Question about Minn Kota Riptide St Saltwater 80 Bow Mount Trolling Motor
Min Kota Trolling Motor Model RT/B?hc Riptide. Problem won't run
Trolling motor won't run at variable speeds. When connecting the tag-air switch the motor runs well but runs at a very high speed. Will run in forward and reverse position. The handle assembly will not respond when activating variable speeds but motor does run in forward and reverse modes but again at the max speed.
  • 1 more comment
  • escobell Jan 20, 2009
    I recieved your answer to replace the speed regulator. Is their another name for this part such as Control Board assemble # 2344007 or part actuator cam # 2302850. My owners manual does not list a speed regulator on any of the diagrams.
  • escobell Jan 22, 2009
    Recieved your answer to my problem Replace the speed regulator.. I am unable to find this part listed in my parts list, does the speed reglator have another name.
    I am actully supprised at the answer you have submitted to my problem. I may have been expecting a more detailed answer, more like a actual name of the part with a possible part number per MinKota's part listing manual, and possibly some hint as how to replace the part, with a guestimate pricing, I quess I may have been expecting to much from a paid professional service. I'll leave you to ponder my disapointment, and may not be inclined to use this service in the future.
    I posted a problem regarding my Min Kota trolling motor and the problem with the motor not responding to the variable speeds, the answer to my problem was to replace the speed regulator. I am unable to find this part in the Min Kota parts manual. A guess I was expecting a more detailed answer to my problem, more of a response with the actuall Min kota part number and a hint as to how to replace the part, I did pay for the service of FixYa problem and not "well go ahead and do that and it should be fine. Can you quide some parts numbers, possible cost and a hint as to how it should be replaced, or is that not part of your service...
    President:
  • 2,559 Answers
The names you are looking for are:(depends on model type)
Speed selector(On most hand and foot controlled models)
or
speed coil (On digital and remote controlled models)
Posted on Jan 22, 2009
  • 8,197 Answers
  • Jyackle5
    Jyackle5 Jan 22, 2009
    You can also get the motor diagram there.
  • 15,935 Answers
Riptide control boards are (1) fully encapsulated in marine-grade urethane to protect the electronic circuitry. All electrical connections are sealed with (2) liquid-tight heat shrink tubing to form an impregnable barrier against the destructive effects of saltwater.
You will be unable to repair the rheostat speed controller without compromising the integrity of the rest of the components. Your factory authorized dealer is the only one that can service this properly.
It may not be the answer you want to hear - but it is the correct one.
See the following picture...
Min Kota Trolling Motor  Model RT/B?hc Riptide. Pr - 7298c98.jpg
Thank you for using FixYa - A FiXya Rating is appreciated!!
  • 11,896 Answers
Either there is a broken wire between the handle and motor or the electronical board is bad.
    Sergeant:
  • 378 Answers
The speed regulator is faulty.just replace the regulator and it will be fine.
Posted on Jan 15, 2009
Minn kota riptide trolling motor
2 things can be wrong here the mother board is burned up or the speed switch is out
Aug 23, 2013 | Boating
RT 40 speed setting problems
bad mother board theres 2 in it one in head one in motor
Mar 27, 2013 | Minn Kota Riptide 40 Transom Mount...
What sizebattery is recommended for a Minn Kota RT40/s riptide motor
Hi, you can get away with a 70 amp hour deep cycle battery but I generally fit a 100 amp hour deep cycle battery. Hope this helps, regards Phil.
Jun 29, 2011 | Minn Kota Riptide 40 Transom Mount...
Have a Minn Kota Riptide 70lb thrust 24 volt. While lifting the motor the cables were cut. We spliced them with a heavy duty connector and it worked fine for several weeks. Now the motor will not run on...
Does the splice get hot when you are running the motor? If yes, then the splice could certainly be the problem. I would have replaced the wire completely. However, the problem more than likely is the controller.
Oct 28, 2017 | Minn Kota Maxxum 70 Freshwater Bow Mount...
Minn kota will turn on and off with remote, but will only turn 1" to each side.
take off the top cover on the head of the motor and see if there are any restrictions to the movement of the cable. it may be the cable itself is rusted internally and may need replacement. call min kota on the 800 number on the motor for prices for any patrs you may need.
May 28, 2010 | Minn Kota Riptide Sp Saltwater 70 Bow...
I have a 74LBS thrust trolling motor that hasn't never in my opion worked right, I don't think its wired right to get the proper 24 volts, However I have took it loose and hooked it directly to 2 marine...
Here is a picture of the wire connection for 24 volt. Compare to yours is it correct? If it is, I wish you listed make and model I could of sent you the right picture diagram of you motor. Use this picture as a starting point. Test the wires through the motor testing for 24 volts. Again if I knew make and model I could show you exactly were. Last if voltage is correct all the way through. The motor is the last thing to tear down. If the brushes or armeture is damaged in anyway, or manufactured wrong, it would lead to power loss.
Nov 18, 2009 | Minn Kota Riptide St Saltwater 80 Bow...
Burning out fuses on trolling motor at battery
not enough info. I went the the min kota website, they show four maxxum 80's at different voltages.is it a 12v 24v or larger? without a year model I'll have no reference to what wiring schematic Is the fuse connected inline with the trolling motor? what size amp fuse are you burning up? well I can give you some troubleshooting tips. tools to buy (1) amp gauge. if you are unfamilier with amp gauges make sure you get instruction book with gauge or you could burn yourself. Toubleshooting(1) Remove cover off minn kota trolling motor. black cover ontop of unit were the foot control wires go into.turn over foot control remove cover (2) check for corrosion. any exposed terminals should be cleaned.(3) go to your batteries and clean all connections. make sure the batteries are fully charged.(4) take amp gauge and test positive wire for amp draw as you tun on trollling motor and run it through all speeds. if batteries are in the rear away from trolling motor get a 2nd person to control trolling motor. if the trolling motor is more than a 12v system you will have more than one positive lead to test.GOAL. What your trying to find out is how many amps the trolling motor is really pulling. and at what speeds. under a load in the water and out of the water.how many more amps than the fuse raiting? newer trolling motors come with inline breakers not fuses so I'm guessing your using 30 amp fuses. again without more info i can only guess.
Oct 29, 2009 | Minn Kota Maxxum 70 Freshwater Bow Mount...
Wiring diagram for Die Hard 28 lbs thrust trolling motor
It's probably a Minn kota with a die hard label. Call Minn kota and ask them.
Aug 08, 2008 | Boating
Minn Kota Riptide St Saltwater 80 Bow Mount Trolling Motor Logo
584 people viewed this question
Top Minn Kota Boating Experts
Mike Marcotte
Mike Marcotte
Andrew Taylor
Andrew Taylor
Colin Stickland
Colin Stickland
Are you a Minn Kota Boating Expert? Answer questions, earn points and help others
