Question about Sony CDP-CE375 5-Disc CD Changer
Sony CDP-C235 CD Changer Dirty Laser Problem
My Sony cd changer gives me a no disc error, so i clean the laser and the whole thing works swimmingly. Then, some random but short interval later (typically when it tries to read a new disc), i get the same error. Cleaning the laser works, but temprorarily. Any suggestions?
  • 10,594 Answers
Please replace optical block (laser) of CDP-C235.
It is available in Part Store.
Posted on Jan 15, 2009
Sony cdp-c215 wont read disc removed cover disc doesn't spin
The pladder motor that spins the disc is open, or the laser pickup is defective, the whole laser assembly would need to be replaced, not cost effective to repair cheaper to buy.
Apr 16, 2012 | Sony 5-Disc CD Changer with SA-CD Playback
Static problem
You can try a laser cleaning kit to see if that will help, generally when the laser gets to that point it is time to replace the laser pickup assembly or just replace the whole unit due to cost over runs in repair.
Apr 05, 2012 | Sony CDP-CE375 5-Disc CD Changer
My cd changer wont play, it sits there for a minute then rotates the slots and then says "no disc"?
from your description it could be the laser unit
try to clean with a clean disc
if it will not help it might be the laser unit
Nov 04, 2010 | Sony CDP-CX450 400-Disc CD Changer
My Sony MegaStorage CDP-CX455 400 Disc changer does not play CDs anymore. What can I do to fix it?
Pretty much the only thing you can try at home is cleaning the laser lens, if the cleaner works then remember to use it now and again.
If the CD lens cleaner does not work the take it to the nearest sony tech/dealer for repair. Multi CD systems are very complicated and need specialist attention.
Hope this helps
Thanks for using FixYa
Aug 09, 2010 | Sony MegaStorage CDP-CX455 400-Disc CD...
ALL SEEMS FINE BUT WON'T PLAY DISCS. FLASHING BLUE LIGHT INSIDE.I GET "LOADING ERROR" ON SCREEN, AFTER A COUPLE MINUTES. SONY CDP-CX400
I would suggest taking a can of compressed air to the disk tray to ensure the laser is clear of all possible debris
Mar 30, 2010 | Sony CDP-CX400 400-Disc CD Changer
Cds dont load and tracks will skip during song play
It is clear symptoms of bad optical laser or dirty optical lens.
Please put lens cleaning CD in player, play that CD to clean dust on optical lens surface. If that helps, fine or replace optical laser block in player.
I can provide you optical lens part number, please confirm is it Sony CDP-CX153 cd player or any other model.
Thanks.
Oct 27, 2009 | Sony CDP-CX153 100-Disc CD Changer
New jazz cd not reconized by player . It says no disk present .
Your laser lens is probably dirty, try a laser lens cleaner if that doesn't work, unplug the unit and take the outer casing off and manually clean the laser with some alcohol and a dry cotton cloth, would also be a good time( see that you have it apart already) to lubricate the moving components with some Vaseline.
Hope this helps with your problem.
Aug 18, 2009 | Sony CDP-C505 5-Disc CD Changer
ERROR message - CD is dirty or not put in the magazine correctly
hi for starters look carefuly if you are putting the CD's in the right side inside the magazine and the magazine itself in its right position take a air spry can and clean the laser eye of the changer while ur at it clean the whole changer from dust and dirt good luck windman
Jan 01, 2006 | Sony CDX-600DSP CD Changer
Sony CDP-CE375 5-Disc CD Changer Logo
1,047 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
