin thread. The mechanism moves, but no thread. How do I fix this problem?
check the bobbin to make sure it's not warped
check the needle to make sure it's not bent-roll on flat surface to see if it roll correctly
make sure the bobbin is in the bobbin case correctly
make sure you have a 3 to 4 inch tail on the bobbin-so the upper thread can pick it up easily
make sure you have a 3 to 4 inch tail on upper thread also as it picks up the lower thread
or you can hold the upper thread with your hand to the side of the machine & use the handwheel to lower the needle as it picks up the lower thread
pull both threads to the back behind the needle
make sure there is no lint or loose threads in the bobbin area
Sep 01, 2010 | White Sewing 2200 Multi-Tasker
Needle will not pick up bobbin thread when sewing
double check the upper and lower tensions they often need to be changed to suit types of fabric and threads
Dec 12, 2009 | Singer Sewing Machines
Top thread will not pick up bobbin thread makes a big loopy mess
This is sometimes caused by the upper thread not threaded correctly. You need to thread it first with the pressure foot in the up position. You need to "floss" the thread into the clear plastic guide as this is where the tension is. The tension should be set to E for embroidering. Also make sure you get the bobbin thread in the slot on the bobbin case. Also, lower your pressure foot before you begin embroidering. Hope this helps!
Sep 20, 2009 | Singer CE-100 Futura Computerized Sewing...
Brother LS-2125 Mechanical Sewing Machine Logo
61 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
