Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Garage door not closing all the way
It opens fine, but does not close all the way down with remote. It comes down half way and then goes back up again - we have to keep the button pushed to make the door go all the way down. The two sensor lights seem to be working fine (none of them is red; one of them is green and the other yellowish).
Any help; idea to fix it?
  • 1 more comment
  • hskhan739 Jan 15, 2009
    It is Craftsman, and has two sensor lights located about 3 inches high at each side of the door wall.
    both sensor lights are on. when I put my hand infront of one, the light turns off. how do I realign them or make sure they are aligned.
    Thanks a lot; wiped off the lens and it is working well now. Great Support from you - Thanks again
    Champion:
  • 244 Answers
What brand. you described three sensor lights/ Craftsman/Liftmaster have two, Sounds like saftey beam problem,
Posted on Jan 15, 2009
  • 3 more comments
  • marty metzger Jan 15, 2009
    do you have a rope on door for pulling it down manually. they can dangle in front of eyes when closing.is light bulb on motor flashing when door goes up? That is saying something is in way of sensors. Wipe off lens. Realign, even if led's are glowing. whould solve problem
    loosen wind nut and sight with eye eye. licj finger and wipe off lens too.
    made typo. light would flash when door reverses after going down.
    should say wing nut. i need to improve typing.
    you are welcome.
  • 3197 Answers
SOURCE: Garage door will open with remotes, but not with the wall switch
Sure sounds like the wall control is bad. Very common problem.
Posted on Jun 12, 2009
  • 3197 Answers
SOURCE: Have to hold the push button inside my garage to close garage.
You have a door sensor problem. Make sure the sensors are pointed at one another and the small light on each one is lit and not blinking. Also check the wiring.
Posted on Jul 20, 2009
  • 3197 Answers
SOURCE: We can't close our garage door
Make sure neither light on the sensors is flickering. Tweak them a bit to make sure they are aligned properly.
Posted on May 17, 2010
Testimonial: "Thank you for the quick response. The lights are not flickering. We can now open with both remotes but cannot close the door with them. We have to us the wall unit. "
  • 3197 Answers
SOURCE: Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+: My craftsman 1/2 hp garage dood does not close whe...
If the main light flashes 10 times when you try to close the door it is a sensor problem. Make sure they are not flickering ever so slightly and that they are not loose on their brackets. Tweak them a little bit.
Posted on May 20, 2010
  • 3197 Answers
SOURCE: My craftsman 1/2 hp garage dood does not close whe...
Make sure the brackets for the sensors are tight and the small light on the sensors is not blinking ever so slightly. You also might try shading the sensor so that the sun is not shining directly into the lens.
Posted on May 24, 2010
Lift master formula I will not close, only goes half way down, but fully opens. Worked fine until my wife closed the door on the car, after that it would fully close
I had this problem as well with the door opening just fine but was not closing when using the remotes or when breifly pressing the wall mounted control. The door would close only when using the wired wall mount control. I have experienced this problem with other garage door openers I've had in my previous homes and it was always caused by sensors at the bottom of the door tracks being either misaligned or the lenses were dirty. In this case, and it was just a moment ago today, I simply cleaned the sensor lenses and then the door began to function properly. Give it a try.
Jan 28, 2013 | liftmaster Chamberlain Garage Door Opener...
My garage door will only open half way. It appears to be getting stuck when it is opening.
If you haven't gotten your issue fixed yet... I had the same problem (stopped opening half way when using the remote, went down fine, could lift/close manually fine as well) and this happened on our first cold weather day of the year which was very telling. Anyhow, there are two gauges/dials on your garage door opener unit itself (above, where the light is) which controls how much torque/strength your door uses to open or shut through resistance. I turned mine up some and it now works fine; what likely happened was that the metal tracks or the wood frame condensed in the cold and was providing just enough resistance to stop it when opening - as they have a security device built in to stop if they meet any resistance. Hopefully this helps!
Oct 27, 2012 | Sears Craftsman LiftMaster Chamberlain...
Can open my garage door with the remote just fine, but it will not close the door. When I try to close it from the button inside the garage I have to hold it down until the door is all the way closed,...
Check your door sensors. Make sure they are pointed at one another and the small light on each one is lit and not flickering ever so slightly. Tweak them a little. If you cannot get both lights to come on you have bad sensors.
Jun 27, 2011 | Sears Craftsman LiftMaster Chamberlain...
The motor runs but it only opens a few inches and slowly goes back down its a chamberlain whisper drive model HD900D
Hi. I have seen this before, although usually not from chamberlain garage door openers.
Pull the release cord that unlocks the door from the opener, and manually open the door ALL the way open.
Then lock back in place in the open position.
Then use automatic opener to shut door.
It will close very slowly, but should close all the way.
Then, open the door again using the remote, and the door will once again open slowly, this time it should open all the way.
Then close door with remote, and door should now close as it is supposed, with the proper speed.
The slow opening and shutting is the system position sensor resetting itself.
This is why your door is acting up.
I would also look up by the belt drive connects to the front of the garage door opening, to make sure there isn't any dirt, cobwebs, or other obstructions on the sensor that may cause it to re-close the way it does.
Jan 24, 2011 | Chamberlain 1/2-HP Whisper Drive Belt...
My mom & I each have a Craftsman garage door opener at our respective homes & live @ 15 minutes apart. Our openers are about 13 to 14 yrs old. The past two yrs. we've both had the same problem. ...
If the main light flashes 10 times when the door reverses to the open position it is a door sensor problem. Make sure both lights on the sensors stay on and don't flicker while the door is moving and the sensors are firmly attached so they don't move. Tweak them just a bit.
Nov 09, 2010 | Sears Craftsman LiftMaster Chamberlain...
I can open my garage door with the remote just fine, but it will not close the door. When I try to close it from the button inside the garage I have to hold it down until the door is all the way closed,...
Make sure your door sensors are pointed at one another and that the small light on each one is lit and not flickering. Tweak them a bit. If you cannot get both lights to come on you have either a bad sensor or the wiring to them.
Sep 07, 2010 | Sears Craftsman LiftMaster Chamberlain...
I am having the same problem. My door will close if I hold the garage door button down in the garage, but if I try to close it with the remote it goes down a quarter of the way, the light flickers then...
You have a door sensor problem. Make sure the small light on each sensor is not flickering ever so slightly. Sometimes very hard to see. Tweak them just a bit. The color of the sensors is normal.
Feb 09, 2010 | Sears Craftsman LiftMaster Chamberlain...
The door reverses back to open position instead of closing
SOUNDS LIKE A SENSITIVITY ISSUE UNHOOK THE DOOR AND TRY IT MANUALLY TO BE SURE IT DOESN'T BIND OR IS TOO HARD TO OPEN OR CLOSE.
IF ALL IS WELL CHECK THE SENSITIVITY SETTINGS ON THE BACK OR SIDE OF THE OPENER.
YOU WANT THIS SET AS LOW AS POSSIBLE AND STILL OPERATE THE DOOR WITHOUT REVERSING.
NOTE: THE FULL RANGE OF ADJUSTMENT IS ONLY ABOUT 3/4 TURN SO MAKE A VERY SLIGHT ADJUSTMENT AND THEN TRY IT AGAIN.
HOPE THIS HELPS
Feb 20, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears craftsman 1/2 hp garage door troubleshooting
My garage door opener will start to close then stop and go back to the open position. If I put pressure on the door as it is closing sometimes it will close all the way and sometimes it will return to the open position. Can you help me. Thanks pbstation771@verizon.net
Aug 18, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
1,083 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
