Question about Toshiba 57H83 57" Rear Projection HDTV
My toshiba 57h83 has a black rectangle in the middle of the picture what do i do
    President:
  • 2,992 Answers
Check your closed-caption settings and make sure they are turned off (or set to "caption 1" or "CC1" if you really want them). You will find the captions set for "text" now and that's why you see that black box sometimes. The set is blanking out a part of the screen for the text that never shows up. Most TVs have a single button to set captioning, so it's easy to press it and change modes without knowing it.
Please take a moment to rate this solution if it's cleared up your screen, and thanks for asking here!
Posted on Mar 20, 2009
A black rectangle showing in the middle of the screen this appeared suddenly
this sounds like screen burn with rear projection and plasma when a picture is left sitting still on the screen sometimes it will burn in to the screen rendering it useless i left my ps3 paused on my old tv then when i changed to bbc one it still had a faint call of duty pause screen in the back it can vary from things like that to logos to your black rectangle the only way of repair is by replacing the screen all toghether i would advise you to just take the screen off and start using the tv as a projector if you cant find a screen it is only a bit of ribbed plastic but very hard part to find
Feb 16, 2011 | Toshiba 46HX83 46 in. Rear Projection...
57H83 57 in. Rear Projection HDTV Television: I have a Toshiba 57H83 and recently purchased the ...
I would suggest to leave your directtv hd/dvr box connected the way It is.
The HD Colorstream 1input on your TV should work just fine.
This TV does not have an HDMI input but you can buy an adapter and connect to DVI/HDCP IN and that might be able to get 1080i video resolution on your TV.
Jun 30, 2017 | Toshiba 57H83 57" Rear Projection HDTV
I have a 10 year old jvc model av27120 serial number 1251053, my 2 year old grandson touched the buttons on the front of the set and now a black rectangle keeps popping up in the middle of the picture. Can...
Sounds like 'picture in picture' was turned on. And if there is no 2nd video source, it shows up as a black rectangle. Find a button that is labelled PIP or similar and press it, maybe several times. It may move the PIP around the screen before turning it off.
Apr 02, 2010 | JVC Televison & Video
Toshiba 57H83 and no longer get any sound. Any
Most often No Sound with Toshiba 57H83 is:
1. TV has a Sound on-off switch on the input panel at the rear of the TV. Very hard to see, black on black. Used to turn off speakers if you use a separate or external sound system for speakers. Usually gets moved while connecting hd cables or dusting and vacuuming in cramped space at the rear of the TV.
2. Someone accidentally changed Sound settings with remote to CC (closed caption) or SAP. Turn off in sound menu and save preference.
3. Sound input plugs from external cable or sat box unhooked or wrong input.
Toshiba 57H83 no sound fault is not common. If you still have no sound, get local service.
Or troubleshoot yourself to determine if Tuner, IF, processing, sound demod, switching or sound output circuit is smoked. Then make an installation plan.
easyab
ConvergenceRepair.com
Feb 28, 2010 | Toshiba 57H83 57" Rear Projection HDTV
Black rectangle on picture Toshiba CF27H40
Hi
maybe your horizontal yoke is defective..
Thanks!
Feb 25, 2009 | Toshiba CF27H40 27" TV
Replace board toshiba 57H84
They are located on the large signal board in the middle of the board all lined up in a row they will have board location numbers of 7412, 7406 and 7413
Nov 23, 2008 | Toshiba 57H83 57" Rear Projection HDTV
Toshiba 57h83 wont do nothing
that relay is supposed to engage power to the tv boards that control the screen.
you will have to take it to a oualified service center , because they have access to parts that are needed for repair
Oct 17, 2008 | Toshiba 57H83 57" Rear Projection HDTV
Loss of picture and sound
Is the front panel power led flashing by chance?
Jan 09, 2008 | Toshiba 57H83 57" Rear Projection HDTV
Toshiba 57H83 57" Rear Projection HDTV Logo
85 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
