Question about LG LMV1314 Microwave Oven
Wont heat looked at the microwave one day and the display said "child" and now it wont microwave for longer than 30 secs and it wont heat. model number nn-s543bfr, panasonic inverter
  • William Miller
    William Miller May 11, 2010
    Is it possibly shutting off after exactly 22 seconds?
  • artiacousmc May 11, 2010
    Do you have your user manual? Is there a section about child locking your microwave?
  • 6,784 Answers
Hi, there are three issues that will cause a no heat situation in a microwave. these issue are a failed Magnetron, busted cut-off fuse and, failed diode.
I recommend checking all these area that are located inside the microwave for faults.
The most common issue will be a failed Magnetron.
The diode and, fuse will be located on the noise filter assembly.
Posted on Jun 22, 2009
MicrowaveSvc
  • 9047 Answers
SOURCE: PANASONIC MICROWAVE NN-K657
To UNLOCK it, press Stop/Clear 3 times.
To LOCK it, press Start 3 times.
You can download your owner's manual here:
http://techdocs.panasonic.co.uk/GetDoc.aspx?did=125787&fmt=pdf&lang=en&src=3
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Feb 27, 2008
ukvacfan
  • 328 Answers
SOURCE: Panasonic Inverter NN-V673S microwave- shuts off after 2-30 secs
If the screen is showing a fault number or a number you havent seen before then its probably a program fault which can't be fixed. Check that the vent holes on the back of the oven aren't dirty and ensure that the whole oven is clean inside. Sadly it sounds like a program fault which cant usually be fixed by the owner though.
Finding a Panasonic oven repairer in the UK shouldnt be a problem though. My parents had a simlar problem wth their Panasonic Inverter oven, called the UK customer services and Panasonic contacted an authorised repairer in Scotland to visit them. Call customer services on 0844 844 3868.
If the call out charge exceeds £80 then you're probably better off buying a new oven.
Posted on Apr 19, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Microwave -- Panasonic NN-S543BFR
I would say either the high voltage transformer or a component on the inverter board has failed.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer.
Posted on Aug 08, 2008
  • 4 Answers
SOURCE: my microwave says "child" and won't play anymore
Not sure of the TT series models but for the NN series models the procedure is as follows:-
If "Child" is displayed in the display window, then the child safety lock is on.
To remove the child safey lock, press the "Stop/Reset" button 3 times in fairly short succession (less than 3 seconds). The time of day or just the Colon sign (:) is then displayed
If you later want to apply the Child safety lock, then, when the time of day (or colon sign) is displayed, press "Start" 3 times (again in short succession).
Hope this helps
Doug
Posted on Nov 08, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: microwave runs 3 sec then shuts off.
mtystufquit - We've already discussed this by chat & e-mail, and if and when you need further help, please let me know.
"If the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle."
ddmdavid - you probably have a bad door switch or door switch mount. Please see these links.
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
http://www.microwavedisplay.com/doorsw.txt
If you still need help, please create a new post with your brand and model number.
Posted on Dec 15, 2008
Child lock on
This feature detects when your child pushes various buttons.
To reset/remove this message, disconnect the microwave from the mains power, wait for 30 secs and connect it to the mains power then set the Time and your microwave is ready for use.
Jan 22, 2012 | Panasonic Microwave Ovens
Whirlpool model number MH7140XFB no longer heats
you either need a new h.v. capacitor or h.v. diode in the magnetron circuitry if you cant hear it cycle when it runs as in a low pitched hummmm when its drawing current to operate the magnetron tube, each part runs about $30 to $45 each,normally its the h.v. capacitor though
Jul 28, 2010 | Whirlpool MH7140XF Microwave Oven
Error message "chiLd"
There is a Child Safety lock-out feature on some microwave ovens. This enables the user to lock the keypad to prevent children from playing with the control panel. The model number you have this question posted under has this feature enabled/disabled by pressing and holding the "CLEAR/OFF" button for 3 seconds. However, the display reads "LOC" when the feature is activated. I suspect your model number is different because of the display indication you are receiving. Review your owner/operator manual for how to disable the child lock feature. If you no longer have the owner's manual, or if you still have questions, please post back with your BRAND NAME and MODEL NUMBER, so that I may be able to provide you with better assistance. I hope this helps you.
Nov 17, 2009 | GE JVM1440 Microwave Oven
CHILD SAFETY LOCK
If the model number you have this question posted under is correct, to cancel the child lock safety feature all you need to do is press and hold the zero "0" button for at least 4 seconds. The "LOCKED" indication will go away and you should hear two beeps. The instructions are listed on page 11 of the owner's manual. If you no longer have a manual, you can download or print a copy for FREE at managemyhome.com. Just type in your model number under the "Manuals" link.
If you have questions, or if your model number is different, please let me know. I hope this helps you.
Nov 14, 2009 | LG LMVM1935 Convection/Microwave Oven
The clock works & counts down but the microwave won't heat
  • Disconnect the power for 30 seconds. After restoring power, do not set the clock.
  • If your model has an ON/OFF clock display, you can choose not to have the time displayed. To choose this option, press the 0 pad for about three seconds. To Turn the display back on, press the 0 again.
Touch the clock pad. Enter in the correct time of day by touching the numbers in sequence. Touch the clock pad again.
Aug 03, 2009 | Sharp R-1460 Microwave Oven
Everything on oven appears to work, but does not heat.
from what your describing it sounds as if you have burnt the antenna off of the end of the magtube if this is the case if your microwave is no longer under warranty due to the cost of the part you may be better off to purchase a new microwave.
Mar 25, 2009 | GE JE1540 Microwave Oven
Whirlpool over the Stove Microwave
This sounds like the unit is defective and if I were you I would return for replacment!
Dec 16, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
My microwave says "child" and won't play anymore
Hope this helps
Doug
Nov 08, 2008 | Panasonic NN-T990SA Microwave Oven
Microwave oven (nn-sd997s) stuck in DEMO mode
Pressing "timer/clock" button 4 times turns on and off demo mode.
Apr 26, 2008 | Microwave Ovens
Amana Microwave model ACM1460AB
Weak heating is usually a bad magnetron.
If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Nov 26, 2007 | Microwave Ovens
LG LMV1314 Microwave Oven Logo
185 people viewed this question
Top LG Microwave Ovens Experts
William Miller
William Miller
sonic boom...
sonic boom...
Nick Olsen
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
