Question about GE JVM1650 1000 Watts Microwave Oven
GE JVM1650 Microwave Suddenly Stops
Hi Brian: You gave some advice back in December about this issue. I ordered and received the mag tube. However, is this something that you recommend an "average Joe/Jane" replace themselves? Or, should I call a cert. technician as GE suggests? Thank you, Tami
  • katehead Jan 29, 2009
    I may have the same problem.
    My oven is the same GE Microwave model. The power cuts out after 3-5 seconds occasionally (sometimes it works fine). After it cuts out, all the lights will display for a second and then it will ask me to reset the clock and the date. I can then try to heat the food again and it may have the same problem or run just fine.
    I saw another post that thought it might be a faulty element. Hopefully you can narrow it down or give a more specific answer.
    Thanks,
    katehead@yahoo.com
  • Joel LeBoeuf Apr 29, 2009
    With my microwave it started making a noise like the fan was rubbing on something, all of a sudden it stopped. Then it started where it would
    run for a while then go completely dead no display at all then it would ask you to set the clock and date. It works fine for awhile hen same problem all over again.
    Thanks,
    jleboeuf1962@yahoo.com
    Scholar:
  • 111 Answers
Tami,
It isn't really difficult to replace... It's the 4000 Volts that go to it and the stored energy (voltage) in the high voltage capacitor that concerns me as far as telling you that it is a do it yourself repair. Also, and this a huge concern, is that after the magnetron tube is replaced, the microwave should be leak checked. A microwave leak detector that is certified is around $400. Now that I said that, I have rarely ever had one that leaked, but it is the law and that's the main reason that it needs to be done. I highly recommend calling GE Factory Service 1-800-432-2737 (1-800-GE Cares) to install the magnetron tube.
Brian
Posted on Jan 15, 2009
GE spacemaker microwave, how to change from indoor vent to outside top vent
You can download GE owner's manuals and installation instructions here.
You can order any needed parts and accessories
by entering your full model number from the tag on the oven here.
Sep 16, 2011 | GE JVM1650 1000 Watts Microwave Oven
Ge microwave jvm160wj01 was working and suddenly started buzzing, gave bad electric/burnt smell and buzzes. Still buzzes and does not seem to heat now.
Sounds like the magnetron just shorted out. Its the part the generates the microwaves that heat the food. Buzzing sounds are a symptom of a shorted mag. Usually not worth fixing since the magnetron costs almost as much as a new oven. Sorry.
Jul 01, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
WE have a JVM1650SHO5 space saver GE Microwave Oven that suddenly started not heating. No other issues.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Mar 06, 2010 | GE JVM1650 1000 Watts Microwave Oven
JVM1650SH02 keeps shorting out after a couple seconds
> but he would also replace the capacitor and diod when replacing the mag tube
Most of the time replacxing them all is done due to ignorance about how to actually test devices, a mistaken notion that it's somehow necessary, or to pad the bill.
The diode may be necessary in some cases (if it tests bad) but the capacitor is almost certainly not needed.
When a capacitor fails, it almost always shorts. If so, the fuse would blow when you peress "Start" to begin cooking.
I've rarely (if ever) seen one fail without shorting.
If it's within the magnetron portion of the warranty (usually 5-9 years) but out of the original full warranty (usually 1 year), then GE manufacturer will cover the part cost, but not the cost to visit you or the labor charge to do the work.
If you're doing this yourself, G.E. will send you the magnetron to do it yourself. Call them at 888-239-6832.
Be persistent. You may have to speak with a supervisor.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
> Can I just replace the mag tube without also replacing the diod and capacitor?
Almost certainly.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Sep 11, 2009 | GE JVM1650 1000 Watts Microwave Oven
Everything seems to work but not heat
the switch is ok. if it was bad itt would blow the fuse. ge had magnetron problems on the 1600 series. if you have an amprobe and are getting 110 volts from the control to the transformer. place the probe around just 1 wire to the transformer. if you get less than 12 amps replace the mag
May 18, 2009 | GE JVM1650 1000 Watts Microwave Oven
Your magnetron tube is leaking RF energy inside and zapping the main board. It is NOT dangerous as any leakage will be contained inside the unit. You will need a new mag tube and it is covered by a 5 or 10 year parts warranty. Call GE Factory Service at 1-800-432-2737or schedule online at www.geappliances.com
Dec 18, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Ge jvm 1650
You should us all the installation parts and material shown in the installation manual.
Whatever you don't have can be ordered.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
If you still have questions, please reply back to this thread instead of starting a new one.
Aug 25, 2008 | GE JVM1650 1000 Watts Microwave Oven
GE JVM1650 truntable noise
Sounds like the turntable motor is going bad.
If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Nov 18, 2007 | GE JVM1650 1000 Watts Microwave Oven
GE SpaceMaker Microwave suddenly stops while heating
I had same problem last week. My GE JVM1650 Spacemaker stopped after a few seconds of heating. Owned 16 months, manufactured Jan 2005. It was the magnetron, which was replaced yesterday. The magnetron has a 10-year warranty, but I had to pay $161.00 for labor by a GE technician. The call-out fee was waived at my request. I don't know what that amount would have been, but I can't believe the $161.00 for what was about 1/2 hour labor once diagnosed. Good Luck!
Sep 20, 2006 | GE Spacemaker JVM1640SJ Microwave Oven
GE JVM1650 1000 Watts Microwave Oven Logo
373 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
