Question about KitchenAid KESI901P Electric Kitchen Range
Kitchenaid electric range
When i use the top ceramic burners on the range, and then if i wish to use the oven i get a "pf" i believe it means power failure, what is the solution for repair?
  • 76 Answers
This one can be a little tricky. I really need to know a lot more information to give you a good answer. You are right pf does mean power failure. This is detected by your power board the is located under the cooktop. If you select cancel the pf should disapear and you should be able to use your oven. You didn't mention whether the control board displayed the pf before you actually tried the oven. If it did, and it gives you that error every time you use the cooktop for a period of time, you could have a problem with the thermister located right behind the console. To remove the console just remove the screws on the under side then lift the console straight up and off.
Posted on Jul 21, 2007
What does the message PF mean?
PF = Power Fail. Possibly damaged control board.
Dec 23, 2014 | Whirlpool 30" Self-Cleaning Freestanding...
I have KitcheAid KERS 807, electric stove/oven range. Left lower part of ceramic stove top that has single/dual heater sizes is malfunctioning. Single one is still working but from recent dual does not.I...
Either the knob has gone out or the burner element. I would test the knob first to see if there is current when turned to the large zone. If the knob is working, next would be to test the burner to see if the outer ring has burned out. I would guess more likely the control has gone out. Burners have less failure (typically).
Apr 14, 2014 | KitchenAid KERS807SSS Electric Kitchen...
We had a power failure and Kenmore stove showed pf and now loc. cannot get burners to turn on and cannot get loc off.
If you have a power failure or a brown out, it sends a very powerful current through the unit. Please keep in mind that these units are not protected against any surges. If you have a display, that means you have power. Unfortunately, the clock/timer contains relays that control the elements, the oven, etc. You will need to replace the clock to get it running again.
Mar 13, 2014 | Kenmore Stove / Oven / Range Bake Element...
Superba model: YKEBS208DB3 electric sove shows code PF. what does this mean?
PF stands for power failure, just hit cancel and reset clock.
Good Luck, I hope this helped.
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Nov 27, 2013 | KitchenAid Architect Series KEMC308KSS...
Whirlpool Range RF366PXGW. I had the oven at 350. The Stove started beeping, I think it said F1 or F2 I turned the dial to off. Then I noticed the oven did not go off, the top element stayed on. Had to...
all repairs on your range should be performed by an authorized service person. F1 is an electronic oven control (EOC) malfunction. F2 is also and EOC issue. as far as the burner the surface control switch contact might be in the closed position. this can cause the burner to stay on. in that case replace the control switch. the PF code= a power failure. push cancel on the EOC to clear the PF code.
Jun 02, 2017 | Kitchen Ranges
Oven won't work says PF
Hello lornalang - Typically "PF" indicates power failure. Once again try reprogramming the range by either unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and restart unit. If it proves to be ineffective, the range may possibly be experiencing a wiring failure or faulty EOC. Consult a professional to move forward accurately and to assist with the repairs.
Feb 03, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
Own a KitchenAid gas range superba, how do i clean the burner, one of my front burners the gas flow is very low, the stove has the glass/ceramic top with no wells & no way to get to the burners...only...
You'll need certified stove technician to service you kitchen Aid range. You have low gas flow on one of the burner. The manual gas control valve behind the knob needs to removed and cleaned. If you have one cleaned then have technician clear all four of these manual gas valves. While he cleaning the valve have do a complete check up of you Kitchen Aid range. Dangerous for the home owners to do this procedure because flowing natural gas or propane. In a lot the states you'll need to be certified by the state to work with natural gas, gas stove, ovens, gas home heating units, etc. It differentially a no,no here.
It is not the burners, it is gas flow valves for the burners. Most of the burner are made of aluminum and I wouldn't use any harsh cleaners of them. Check with Kitchen Aid and ask them what is recommend for cleaning the burners. Also the top of the range isn't ceramic but porcelain, it glass that has been melt to the top hood of the range. Don't use scratch pads, steel wool or any thing that will mare the Periclean surface of your stove.
If you can get the aluminum burner out to clean them then do so. GB you Allison and I wish you many year cooking on your Kitchen Aid range. stewbison
walk softly up on this earth and she will good to you...
Aug 21, 2011 | KitchenAid Kitchen Ranges
KitchenAid KESI901P Electric Kitchen Range Logo
440 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
