The numbers on the Transformer is EM48-27A3
SOURCE: MS9700 secondary voltage
I am working on the same situation. DId you first check to see if it isn't the fuse that has blown? Radio Shack has a 4 pack of 2 amp fuses for $2.49 which I think will work. Their catalog number is 270-1064. These as 5x20mm in size (the 1-1/4 x 1/4 inch is way to large) and they are slow blow - designed for this type of household equipment to protect from short circuits and power surges.
If you are lucky maybe it is just the fuse. Since I can find no other information about this unit - especially the transformer - I'd check eBay for a working one. If you can get it cheal and it works test the power output with a VoltOhmMeter (VOM) and once armed with the info you can let me know too what the output is
SOURCE: Nothing on Radio stereo system works.
check to see if the cd player has a little hole next to it if it does that is a release use a paper clip to push into the hole that should get your cd out.
SOURCE: Power transformer appears bad.
don't bother with a transformer. use a 12vdc 2amp power supply, the unit has a 8v regulator. remove the bad transformer and connect the power supply. polarity doesn't matter because the unit has full bridge rectifier that will provide the proper polarity.
