Question about Frigidaire GLTF2940ES Front Load Washer
Fabric softner does not empty
The fabric softner compartment is almost always full with water at the end of the cycle. Fabric softner is still in compartment.
    Novelist:
    Champion:
  • 220 Answers
I had a similar problem and removed the complete dispenser drawer and washed it in with hot water. The small inner cups for the fabric softener and bleach should be removed and the hot water directed into the small "stand pipes" on the back side of the covers. It appears the fluids in the cups are siphoned out and if the pipes are clogged at the bottom there will be no flow. Also is the plate is not fully seated, the siphon effect is will not work.
Also, my wife said she does not use the cheaper brands of fabric softener anymore because we think that might have caused some of the clogging.
As a side note, if you remove the top of the washer, there is an adjustable dial where you can fine tune the amount of liquid dispenced. You can try adjusting that too. I think my final fix was to clean the back side of the face plates inside the dispenser and ensure they are fully seated to allow the proper siphon effect.
Posted on Jan 15, 2009
My question is this..why doesnt my clothes smell like fabric softner?? They dont smell at all..like i never put anything in there...and the fabric softner compartment never fully drains of its water what...
The fabric softener may be unscented.
The softener compartment is flushed during the wash cycle to clear it completely, therefore some water remains at the end.
Aug 01, 2014 | Washing Machines
Bleach and Fabric Softner Dispenser
Hi
This is a result of the siphoning action and is part of the normal operation of the washer. Water
may be removed by removing the dispenser drawer and draining
water into the empty drum or sink.
Outside
• When washing is completed, wipe top and sides of washer with a damp cloth. Turn water
faucets off to prevent pressure build-up in the hoses.
• As needed, clean the cabinet with mild soap and water. Never use harsh, gritty or
abrasive cleansers. If door or console becomes stained, clean with diluted chlorine bleach
[1/2 cup (120 ml) in 1 quart (.95 L) water]. Rinse several times with clear water.
• Remove glue residue from tape or labels with a mixture of warm water and mild detergent.
Or, touch residue with the sticky side of the tape or label.
• Before moving the washer, place a strip of cardboard or thin fiberboard under the front
leveling legs to prevent floor damage.
Cleaning the Dispenser Drawer Area
Detergent and fabric softener may build up in the dispenser drawer. Residue should be removed
once or twice a month.
• Remove the drawer by pulling the drawer out until it stops. (Figure 1)
• Reach back into the left rear corner of the drawer cavity and press down firmly on the lock
tab (left rear portion of the drawer). Pull out the drawer. (Figure 2)
• Remove the insert from the bleach and fabric softener compartments. (Figure 3)
• Rinse the drawer and inserts with hot tap water to remove traces of accumulated powders
and liquids. Large amounts of fabric softener residue may indicate improper dilution or
more frequent cleaning is required.
• To clean the drawer opening, use a small brush to clean the recess. Remove all residue
from the upper and lower parts of the recess. (Figure 4)
• Replace the insert pressing the "X" to lock it in place. Return the dispenser drawer.
Inside
• Remove items from the washer as soon as the cycle ends. Excess wrinkling, color transfer,
and odors may develop in items left in the washer.
• Before cleaning the washer interior, unplug the electrical power cord to avoid electrical
shock hazards.
• Dry around the washer door opening, flexible gasket, and door glass. These areas should
always be clean to ensure a water tight seal.
• When extremely soiled items have been washed, a dirty residue may remain on the drum.
Remove this by wiping the drum with a nonabrasive household cleanser. Rinse thoroughly
with water.
• Periodically, wipe dry the bottom of the flexible gasket to remove lint and other debris.
• The plastic drum vanes may become stained from fabric dye. Clean these parts with a
nonabrasive household cleanser. This prevents dye transfer to future loads.
try this out for more ref check the operations mannual page 7
Dec 07, 2007 | Frigidaire Affinity ATF7000ES Front Load...
The fabric conditioner drawer is always full of water at the end of the cycle, i have tried cleaning it and running the machine empty but nothing has worked.
fabric conditioner drawer is always full of water This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 02, 2011 | Washing Machines
Water in the fabric softner compartment after wash cycle
You need to poke all the holes clear in the top of the dispenser housing with a piece of wire or similar.
This should solve the problem.
Dec 15, 2009 | Washing Machines
Water left in bleach and fabric softner after running load
You must take out the compartment and empty it out before adding any bleach the next time, there is a type of button way in the back that you press down on pull out the entire door and empty the water for the next washing. You must press down very hard the entire door does come out check out your book for instructions it is way in the back on the left hand side. This happens to mine once in a while not all the time.
May 05, 2009 | LG WM1812C Front Load Washer
Problems with fabric softener
check the water solenoid for open circuit, this is the water valve that supplies water to the compartment
Sep 28, 2007 | Bosch Axxis WFL 2060 Front Load Washer
Whirlpool duet fabric softner problem
It obviously is backed up or splashed in from the wash. And if it is just water why worry about it.
Aug 07, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Water in bleach/fabric softne compartment
Purchased the duet washer and dryer sept 2004..have had the same problem with water staying in the compartments. while under warranty had to place 2 service calls..the last tech order a new bleach compartment...that helped for a few months, but back to the same problem with having to pull entire container out and empty..i do remember the tech saying that whirlpool duet was first introduced in germany...then the united states...they have had the same problem...and that whirlpool is awhere of it, but nothing can be done about...except keep emptying compartment when it fills with water...our neighbor bought a duet washer last fall...no problems like we are having..whirlpool must of solved that issue with the newer versions.... paying $1000.00 for a washer and having to empty the compartment everytime doesn't make sense to me.
Dec 12, 2006 | Whirlpool Duet GHW9150P Front Load Washer
Frigidaire GLTF2940ES Front Load Washer Logo
496 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
