Question about Whirlpool MH7135XE Microwave Oven
Microwave has no power
The microwave oven appears to have no power. The fuses were checked as well as the power to the micowave. All is normal. Is there a reset button on the appliance or is it shot?
    Brigadier General:
  • 8,619 Answers
Hi
If your microwave oven doesn't seem to work at all, check these:
Fuses Usually, when your microwave oven doesn't work it all, the internal fuse (thermal fuse) is blown. This fuse protects both you and the oven. When it blows, you need to have a qualified appliance repair technician replace it.
Door switch If the fuse isn't the problem, check the door hooks and the door-release button. When these are broken, the door switch doesn't activate, so the oven can't work.
Thanks
Rylee
Posted on Jan 15, 2009
Hi I have a Samsung SMH9187 micowave that is dead (no display, light, fan, mirowave).
Sounds like the main fuse blew. It's either near where the power cord enters the cabinet, or behind the control panel (if an over the range unit).
You may also have some type of failure in the high voltage circuit; based on your description of the symptoms.
Aug 16, 2014 | Samsung SMH9187ST Microwave Oven
My microwave power is ok, led light ok, but dosen't work what problum?
check the door switches....i had an over the oven micowave with a bad door switch....thing is the switch cost 35.99 online and i bought a counter top microwave for 39.95 at walmart
Jan 31, 2012 | GE Microwave Ovens
Power comes on but micowave does no cook
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Feb 15, 2011 | Emerson Black Microwave Oven
Trying to change a fuse in ge microwave oven je2160. however, we can't determine how to find the old fuse and remove the cover
THE FUSE IS ON THE RIGHT HAND SIDE OF THE MICOWAVE AS YOU LOOK AT IT JUST AT THE TOP BEHIND THE CLOCK
Dec 25, 2010 | GE JE2160 Microwave Oven
Micowave works but no heat fuse is good mw8992rcd,what other checks can i do thanks wg
Microwave Oven Basic Troubleshooting Tips
heatman101
Sep 30, 2010 | Emerson Microwave Ovens
My model is nn-s253wf, micowave stopped working, no power, checked circuit breaker, is ok ?, unplugged, then plugged back in, still no power ?
Inside the external case and usually to the right left ( from Front) in some models There is a 30 amp fuse ( This may vatry on oven output amperage) Replace that and you should be back in cook mode.
Removing the case you should remember to disconnect from the power plug.
Please rate my help++++Thanks for using FIXYA
May 29, 2010 | Panasonic NN-S252WF Microwave Oven
My oven started arching with micowave popcorn (4 or 5 different times). Now it will not heat. No error messages on the screen and everything else works. Thanks Dennis M.
Hi, there are three issues that will cause a no heat situation in a microwave. these issue are a failed Magnetron, busted cut-off fuse and, failed diode.
I recommend checking all these area that are located inside the microwave for faults.
The most common issue will be a failed Magnetron.
The diode and, fuse will be located on the noise filter assembly.
Jun 21, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Ge spacemaker microwave has no power how do i change the fuse?
First you have to unplug your device. Next you must remove the cover from the micowave. Follow the powe cord to the unit the fuse should be right at the beginning of the powe cord. I hope yhis will help you.
Nov 26, 2008 | Microwave Ovens
Whirlpool MH7135XE Microwave Oven Logo
583 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
