Question about Philips Magnavox DVD/VCR Dual Player
How to watch dvds with a converter box connected
We hooked up the converter box to our analog tv and now cannot figure out what we need to reconnect the dvd player, Is it some type of splitter cable?
    Scholar:
  • 73 Answers
You should connect the dvd player directly to the television and not the converter box.
DVD player may have red, white, (audio) and yellow (video) connections or it will have the red and white connections for audio and then red green blue for video.
Connection depends on the television inputs.
i hope this helps, if not send me another question I will walk you through it.
Posted on Jan 15, 2009
I have a Sylvanis VCR/DVDcombo and a Standard TV.
The converter box receives hte digital signals and converts them into either channel 3 or 4, or into direct video (red,white,yel). The output of the converter box must go into the VCR input for recording to work. Before the conversion, the tuner of hte VCR would receive the RF signal the same as the TV. The tuner inside the VCR is an analog tuner not digital, so it needs the conversion too. Most converters will provide both the A/V signal (R/Wh/Y) and RF (coax connector).
Hope this helps,
Dan
Sep 30, 2009 | Sylvania 6720FDG 20" TV/VCR/DVD
Receiving no signal with converter box
Where is the "no signal" coming from, the converter box or tv? If tv then unplug the dvd player and plug the plugs into the converter so the wires go from the converter into the rf modulator. set the tv up to watch dvds and try your channel scan gain. If it works then post again and we'll figure out the best way to connect the converter and dvd to the tv.
Jul 30, 2009 | Apex Digital (AL-A300ATX) 300-Watt Power...
Need indtructions to hook up converter, DVD, VCR & antenna to TV.
please help me i can watch my movie since i connect my converter box.. i connected my video cable to the converter when i press play nothing is showing up PLEASE HELP..
Jun 11, 2009 | Insignia Digital-to-Analog Converter for...
Hook up analog vcr to hd tv
You must have a converter box for the tv and for the vcr. Set the vcr to receive chanel 3 and set the converter box to the digital chanel you want to record. Put a splitter on the antenae out and route one to the tv converter box and one to the vcr converter box. GOOD TO GO.
Apr 11, 2009 | Sanyo Televison & Video
Hooking up my DVD/VHS player to TV & Convertor box
I would just hook up the dvd/vhs player with the red,white,yellow rca cables that should of come with your unit and just go to the input on the tv to watch your dvd/vhs player. This will give you a better picture and sound while allowing you not to have to watch dvd/vhs on a channel which helps make the dvd/vhs player independent. Also if possible I would hook the converter box up with the red,white, yellow rca cables to the tv as well if your tv has more than one set of red,white,yellow plugs since it is a better connection that coax and you probably watch more tv than vhs/dvd anyway. So bottom line try to hook up both boxes red,white,yellow and watch each box on different inputs instead of like channel 3 or 4. Also to record of converter box you can run coax from converter box to dvd/vhs combo and make sure your dvd/vhs player is on tuner input or channel 3.
Nov 16, 2008 | Insignia Digital-to-Analog Converter for...
Connect tv vcr and dvd player to digital converter box
Yes you can first connect the converter box to the antenna first. Next hook the tv out on converter box to vcr in on vcr. Next hook the vcr out to the tv in and watch vcr and converter box on channel 3 sometimes channel 4.on the actual tv and of course change channels with converter box remote. For dvd player hook it straight to tv with red,white,and yellow cables that come with your dvd player. Then to watch dvd player if it's hooked up that way you have to put your tv on a input like video 1 or input 1. This can be done by using the tv remote and looking for a button that says tv/video or input or source button. This is some common names for that button on tv remotes.
Nov 02, 2008 | Insignia Digital-to-Analog Converter for...
Ilo DVD player/recorder
> jfthr - Tv convertor boxes transfer digital signals into ANALOG. So when it goes to the dvd recorder it IS ANALOG. I have my antenna hooked to my convertor box, the converter hooked up to the ILO (A/V connections) then, the output on the ILO to the input of my analog tv. (Video selection on my tv). It works great to watch tv and/or record. I switch to the "DVD SOURCE" to watch dvds. Maybe you have the conv box hooked to the tv then the outs on the tv to the dvd. That would explain why you can get a picture but not watch dvd? The ILO has to go between the box and the tv in order to watch dvd.
Aug 07, 2008 | iLO DVD Recorder DVDR05
Converter box
1) Connect the coax cable from the antenna to the converter box input.
2) Connect the coax cable output of converter box to the input of the VCR.
This is the only way it will work but you will have many limitations such as using the programming features of your VCR.
The boxes are fine if you want to play prerecorded DVDs or tapes. If you want to record tapes you have to leave the box on and have it set to the station you want to record.
May 27, 2008 | Insignia Digital-to-Analog Converter for...
How to connect my dvd & vcr with the converter box
Here is my setup.
1) Separate DVD player 2) Separate VCR 3) Digital to Analog Converter box 4) Analog TV 5) Rabbit ears (UHF/VHF) antenna
The antenna goes into the converter box.   The RF-output of the converter goes into the RF-Input of the VCR The DVD output goes into the front input jacks of the VCR The VCR RF-output goes into the TV RF-Input The VCR Line output goes into the front of the TV
To watch DVDs, we turn on the DVD player, turn on the VCR, and set the VCR channel to L2, and tune the TV to channel 3.  The converter is off.
To auto record on the VCR, the converter must be tuned to the station being recorded.  The converted must be turned on, the TV can be off.
To watch VCR tapes, turn the TV and VCR on.  The TV is set to channel 3.  Just press play on the VCR.
To Watch TV.   Turn the TV and converter on.  The TV is set to channel 3.   Change the stations using the converter.
May 06, 2008 | Insignia Digital-to-Analog Converter for...
Philips Magnavox DVD/VCR Dual Player Logo
85 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
