Question about Sony PlayStation 2 (PS2) Console
Playstation 2 Won't Boot
The playstation 2 (50001 Model) I borrowed will not boot up to the browser/configuration screen. It will play a DVD just fine, but won't even boot up to the basic Playstation 2 home screen. I don't have any clue why this isn't working. Any help would be appreciated. Thanks, Jason Bailey
Don't put a disk in and try
Posted on Jun 29, 2007
PS2
Step 1 – Download and install PCSX2 PCSX2 comes in two packages. A binary package (which you have to un7zip) and an installation file. Just install or extract it to the folder of your choice.
Step 2 – Getting the BIOS files Contrary to the first PlayStation, the PlayStation 2 uses several BIOS files. Basically, these are the hardest to find. Because they are copyrighted material, you are only allowed to own these files if you also own a PlayStation 2. MakeUseOf does NOT encourage piracy! This is also the reason why it’s illegal to host these files online. If you actually own a PlayStation 2 though, it’s not illegal to download them (laws may differ in your country).
So now you basically have two options layed out for you. You can either dump them from your PlayStation 2 yourself, or find someone else who dumped them and who put the files online. On this last website you can find the ROM1, eROM and the SECAM-, NTSC- and PAL BIOS files you’ll need. Again, you must’nt download them if you don’t have a PlayStation 2. You can put these files in a folder of you’re choice.
Step 3 – Running PCSX2 and configuring BIOS, video and controller input The program comes in two different versions. One version uses TLB (pcsx2t.exe), the other one Virtual Memory (pcsx2.exe). First of all, try running the VM version. The program will try to reallocate the memory, after which you have to log off and on again. If it fails to do so, you’ll have to use the TLB version. This one is somewhat slower, but according to the developers the speed difference is not that great.
After you’ve started up, select ‘Config’ -> ‘Configure’.
First, we’re going to configure our BIOS. Press ‘Set Bios Directory’ and select the folder where you’ve put your BIOS files. Back in the Configuration screen, select the correct region from the Bios drop-down menu. You might want to change this now and then, depending on your games.
epsx2biosconf.jpg Next, the video plug-ins. PCSX2 comes with ZeroGS KOSMOS and GSdx9 plug-ins. A ‘Ps2 Output’ window (which looks similar to the command screen) normally opened when you started PCSX2. Else, temporarily close the Configuration screen, select ‘Misc’ -> ‘Enable Console’ and restart the program. In this Ps2 Output screen, look if ‘Detected SSE2′ is stated under Features. If not, you might want to choose the ‘no SSE2′ video plug-in.
ps2output.gif If you press the ‘Configure…’ button under the video drop-down menu, you can tweak graphic related options like screen size, toggle full-screen, anti-aliasing and more.
As for the controller, I highly recommend LilyPad. This is one of the most adjustable plug-ins. You can use keyboard, mouse and controller input. There even is a setting so you can use your Guitar Hero guitar.
Just download it here, and drop it in the plugins directory. If you’ve used the installer, that would be C:\Program Files\Pcsx2_0.9.4\plugins .
Re-open the Configuration screen, select LilyPad from the drop-down menu and press configure. In the ‘General’ tab, you can tweak various settings. Select the ‘Pad 1′ or ‘Pad 2′ tab to configure the keys.
Step 4 – Test-driving and alternative plug-ins With everything set up, it’s about time for a test-drive. We’re going to look if everything works as it should, and look which points need more improvement.
We can boot the games, depending on the plug-in we use, either by CD/DVD or by using an image file. The standard configuration uses Linuzappz, which is able to boot ISO’s and other image files. To do this, just select ‘File’ -> ‘Run CD/DVD’.
If you want to boot from a disc instead, go back to the configuration screen and select the P.E.Op.S driver from the Cdvdrom dropdown menu. Press configure to select an interface (based on your operating system) and the drive you want to use. Confirm your configuration and you’re ready to roll. Select ‘File’ -> ‘Run CD/DVD’ to boot from the chosen drive.
epsx2run.jpg At this point you’ll be prompted for a date and a timezone, after which the game will start. If you’ve got problems with the graphics or sound, try using one of the the other plug-ins. You can get more additional plug-ins here.
If you’re still having problems, check the compatibility status of your game here.
Have fun!
Aug 06, 2009 | Sony PlayStation 2 (PS2) Console
Tip
Playstation2 Region Free Fix
Sony Playstation 2 DVD Player Region Free Fix
Would you like to unlock your Sony Playstation 2 DVD Player to Region Free?
There is more than one model of PS2, and more than one PS2 DVD player module. For some models or modules, only a Messiah 2 or Magic 2 chip installation will make them region free. However, many can be made region free, for free.
Follow these steps to unlock your Sony Playstation 2 DVD Player:
  1. Press and hold CIRCLE, RIGHT, L1
  2. Press and hold L3 and push the stick in hard
  3. Boot into the PS2 browser without a CD/DVD in the tray
  4. Press CIRCLE and R1 on the DVD
  5. Hold RIGHT until a menu appears
  6. Press CIRCLE and R1 again
OR
  1. Load the DVD into the PS2
  2. At the browser screen, select the CD icon the press and hold SQUARE then CIRCLE until the DVD menu appears, holding both buttons all of the time
  3. Either select the PLAY icon or the MOVIE START icon
Your Sony Playstation 2 DVD Player is now Region Free.
I hope that helps.
on May 02, 2010 | Sony PlayStation 2 (PS2) Console
Tip
PS2 DVD Region Free Fix
OR
I hope that helps.
on May 02, 2010 | Televison & Video
Will not play dvds or games
2 things for this one
1 lens is dirty get a damp cotton bud and wipe the lens or even rubbing alchohol.
2 lens is broken or misaligned you can get this fixed at a shop that fixes consoles but dont know how much it will be.
and always clean your discs when you put them in or take em out of the playstation because any dirt or dust can get on the lens etc.
May 13, 2009 | Sony Video Game Consoles & Games
Ps2 action replay wont work on 60gb ps3
The Playstation (R) 3 has most likely been patched. I find it knocks back not only Action Replay but XPLODER also (The EU version of Gameshark) both for PS2 it is likely that SONY has blocked it out to stop consumers playing region locked dvd movies. So if you in UK you can only play Region 2 PAL dvd's, if you in the us, you can only play Region 1 NTSC dvds. If in AUS, you can only play Region 4 Dvd Disc....etc.... AR Max had a feature to bypass this problem, thus why sony has probably patched against it. As for a solution I am also searching for one, truth be told, I don't think there is one.
You should boot up your codes on your PS2, then the game.
Save your game.
Then copy your save game to your PS3.
Hope this helps.
Feb 06, 2009 | Sony Playstation 3 (PS3) Console
Tip
Make a SONY PS2 multiregion with SCPH 1000 firmware.
NOTE: this will only work on the earlier models with the SCPH 1000 bios 22/9/2004
1. Press and hold Circle , Right and L1
2. Press and hold L3 and push the stick hard
4. Press circle and R1 on the DVD
5. Hold right until an menu appears
6. Press circle and R1 again.
If this fails try this
1. Load the DVD into the PS2 that you want to play.
2. At the browser screen select the CD icon press and hold circle and square until the DVD menu appears.
3. Either select the movie select icon or the play icon.
If these two fail you will need a Messiah chip OR magic chip 2 installed
on Dec 14, 2009 | Video Game Consoles & Games
When i turn my game on to play and put the cd into it it only gives me two options
my ps2 model scph15000
not read the orginal dvd game?
y the origanal cd in ps1 can read it :}
and cant read the pairated cd or burn cd / dvd game?
Sep 14, 2008 | Sony PlayStation 2 (PS2) Console
Playstation 2
is there any microchip in ur ps2........??it will be shown when we switch on the console.if it is not there ,may be bcz of that .othrewise ur lens is damaged...try replace a new one..
Sep 08, 2008 | Sony PlayStation 2 (PS2) Console
Playstation 2 stopped working
It sounds like the disk reader could be damaged. PS2 is an old console so I think it is just dying. You could try this. How to Fix PS2 Disk Read Errors
Mar 12, 2017 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 (PS2) Console Logo
140 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
