Question about Alpine iDA-X200 Car CD/ MP3 Player
Subwoofer doesn't play through ipod, only radio and cd's
I have a 2002 jeep wrangler that has a factory sub under the center console. Everything works great with the Alpine head unit but when playing songs off the ipod the sub does not play. It is hooked up correctly b/c it will play when the radio or a cd is playing. Is this an ipod setting or something wrong with cd player? How do i fix this problem? i have the same problem with my aftermarket subwoofer in my celica. the guy at best buy said something about the wire going from my amp being solid blue needing to be blue with a white stripe or something... i couldn't really follow tho... where would u buy a new wire for that?
  • Kate5686 Feb 16, 2009
    I had the same problem. What was wrong with mine was i had a thin blue wire coming out of my sub that needed to be connected to the wire harness. I had it connected to the solid blue wire in the wire harness (which seemed logical at the time) but it actually has to be connected to the blue w/ white stripe wire in the harness. Now my sub works great with both the ipod and radio.
  • mshullen Mar 30, 2009
    I have a jensen VM9412 touchscreen, my sub works fine when the radio is on but when i put a CD in the subwoofer stops working, does anyone have any suggestions?
Hook up the remote wire from the head unit (grey w/ orange stripe) to the power antenna wire (blue) on the wiring harness adapter.
Posted on Apr 17, 2009
  • Blue Rubi Apr 17, 2009
    Its not the MP3 quality or the source tone feature or the eq.
    I take that back, the wire color on the harness is blue and like me, you probably hooked it up to the blue wire from the head unit whereas it should be connected to the blue and white wire (remote / power antenna).
  • 3 Answers
Hi,is the subwoofer works with radio then it must be the quality of your mp3's that is poor, diffrent sources do not change the subwoofer output....
also it could be the source tone feature, the unit will remember diffrent bass&treble and sublevel settings for diffrent sources, maybe the bass is turned down, also check the EQ on the i-pod, that may be affecting to sound?
Posted on Feb 16, 2009
2002 X Jeep Wrangler radio won't work CD still comes in and out but nothings plane
all features dead? only the eject and insert works
radio dead, AM and FM?
does dial light up, and show that search stations scans and stops
on a station, (regardless of sound or not) if not ? all that is dea check fuses.
if fuse are good, its a bad head end.
time to upgrade to media center, no?
Nov 12, 2014 | 2002 Jeep Wrangler
CD STUCK IN FACTORY RADIO 2005 JEEP WRANGLER X SERIES
does the cd make a clicking sound when you try to eject the cd?
Mar 02, 2011 | Car Audio & Video
I need a wiring diagram for a 2010 Jeep Wrangler Stereo, I'm trying to install an aftermarket deck.
If it isn't already cut, please do not cut the factory connector off the wires that plugged into the original radio. Instead, puchase the correct pigtail for your vehicle, it will plug right in to the connector from the factory radio and colored wires that match the wires on the deck come out of the pigtail. This simplifies everything and leaves you with the option of reinstalling the factory radio at a later point.
Feb 28, 2011 | Car Audio & Video
I have a Kenwood kdc-mp342u car cd player installed in my truck. I have subs hooked up to it and everything was working fine until i had to reset my radio and when i reset it the "sub Level...
Subwoofer output: Hold the (AM-) button down for at least two seconds. You can do this function when "SWPRE" in is set to . The SWPRE (Switching Preout) Switches the preout between rear output ("R") and subwoofer output ("SW").
Nov 10, 2010 | Kenwood KDC-MP342U Car CD Player
Where would I find the heater blower resistor under the hood of a 2002 6 cylinder Jeep Wrangler with factory air?
Generally you won't find the resistor under the hood on Jeeps. It looks like a flat fixture made from the same material that circuit boards are made from and has three or four wires plugged into the center. Look under the dashboard on the box where the heater is on the passenger side. Normally behind where the glovebox is located.
Jun 29, 2010 | 2002 Jeep Wrangler
Hi, I have an 12 inch subwoofer who doesn't want to play. It play when i plug my ipod through the amplifier and i know that the problem comes from my head unit. Everything is right connected behind th
The i pod should play through your head unit when you scroll through the SOURCE button and land on AUX.-thats how it works on mine but yours might be different. Good luck
May 20, 2009 | Clarion DXZ775USB CD Player
Factory cd player doesn't play aftermarket burned cd's
What format are you burning them in? CDA or MP3 most Factory units will only play CDA format, just pick you up a copy of Nero and choose Aduio CD, it will convert you MP3 format to CDA and you should be able to playthem with no issue, the CDA format also works in the old portable CD players as well...
Hope this Helps,
David
If my solution was helpful please rate accordingly.
Mar 17, 2009 | 2002 Jeep Wrangler
Subwoofer does not turn on when playin usb or cd or aux
I have the same problem..Have you guys sorted it yet?
Mar 12, 2009 | Car Audio & Video
Jensen VM9311TS wont play cd
you are probably mising to power on the factory amp from the vehicle
Nov 04, 2008 | Jensen VM9020TS Car DVD Player
VM9311TS Subwooofer problem
you wired the remote wire up to the solid blue wire on the dvd player.....you need to put it on the blue wire with a white stripe......that should make it come on for everything....the solid blue wire is if you have motorized radio antenna. it turns it on
Sep 04, 2007 | Jensen AM/FM/MP3/DVD/CD iPod-Ready...
Alpine iDA-X200 Car CD/ MP3 Player Logo
975 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
