Question about One For All URC-3605 Remote Control
Dont remember the code to set my tv with this is a remote that has not been used in a while
  • 3 Answers
Http://www.hifi-remote.com/manuals/manual.shtml?URC-3605-codes
Here is the list of codes for the URC-3605 remote control.
Hope this helps, you must have Adobe Acrobat Reader installed on your pc to view.
Posted on Feb 15, 2009
Sky remote code for model UE40J5100AK
Programming the remote control
To control your TV firstly switch on the TV set, point the Sky remote at the TV, press the "TV" button on the Sky remote, then press and hold the "Select" and "Red" buttons together until the red light at the top of the Sky remote control flashes twice. Press "TV" again then enter the code for the TV listings below (Use the 4 digit codes from the left hand column), the red light will flash twice if a valid code has been entered. Press TV then the standby button on the Sky remote control, this should switch the TV set off, if so then press the "Select" button to store the settings. You should now be able to switch the TV back on and use the volume control button from your Sky remote.
If the TV did not switch off then it may require a different code, you can either start again using one of the alternative Direct codes below or continue with this process by continuously pressing "TV" then "Standby" then "TV" then "Standby" etc until the TV set switches off. This will provide a manual scan for variations within that product code.
If you are still unable to control your TV from the remote control see: Programming The Sky Remote or go to Sky's official website where you can see if a particular remote control version number will operate your make of TV, this can be found at:Skyplease remember to use your back button and come back to us.
www.electro-medical.blogspot.com
Samsung brand code 0060
3 digit code for Samsung
065, 584, 037, 245, 476, 398, 516, 292, 318,037
Oct 13, 2015 | Samsung Televison & Video
How do i get my LM-1750 remote control to operate my sylvania 6427FF television
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Pull up older posts.
http://electrohelponline.blogspot.com/
http://remotesearch.blogspot.com/
Sep 09, 2014 | Sylvania 6427FF TV
QuantumFx Rem-200 remote codes for philip TV no set up button
Hold down the tv button and then press and hold down the power key untill the light comes back on then press and release the power key untill tv comes on or goes off then press the (dvd) stop key and it is programed
Aug 25, 2012 | Universal Remote Control URC-200 LCD...
The nursing home my mother is in has a Toshiba 13A24 TV in ;her room. The can't find the remote and I wanted to get her a universal and be able to set it up for her What do you advise
Hello, a Universal remote should have the codes already set for the Toshiba so it shouldnt be too hard, just follow the instructions. Just remember that some of the cheaper remotes dont have all the codes.so make sure you get a good quality one,she deserves it!
Mar 23, 2011 | Toshiba 13A24 13" TV
I have a mitsubishi cs-26ex1 tv and the parental code is set but I dont have the original remote or a user manual to reset the code. How can I unlock the tv?
well first lets narrow this down so the tv is already holding a code you will need the old code to re-enter a new 1 okay if the code is known you may be able to set with the menu button goto pc option try to use the channel up and down and volume see if this will help now lost remote may try a universal remote make sure it has the menu option on it ,also when entering code numbers some have over 5 or so codes okay the tv may respond to 1 code but not let you use the menu so try each code also if you cant remember the code its not to good you will have probally no choice to take to tv shop okay good luck shad
May 06, 2009 | Televison & Video
JVC code to set my remote
Brand codes for universal remotes are determined by the remote control manufacturer, so there's not really "a code for JVC" that anyone could tell you. You could try looking on the remote manufacturer's website to see if they have the information available. Or you could simply purchase another remote, and you'd have a fresh set of instructions.
Dec 14, 2008 | JVC AV27F476 27" TV
I dont have vchip code fof my used tv
1. Hit the Menu button on the TV. 2. 'INPUT SECRET No.' should appear. 3. Press and hold both VOL (+) and CH DOWN on the TV set simultaneously until the message 'INPUT SECRET No.' disappears. 4. The vchip settings should be disabled now and the Parental controls menu should be presented, 'disable' Status if need be
Remember do it on the tv not the remote
Nov 14, 2008 | Televison & Video
Code
Orion Code is 035
The Instruction given is for programming a remote to control a TV set. Please substitute CABLE or VCR in place of TV to program for other devices.
1.Find the three digit code(s) for your TV set.
2. Manually turn on the TV set.
3. Press and hold the CODE SEARCH button until the indicator light is lit. Then release the CODE SEARCH button. (The indicator light is located above the TV button).
4. Press and release the TV button. (The indicator light will blink and then remain lit).
5. Enter a three digit code found at step 1 using the Number Buttons.(After the code is entered the indicator light will turn off).
6. Aim the remote at your TV. set and press the OFF/ON button. If your TV. set turns off, then proceed to step 7. Otherwise, repeat step 3 to 5 using the next code on the list. Press CHAN up button to double check for accuracy of the code. the programming is complete if the TV set responds by going up a channel. Otherwise repeat steps 3 to 6 using the next code on the list.
7. Press CHAN up button to double check for accuracy of the code. the programming is complete if the TV set responds by going up a channel. Otherwise repeat steps 3 to 6 using the next code on the list.
8. Try the code search method If there is no more code left to try.
Dec 16, 2007 | Televison & Video
Universal remote codes
Hi jamie, did you remember the procedure to scan for the codes ? Normally if your TV is not listed on the manual, you can execute the search mode ponting to the TV. As soon as the TV turns on, press the accept key on the remote. I had the sam problem, luckily I remembered the scan procedure. I have 3 different brand of remote controls, all with scan capability but diffeent key strokes.
May 13, 2007 | Gemini Sound Products SBR3B Remote Control
One For All URC-3605 Remote Control Logo
307 people viewed this question
Top One For All Televison & Video Experts
Computer Repairing
Computer Repairing
Are you an One For All Televison and Video Expert? Answer questions, earn points and help others
