Question about Intermatic T10404R - Two 220 time clocks in raintight box
Operator manual for a GE GLXQ22W30 timer
I need an operators manual for the above General Electric timer. These timers are commonly available but do you think I can find the manual for mine. I need to be able to program it so a manual or someone who knows how would be appreciated.
4 Suggested Answers
gotgeek2
  • 565 Answers
SOURCE: Need Timer Instructions
Here ya go:
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/ej500c%20-%20english.ashx
Posted on Dec 08, 2009
SOURCE: how do I set the ge timer model #15119. husband
I tried to pull the whole dial and doing that I discovered that the border of the dial is composed by pins that you can pull it up each independently, with your nail or with any pointing device. The rest is easy: get sure the switch is set at "timer on", turn the dial to the current time using the black triangle mark and pull the pin up in the time you want your device to disconnect.
Posted on Dec 21, 2009
SOURCE: Can GE Digital Timer model 15086 be used for two way switch?
GE 15086 can replace single pole switch only.
If you have "3-way" switch, that is when 2 switches control same light, for example in a hallway.
Open link below to identify GE15086 timer, see wiring instructions, on-line manual <> and see list of timers that can be used for 3-way switching with links to those timers and manuals:
http://waterheatertimer.org/GE-timers-and-manuals.html#15086
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Jan 27, 2011
GE 15136 timer display stopped working
Try resetting timer, and reprogramming.
The GE brand of electronic box timers is not dependable long-term product. The 30-40 amp contact ratings do not appear consistent with rest of timer quality. I think the amp load is overrated from what I have seen, compared with heavy duty timers like Intermatic GM40AVE series etc.
My local home depot has replaced the GE line of box timers with 100% reliable Intermatic T100 series mechanical timers.
http://waterheatertimer.org/GE-timers-and-manuals.html#15136
15136 is not battery-operated timer, and there are no repair parts.
15136 timer is rated outdoors, with temperature range -40F to +130F, which sounds like hardened electronics.
But often these cheaper electronic devices with plastic gears and multi-voltage are not hardened for years of dependable service as found with commercial grade timers.
Nor are they protected from surge caused by local power outage or nearby lightning strike.
For most dependable timer, and cost effective, choose T100 series or T170 series with skip-a-day... repair parts available... timer will last decades
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#T100-series
Gene
h
Nov 23, 2013 | General Electric Hardware & Accessories
GE plug in mechanical timer model 15417
Copy following links to identify timer and setting analog timer by experimenting with features.
GE timers change appearance as model numbers are upgraded, but all 24-hour analog timers have same basic features.
http://waterheatertimer.org/GE-timers-and-manuals.html#15119
http://waterheatertimer.org/How-to-set-timers.html
Sep 23, 2012 | General Electric Ge 24-hour Mechanical...
GE digital timer DT300 need a free manual
Question posted under GE 15004 timer.
Open following link to identify Intermatic DT300 timer and download possible manual.
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#DT300
http://waterheatertimer.org/pdf/DT300-series-manual.pdf
Open following link to identify GE15091 timer and download possible manual:
http://waterheatertimer.org/GE-timers-and-manuals.html#15091
If the free information does not match your timer, then add a comment with clear description of timer for possible identification and manual.
Sep 23, 2011 | General Electric GE 24-Hour Timer, 2-Pin...
Need to know how to set timer #15075
GE 15075 is heavy-duty plug-in-type 24-hour analog timer with pins located around dial.
Each pin represents 1/2 hour. Two consecutive pins represent 1 hour.
Open following links to identify timer and to read detailed instructions:
http://waterheatertimer.org/GE-timers-and-manuals.html#15075
Aug 31, 2011 | General Electric GE 24-Hour Timer, 2-Pin...
My GE 15132 was operating fine for a year but now is losing time..the clock runs about 4 hours a day slow...I am resetting it once or twice a day....what could be wrong??
Contact Jasco and tell them what you said here.
http://www.jascoproducts.com/contactus/index.asp
Although GE has made high-quality timers for many years, the 15000 series box timers have been on the mass market for a year or so, and there are no replacement parts like available for Intermatic timers.
I tested the GE series and found them to be cheaply made with moveable plastic parts and lightweight overall.
http://waterheatertimer.org/GE-15207-clock.html
Jun 24, 2011 | General Electric GE 56941 24-Hour Outdoor...
How do I work a GE 24-hour timer? There were no instructions. I don't know if I'm supposed to have the lamp turned on or off in order for the timer to work.
Yes the lamp must be turned on.
Bulb must be in working order.
http://waterheatertimer.org/GE-timers-and-manuals.html#15004
If link above does not show your timer, then add a comment
The GE 15004 timer does not have a manual at Jasco, so many folks write in about this timer
To set the timer, rotate dial until current time lines up with pointer located on inner dial.
The trippers are located on outer edge of dial.
I'm am guessing that you move the trippers around to time, and then push tripper inward or outward.
I have looked at enlarged photos of timer but cannot say exactly how the tripper is set.
Green tripper is ON
Red tripper is OFF
There is a switch located on side of timer.
Move switch to ON for timer to operate.
Plug lamp into timer.
Plug timer into wall.
To check on-off settings, manually rotate dial clockwise with your hand and watch lights turn ON-OFF.
Check switch is supposed to be set ON, by moving switch both ways.
You can also take advantage of fixya phone service.
Expert will talk with you via phone for a price.
Dec 25, 2010 | General Electric GE 24-Hour Timer, 2-Pin...
I need instructions for how to set a 24 hour mechanical General Purpose timer. My model #15075
GE 15075 manual:
http://www.jascoproducts.com/support/manual-downloads/applications/DocumentLibraryManager/upload/Plug-In-15075-Manual-eng.pdf
GE 15075 is a plug-in timer.
Before you plug it in, set the timer so you're not bent over at the receptacle.
Rotate dial until current time lines up with triangle located on inner dial.
There are movable pins located around the dial.
These pins cause the timer to turn on and off.
Pins out = timer on
Pins in = timer off
plug in your lamp and the timer turns on and off.
After power outage, set current time again.
Oct 25, 2010 | Electric Eyeware Ge 24 Hour Electric...
How do I set a general electric outdoor timer
If I understand you correctly, you have GE outdoor box-type timer, for example the GE-15087. If this is the wrong timer, please respond with model number and I'll look up the information.
http://waterheatertimer.org/How-to-wire-GE-15207-timer.html
http://waterheatertimer.org/How-to-wire-GE-15087-timer.html
6888635.jpgSegment up, timer on segment down, timer off
GE has additional manuals
http://www.jascoproducts.com/support/manual-downloads/index.asp?search=timer&submit=Search&offset=-1
Oct 19, 2010 | General Electric Hardware & Accessories
Intermatic T10404R - Two 220 time clocks in raintight box Logo
675 people viewed this question
Top Intermatic Hardware & Accessories Experts
Gene Haynes
Jay Finke
Jay Finke
Steve
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
