Question about GE (PSS26MSRSS) Side by Side Refrigerator
Sounds like a motor rattling
Have a Frigidaire FRS22WRC & am hearing a rattling noise from the lower back of the unit. Any help?
  • 1 more comment
  • bbq_mike_in_ Jan 15, 2009
    I certainly can. I'm gonna pull it off in the morning. Thanks for the quick response Skeeter.
    Mike
  • bbq_mike_in_ Jan 30, 2009
    Sorry it took so long to get back to ya. Wife & I are laid off & had to wait for unemployment checks to pay for a new compressor. Thanks for all your help. It was a little aggravating not having done this kind of repair work before but it's not like I didn't have the time & it was a lot cheaper than getting a repair guy..
    Thanks again from Atlanta,
    Mike
  • Ken Bledsoe May 11, 2010
    Hi there bbq hey can you pull frig away from wall and remove the back cover to expose the lower unit?
  • 163 Answers
Hi!!! Once you pull the back cover then check your condensor fan motor or compressor shown here good luck..\\
Posted on Jan 15, 2009
What is making a rattle noise in the front?
Check all the bushings and make sure they are not loose. General Motors bushings are prone to cracking.
Nov 02, 2012 | 2005 Chevrolet Malibu
The feezer side is making a loud noise and will not stop. it seems to still be cooling just fine on both sides. thier is no burning smell or anything. i tried dissconnecting the ice maker and that did...
From what you're describing it sounds like the freezer fan motor is causing the noise you hear. The freezer fan is the only moving part in the freezer section. I recommend replacing the freezer fan motor & fan blade together. If there is ice buildup on the back wall of the freezer then the sound is likely from the fan blade hitting the ice and you will need to defrost the unit.
Jul 31, 2011 | Frigidaire Refrigerators
Frigidaire dishwasher noticeably louder - circulation motor?
Try to position the machine, so that you can run the cycle and watch the dish washer. Remove the back panel and hear the sound of origination. Take suitable action as per your convenience. You can clean & replace the bearings if they are worn or replace as a whole unit.
Jul 06, 2010 | Frigidaire Dishwashers
Weatherking heat pump sounds noisy but has a 20 degree air difference from intake to vents, is this normal?
Without hearing the "noise" it is difficult to diagnose via internet; however, I can tell you that the 20 degF temperature difference is a good sign.
If the noise is at the outdoor unit, try to determine if it is the casing or something else. Sometimes the casing can rattle and/or vibrate that can cause a sound. Sounds can also come from refrigerant lines rubbing against the casing. Other noise sources at the outdoor unit are the fan motor, fan blade assembly, and compressor. You can remove one of the fan motor wires from the contactor, tape off the end, and start up the unit for a few seconds to see if the noise is still present. Then you can replace the wire and remove the compressor wires from the contactor and repeat the test. This will help you determine where the sound is coming from.
If the sound is coming from your indoor unitl, the most common sources are loose tape, Blower wheel, blower motor, or blower housing. Also look for loose panels.
Without being onsite with toolbox in hand and being able to actually hear the sound, I hope you find this information to be helpful to you moving forward. :-)
Jun 07, 2010 | Weather King 12AJA4801AH Air Conditioner
Clicking/tapping noise back of dryer
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
fgj
Dec 27, 2009 | Frigidaire FEQ332E Electric Dryer
Noises
Now this is a broad complaint!! LOL! Where do we start? What does the noise sound like? If it sounds like a bird chirping, it's your evap fan motor. If it sounds like somethings hitting the fan blade, your unit's frozen up with ice and needs to defrosted COMPLETELY and a new defrost system replaced. Call us and we'll be sure to ge the right parts out to you right away asap so you can get this unit back up and running again! We look forward to hearing from you and hope to be able to work with you more.
Sep 10, 2009 | Whirlpool GC5SHEXN Side by Side...
Same rattle and noise
this is easy one if you put the a/c on do you hear the rattle if yes then shut off the a/c if the noise go away then it is the compressor
Jul 21, 2009 | 1995 Nissan Altima
2001 WINDSTAR ENGINE RATTLE
Stop running the engine. Check the engine oil level. It should have a yellow colored handle, pull it out and check at the bottom of the stick for oil. If it is within the range on the dipstick, you need some engine work done. If you don't have any oil on the stick, or it is lower than the range, just add more oil, a little at a time until you get it back within range.
Apr 25, 2009 | 2001 Ford Windstar
Ticking and rattling
Is it a 3.9? Does it sound like it is coming from the front of the engine(timing chain)? From the factory the 3.9 didn't come with a timing chain tensioner. They are available after market.
Mar 27, 2009 | 1993 Dodge Dakota
Frigidaire Model #FRS22WRC Side by Side leaking
Check the bottom of the freezer side is there a sheet of ice???
May 20, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
320 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
